Question about Haier Washing Machines
What is part a020 it fell off our machine and the machine will not spin
  • bandytiling Sep 01, 2010
    haier model hwmp60tlf
  • bandytiling Sep 03, 2010
    this is a top loader machine could we find parts list for this thanks dennis
  • 1,998 Answers
Do you have a picture of the part or can u describe the part? that number you gave does not come up as a part number
Posted on Sep 03, 2010
  • Haier Master
  • 19,396 Answers
Hi.
Please click on the link below and open the complete part list diagram. Enlarge the PDF page by zooming in to see the small parts.
If you still cannot find the part, take a picture of the part, use the Pictures button and post the part in a Fixya comment (you may need to reduce picture size to less than 150K).
Here link to complete part diagram.
If this helps, please do not forget to accept the answer.
Posted on Sep 02, 2010
  • Ginko
    Ginko Sep 30, 2010
    Well, I posted the part list, I expected some kind of feedback.
    The question is now closed, if you don't rate or ask back the question gets closed, and sometime rewarded to someone asking irrelevant questions. The model was already there:hwmp60tlf.
    Enjoy the part list.
    Goodbye.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post back with the model no# for your Haier washer so that I can further assist you with the issue.
Thanks
Rylee
Posted on Sep 01, 2010
The belt fell off, looked worn so purchased a new one and put it on (very tight!) Started machine, and belt new belt fell off. Pls help.
Can you confirm your model number? FAV6800A or FAV9800A?
If it's one of those models with 120VAC power cord removed from the service outlet and the front cover removed. See if you can rotate the Clutch Pulley CW the wash agitate direction and then CCW the Spin direction. The Clutch Pulley is the large pulley in the center of the washer. We are looking to see if the drive system is seized.
After the drive belt replacement was there any belt screech when you powered up the machine and selected a Wash or Spin Only Cycle?
Feb 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Daughter washed a feather pillow which fell apart in front load frigidare washer now it wont spin and drain can u help plz?
The drain is plugged...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 30, 2010 | Frigidaire ATF6000ES Front Load Washer
Model 110.92596100 won't spin
then there may be a problem with the basket drive tube,,,I found on my machine that the thrust washer had ground off the bottom of the basket drive tube and the clip that holds on the brake release arm had fell off and the arm fell down breaking the 2 little pins that go into the cam and it was not releasing the brake allowing the basket to spin,,,,i got a used 1 for 50 bucks installed it with a new clutch and works fine now,,, so i would check that area!
Mar 08, 2010 | Washing Machines
HAVE AN OLDER MODEL KENMORE 70 SERIES MACHINE THAT WILL NOT SPIN. WHAT SHOULD I CHECK?
check lid switch,,,,mine had a problem with the basket drive tube,found out the thrust washer had ground off the bottom of the tube and the clip that holds on the brake release arm fell off and the arm fell down breaking the two little post it has on it that go into the cam and it was not releasing the brake allowing the basket to spin,,,bought a good used 1 for 50 bucks,installed it and a new clutch and it works fine now!
Feb 27, 2010 | Kenmore Washing Machines
My maytage washer would make a terrible screaching noise during spin cycle..now no spin cycle and something smells like electrical burning...I unplugged the machine. What has happened and what needs to be...
check your motor coupling, it is between the motor and transmission,made of rubber and plastic, if it is not broken and you heard a lot of screaching ,i would say it is your basket drive tube-could have gotten worn down on the bottom around the clutch brake area! mine sheared off the brass t post on the bottom of the drive tube,which my clip holding on the brake release arm fell off ,arm fell off and thus no spin,i bought a used basket drive tube installed it with a new clutch and is working fine now! a lot of work though to replace it
Feb 15, 2010 | Maytag PAV2300 Top Load Washer
When the machine goes into spin mode it makes a loud screeching sound
could be your clutch or brake assy , mine was doing that and it turned out to be the clip on the basket tube was grinding off the bottom of the tube and the clip fell off ,clutch fell down thus no spinning cause it wasn't releasing the brake!
Feb 11, 2010 | Kenmore 24032\24036 Top Load Washer
My washing machine got to the spin cycle but didn't drain water
prolly cuz you didnt check your pockets first and either change or a set of keys fell out
Aug 15, 2009 | Washing Machines
DRUM WILL TURN TO EITHER WASH OR SPIN CLOTHES
your belt has probably fell off the back of the drum try turning the tub by hand see if you can hear the motor turning with it
Mar 31, 2009 | GE WSXH208A Front Load Washer
Won't Spin
CHECK TO SEE IF SMALL CLIP ON BOTTOM OF PULLEY HAS FALLEN OFF. IF CLIP FELL OFF, THE PULLEY MIGHT OF SLIDE DOWN AND MOTOR SHAFT IF SPINNING. PUSH PULLEY UP AND ON END OF SHAFT ARE NOTCHES WHERE CLIP SLIDES ON. GE RECOMMENDS YOU REPLACE IT. MACHINE NOT LEVEL OR CLOTHES NOT BALANCED PROPERLY CAN CAUSE CLIP TO FALL OFF. HOPEFULLY THIS INFO HELPS.
Mar 17, 2009 | GE Profile WPRE6100G Top Load Washer
Washing machine trouble
i need more info but can help front loader top loader brand etc
Dec 30, 2007 | Washing Machines
Washing Machines Logo
49 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
