Question about Roland Juno-D
What kind of lithium battery does the D 50 take?
  • Roland Master
  • 5,603 Answers
The schematics I found for the Juno D do not show any battery.
Posted on Sep 01, 2010
Why won't my digitech 21pro save my program changes. I know how to chage parameters and save those changes yet when after saving them and shutting down the unit, when I fire it back up it goes
Did you try changing the battery yet? It uses a lithium battery to keep the settings in memory and those eventually die. People forget that old electronics needed juice all the time.
Jan 06, 2015 | Music
Factory reset on korg x 50
FACTORY RESET:
  1. Press the [GLOBAL] button to enter Global mode.
  2. Press the [EXIT] button.
  3. Press the [UTILITY] button
  4. Select "Load Preload Data," by using the ClickPoint [?] button, and press the [CENTER].
  5. Choose "Kind," (All)
  6. Press the [MENU/OK] button.
  7. When a dialog box will ask you, press the [MENU/OK] button
May 01, 2014 | Korg X50 X-50 Keyboard
No Sound or beeps
There may be a mute button. and sometimes not that easily spotted/ and . or may be a combination of buttons. what kind of unit is it?
Apr 19, 2014 | Seiko Digital Metronome DM-50 - Red
Sabine zoid z-1000 blinks
More than likely you need a new battery those can be cheaply had if you buy 12 piece tea lights with LEDs they have CR2032 in them that's a lithium battery
Apr 02, 2014 | Sabine Z-3000M Zoid Tuner Metronome
When plugged into my churches pa system through a direct box the volume gets really loud then really quite and then sometimes normal. I'm using a lithium battery
Talk to your sound man... It is possible he has a compressor on the line. A compressor adjusts the volume dynamically and delays tweeking and releasing as a setting. Your guitar should NOT run through a compressor.
Aug 08, 2011 | Martin Guitars Martin XC1T Ellipse...
SD5K Drum module NOT saving user defined voices.
Possibly has a Lithium battery in it that is depleted that maintains the saved data.
Jun 02, 2011 | Simmons SD5K 7Piece Electronic Drum Kit
Is the TC Electronic Nova Repeater supposed to retain all of the settings when the power is turned off to it? Mine did and doesn't anymore. Is there a master reset for this pedal?
The unit should store the data ASSUMING you have done the store, I suspect the unit has an internal backup battery, probably Lithium, which MAY be exhausted.
Jan 03, 2011 | TC Electronic Nova Repeater Pedal Guitar
MY korkg PA800 doesnt load the opperating system and it wont let me reformat it, all i get on startup is a clear screen and nothing else happens
I don't know if your keyboard has a lithium battery for memory backup but that used to be a symptom of battery failure in other synths. Here is a link to a forum that discusses all the various problems:http://www.korgforums.com/forum/phpBB2/viewtopic.php?t=38399 Lots of reading buts lots of links and help.
Jul 08, 2010 | Korg Pa800 Synthesizer
Replacement Battery Problems Kurzweil Mk 152
Check the voltage provided by the cells. Each cell should be above 3 volts. Make sure they are installed with correct polarity and the contacts are making. Brand new cells CAN be bad and some holders may not contact properly.
Jul 23, 2009 | Music
I need to buy a replace battery for a yamaha sp900
usually its a standard lithium cell cr 2032 which you can find anywhere
Jul 15, 2009 | Music
Roland Juno-D Logo
70 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
