Question about Lenovo 3000 N200 Notebook
I have a new battery of my lenovo 3000 n200 yesterday i have charged it for 18 hours before use ... then used the computer on battery power ... when it reached 34% I have plugged the charger I got the message "34% plugged in , not charging " when I release the charger the computer continues on battery power BUT NOT CHARGING Please help ......
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 08, 2010
Lenovo 3000 n200 bad bios flash
You can try removing the CMOS battery for a few hours. Did the BIOS update come from Lenovo website? What was the reason for the BIOS update, a problem? Altering the BIOS or the System Registry is like taking a stroll in a minefield, one wrong step and............well you know. Take a look at this forum: http://forums.lenovo.com/t5/Lenovo-3000-and-Essential/Help-How-to-reset-CMOS-on-3000-N200-model-0769/td-p/57678
Jan 11, 2013 | Lenovo 3000 N200 Notebook
Lenovo 3000 N200 0769wont charge, i brought a new battery and charger which both work the problem is the power doesnt seem to be going through to the battery to recharge it what could be causing this
Was the adapter you bought directly from Lenovo? I just know that dell builds in a chip to detect the adapter, if not original it will not charge the battery. I do not know if it's the same issue.
Feb 16, 2011 | Computers & Internet
My lenovo 3000 n 200 will not start :/ the only thing i can see is a lamp showing " Y " . when i put the charger to the computer the lamp who showing that the computer charging is not lightning. when i...
First tip is disconnect the battery and Adapter, hold down the power button for 30 sec. and the insert your battery and adapter and try starting. Let me know is this works or I can suggest something else.
Feb 06, 2010 | Lenovo 3000 N200 Notebook
Lenovo 3000 N200 Power Problem
It seems like the issue is with your Laptop Battery.
Please try to check the same battery with some other laptop & see if that works, other wise you have to go for a Battery Replacement.
Hope this resoultion will help you to get the battrey issue resolved for you.
Cheers!!!!
Vivek
Dec 25, 2009 | Lenovo 3000 N200 PC Notebook
Lenovo 3000 N200 laptop not starting up, power light on
Keep pressed the power button of your laptop for about 30 seconds, the machine will power down.
--The above step may not be required as already so many days passed by.
Then plug it into the power adapter.
Switch the laptop on.
Boot in "safe mode" (F8 during boot).
This will fix any driver or some operating system issue during previous failed boot process.
Once it boots completely, do a normal shutdown and reboot your laptop in standard mode (no more F8 this time).
Now your laptop will be ready to use.
Sep 30, 2009 | Lenovo 3000 N200 Notebook
Laptop fan spin for 2 second and display not show
You must veryfi the CPU and try without battery or try it without charger with a already charged battery! This must work!
Sep 13, 2009 | Lenovo 3000 N200 Notebook
Lenovo 3000 N200 battery not charging.
I just had the same problem. My battery had discharged to less than zero and would not start even though the power plug was in. I tried everything... but what fixed it for me was to remove the power plug, remove the battery, plug in the power cord and start the machine. Once the machine was already booted, I put the battery in and it started charging. Dont know if that will fix your problem, but it fixed mine.
Sep 05, 2009 | Lenovo 3000 N200 Notebook
Require Audio Driver for Lenovo 3000 N200 type 769 dual-core
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP audio driver for your model laptop,
www-307.ibm.com/pc/support/site.wss/MIGR-39956.html
Feb 22, 2009 | Lenovo 3000 N200 Notebook
Computer hangs up due to power failure:
1) Replace your laptop's battery.
2) Run Reginout Scan.
thank you....
Jan 05, 2009 | Lenovo 3000 N200 Notebook
Lenovo 3000 N200 Notebook Logo
126 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
