Question about E-Machines eMachines T3830 PC Desktop
Desktop E-Machine in suspended mode.
HI SILLY GIRL,
GOOD ARTICLE,
YOUR NOT AS SILLY AS YOU ARE SMART.
I CAME ACROSS THE SAME SITUATION A WHILE BACK WITH MY
HOME MADE DESKTOP. IT WAS IN A STATE OF BEING SUSPENDED,
BUT I DIDN'T KNOW WHAT THAT WAS, WHICH MAKES PERFECT SENSE TO ME NOW. FOR AFTER I SEND MY GIGABYTE MOBO IN FOR REPAIR, TO WHICH THEY FOUND NOTHING WRONG.
I PUT IT BACK TOGETHER, AND "WOW LA" I WAS BACK UP AND RUNNING.
I'D LIKE TO ASK YOUR OPINION, IF IT'S NOT TO PUSHY.
I'D APPRECIATE ANYTHING YOU MAY HAVE TO TELL ME.
THANKS FOR YOUR TIME IN READING THIS.
WELL NOW, I FOUND A VERY NEW GATEWAY GT 5228, THAT THIS GUY HAD THROWN AWAY, AND I UNPLUGGED EVERYTHING, AND A FEW HOURS WENT BY AS I WAS WORKING ON ANOTHER PC. SO I PUT IT BACK TOGETHER, AND IT BOOTED RIGHT UP.
I MADE MYSELF THE ADMINISTRATOR, AND THEN WENT INTO THE BIO'S AND LOOKED AROUND, AND IN THE BOOT ORDER, I MADE REMOVABLES 1st BOOT, FOLLOWED BY CD, THEN HDD, AND THEN DECIDED NOT TO MAKE THE CHANGES, BUT OUT OF HABIT, I HIT THE F10, WHICH KEPT THE CHANGES, AND IT GOT HUNG UP ON THE REBOOT. SO AFTER ABOUT 10 MIN'S I JUST SHUT IT OFF.
SO NOW I'M AT THE BEGINNING AGAIN. SO LAST NIGHT I DISCONNECTED EVERYTHING, AND REMOVED THE CMOS BATTERY, AND SHORTED IT OUT.
DO YOU KNOW HOW LONG IT TAKES THE MEMORY MODULES TO LOSE THEIR STORED MEMORY, AND IS THERE A FASTER WAY TO DISCHARGE THE MEMORY MODULES OF THEIR MEMORY, OR DOES IT CLEAR THE PC'S MEMORY, THE MINUTE YOU REMOVE THEM?
THANKS AGAIN, FOR ANYTHING YOU MAY HAVE TO TELL ME.
SINCERELY,
TOM
  • 558 Answers
Capacitors loose their power within 10 seconds so 20 seconds with the power turned off or completely disconnected and the c mos shorted will do the job in 20 seconds
Posted on May 11, 2008
Was a teacher in Oxford, England really fired for calling a girl a girl ?
He was suspended, not fired. The teacher, Joshua Sutcliffe, is also an evangelical preacher. And the student, although a natural-born girl, is a trans, and identifies as a "boy," which he or she prefers being addressed as.
Dec 20, 2017 | Miscellaneous
Kenmore elite smart Wash quiet pak 9 has got the control panel set to lock mode. How can we open it?
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 27, 2009 | Kenmore Elite 45986 Front Load Washer
The dell girl
See if you can do this, Tap the F12 while booting and see if the restore features open,if not try the same thing with F11 key,once it opens just restore to the last known good configuration.
If you still have trouble,just send me another request.
Jan 15, 2009 | Dell XPS M1210 Notebook
Window resume loader
Windows Vista doesn't shut down the machine by default when you press the power button. Additionally, if you look at the bottom of the start menu you'll see this:
The button on the left, highlighted here in bronze, does NOT turn the machine off in Windows - it suspends it, which requires power. When the battery runs down, the power goes out and you get this message the next time you start up.
Some laptops also indicate suspend mode by flashing the power light.
Happily, if you click on the little right facing arrow a menu pops up, one of the options of which is "Shut down" and this will bring Windows down properly and fully.
You can also change the function of the power switch (which defaults to suspend, NOT shut down) by going into the power options from Control Panel:
Selecting one of the above options will allow you to set the power button and closing the lid to turn the machine off fully, not suspend it.
May 27, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Cannot get out of running windows normally
You didn't loose you work, windows only got corrupted as what often happens. Start up into safe mode, then run "scan disk" and select fix errors automatically, it might take a while to run. Maybe with a little luck it might find some errors and fix it.
Worst case situation - put the hard drive in another computer that boots in order to back up work, then put it back in your machine and buy a copy of windows xp. Then install drivers from Acer's website. (might have to use a jump drive with another machine to install first network drivers on your machine)
Hope this helps maybe a bit......
Apr 25, 2008 | Acer Aspire E360 PC Desktop
My girl left me and changeg my login password
Let me know what kind of PC Desktop you have,. Any way turn on your PC once get started press F8 then safe mode when the windows start at safe mode go to control then user account click the user that has a password and start to remove the password
Mar 22, 2008 | Computers & Internet
Can't get PC out of Suspend mode
Please press The same Suspend Button
Feb 29, 2008 | Computers & Internet
E-Machines eMachines T3830 PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
