Question about Lithonia Lighting Psq500 Power Sentry Inverter Charger
We have had numerous failures of the Lithonia #427 emergency lighting fixture withe the PS1400 "Power Sentry" battery pack. Is there a recall or assistance available. This is in a 3 year old school and we have lost dozens of them starting immediatly after the installation.
2 Suggested Answers
SOURCE: lithonia power sentry ps1400 wiring diagram
wiring diagram for power sentry ps1400 inverter
Posted on Nov 18, 2010
How do I open the fixture to change the battery?
usually there are clips or snaps and screws that hold it together
Mar 02, 2015 | Lithonia Lighting 2 Head Emergency Light...
How do I repair Lithonia ECR M6 LED Emergency/Exit Light combo. No emerg lights when test button is depressed, no led lights from AC? just a flash when test switch is depressed? is it the small transf
Fixtures are covered by Lithonia Lighting 24-month warranty against mechanical defects in manufacture.
All life safety equipment, including emergency lighting for path of egress must be maintained, serviced, and
tested in accordance with all National Fire Protection Association (NFPA) and local codes. Failure to perform the
required maintenance, service, or testing could jeopardize the safety of occupants and will void all warranties.
Note: Specifiations subject to change without notice.
Actual performance may diffr as a result of end-user environment and application.
Standard
Catalog Supply Input Pallet Carton
Number UPC Description Voltage Wattage Qty. Qty.
ECR LED M6 784231874516 Red 120/277 3.8 108 6
ECG LED M6 784231874592 Green 120/277 3.2 108 6
ECR LED HO M6 784231874561 Red, high output 120/277 3.8 108 6
ECG LED HO M6 784231874615 Green, high output 120/277 3.2 108 6
Accessories: Order as separate catalog number.
ELA WG3 Wireguard (back mount only) 1
ELA LED M12 Single remote lamp2,3
ELA LED T M12 Double remote lamp2,3
ELA LED WP M12 Single, weather-proof remote lamp2,3
ELA LED T WP M12 Double, weather-proof remote lamp2,3
Notes
1 See spec sheet ELA-WG.
2 See spec sheet LED-Remote Lamps.
3 Only available with HO option.
11 5/8 "
7 3/16 "
1 5/8 "
Integrated Exit-Unit Combo
12-5/8"
(32.1)
8"
(20.3)
4-3/8"
(11.1)
5-3/8"
(13.7)
1-7/8"
(4.8)
LED Unit
LED Combo
LED Exit
15 (38.1)
3-3/4
(9.5)
5-3/8 (13.7)
12 (30.5)
3-3/4
(9.5)
2"
(5.2)
4-1/2"
(11.4)
9"
(22.9) 8"
(20.3)
20"
(50.8)
12"
(30.5)
All dimensions are inches (centimeters).
Shipping weight: 3.6 lbs. (1.6 kgs.).
ECR LE
Oct 27, 2014 | Lithonia ECR M6 Exit/Emergency Lighting...
We have Lithonia 2 bulb fixtures in a recessed ceiling. We currently have 2 (25) watt bulbs in them. What wattage can I upgrade to ??
The ballast inside the fixture is rated to operate 2 25w bulbs. You can't put higher wattage bulbs in this fixture, unless you change the ballast. Sorry.
Sep 22, 2014 | Lithonia Lighting Fluorescent Flush Mount...
What damage takes place when the battery polarity is reversed on a lithonia emergency light fixture(IND2100)
well if you did hot to neutral it will mess it up, most lights come with wires colored, black to load, white to neutral and green to ground, so if you hooked it up backwards, it will work for a short time then will not at all
Nov 17, 2011 | Home
We have 48" lithonia flouresent
even if there is power at the sockets, ballast may not have power to fire off the lamps, how old is this fixture, and you need to replace the ballast same as in fixture, if you replace ballast make diagram of wiring so you can rewire it like it was wired from store.
Aug 21, 2011 | Lithonia Lighting White Finish 2 12" High...
I need a lithona lighting power sentry psdl3 wiring diagram
http://www.lithonia.com/SpecSheets.aspx
Lithona has a lot of products and they show the manuals.
Unlike a lot of companies where manuals are not available, as if customers live in the 1980's and still write to companies asking for information.
I don't see your speicific product at Lithona.
A search for 'power sentry' turned up many possible products.
Unlike a lot of sites that just say, 0 results.
Many times, the same product will have more than 1 name or product-number depending on who is selling the product >>> that's how different companies can sell the same product but claim their product line is unique.
You might search the manuals at Lithona and find a similar product under a different name or number.
Oct 15, 2010 | Lithonia Lighting Psq500 Power Sentry...
No power to lighting ballast ,only lights up on loss of power 277v at emergency ballast
Follow the appropriate wiring exactly. There are about 6-8 different diagrams. Find your lamp type and number of lamps. Locate your ballast type (usually instant these days) Quite often these diagrams show a switch on the power lead going to the operating ballast. If it isn't on a switch be sure to wire it in with the lead to the emergency battery ballast.
Jun 30, 2010 | Lithonia Lighting Psq500 Power Sentry...
Kill power to light and emergency single light does not turn on also with power on push test knob and emergency bulb not come on
Hello Ramon, Check the power back (battery cell) as without a functioning battery pack, the emerbency light won't function.
Typically the batery packs will need to be replaced periodically every 4-5 years, depending on the istallation location and ambient temperatures.
When you kill the power to the emergency lighting circuit the PSQ is switched to operate automatically on battery power only. The same thing occurs when you press the test button; it disconnects the lighting from the electric power that keeps the battery charged and ready for service. You might also want to check the bulbs with a test meter (remove the bulbs from the fixture and test with the Ohm setting) While rare that these bulbs burn out, since they aren't usually illuminated often, only during a power disruption/outage, etc.
Here's a link to the Lithonia site with the spec sheets for the PSQ series of emergency lighting products, for your use and reference.
http://www.lithonia.com/product/advSrch.aspx
I hope you find this Very Helpful and best regards!
Nov 24, 2009 | Lithonia Lighting Psq500 Power Sentry...
Changing ballast
Here is the link for wiring Lithonia Power Sentry Ballasts: http://www.acuitybrandslighting.com/Library/LL/documents/Installation%20Instruction%20Sheets/PS.pdf
Hope this helps Sparkylikes480
Mar 27, 2009 | Lithonia Lighting Psq500 Power Sentry...
Lithonia Lighting Psq500 Power Sentry Inverter Charger Logo
343 people viewed this question
Top Lithonia Lighting Electronics - Others Experts
Are you a Lithonia Lighting Electronics - Other Expert? Answer questions, earn points and help others
