Question about LG DLE5977 Electric Dryer
Loud rattle as it dries, dryer is five years old, is it just the rollers?
  • 1 more comment
  • BigGrip Sep 01, 2010
    Does it rattle even if nothing is in it?
  • jileks2002 Sep 01, 2010
    Yep
    the top or the back of the dryer should be able to open either by screws from the back or pushing the front corners to one side or the other. See if you can pinpoint where the noise is coming from or if something got trapped around the drum and just needs to be removed.
  • LG Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 04, 2010
Dryer makes loud rattling noise while drying
How old is your dryer? My dryer was making a horrible rattling noise and it turned out to be the idler pulley.
Sep 19, 2016 | Kenmore Elite HE4 Electric Dryer
My dyer is makes a loud, rattling sound.
did you find what caused the blower fan to break in the first place?I suspect the casing around the fan may not be clearing and something is in the fan again. or the keepers to keep it on the motor shaft are loose. The rollers for the drum and belt may be faulty. these are all of the parts that move so it has to be one or more of them.
Mar 01, 2012 | Amana NED4500VQ Dryer
Rattling and very loud
Rattling and very loud sounds like a very worn roller on the belt tensioner inside the dryer. The top and front panels must be removed to replace these items. Remove the top first to inspect. Usually the inner bearing on the roller locks up making the roller to receive a flat spot on it which causes the belt to jump upon hitting the flat spot on the roller. That is the sound of the dryers drum you hear
Apr 17, 2010 | Dryers
Loud rattling noise, but dries ok
The drum of a dryer is supported b the front and back of the unit, spins on a felt gasket. Noise is coming from rollers or their is something stuck between drum and the felts. The pulley is a piece of springy metal with a plastic wheel on it, could also be worn. If you take off front of dryer, drum will come loose, check to see if something is stuck. Common for loose change to get jambed in felts. Also spin rollers and pulley to see if need to be replaced. I still think something is caught in felt.
Aug 17, 2009 | Kenmore 63942 Dryer
Neptune gas dryer rattles sporadically when running.
do you fell it rattleing alot? Its can be the rollers are very worn and need to be replaced or the center of the rollers need to be greased up. hope this helps...
Jul 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas Dryer is Noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 19, 2009 | Maytag MDG7600AW Gas Dryer
Kenmore 70 series dryer making loud rattling noise, drying ok
it could be a worn motor bearing, but they usually last for 20 years, i would guess that you have a worn drum roller, the thing that holds up the drum and looks like a wheel.
if your sure the motor has a worn bearing then replacing the motor is not easy as you have to unscrew the blower wheel from the motor shaft.
it also may be that you are talking about the idler pulley being worn. it is the device that holds tension against the belt and they also will wear out and be "wobbly"
Dec 28, 2008 | Kenmore 63942 Dryer
Fisher and paykel dryer works but very noisy
Dec 27, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
LG DLE5977 Electric Dryer Logo
247 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
