Question about Harman Kardon HKTS 7 System
I have a HKTS-7 sub that is stuck in the stand by mode and wont come out(constant yellow light). Please could someone help. Thanks in advance.
3 Suggested Answers
ravichetty
  • 158 Answers
SOURCE: The sub has a loud buzzing when turned on (harman
sounds like your audio stage is blown
Posted on Jul 22, 2009
atang1
  • 734 Answers
SOURCE: My HKTS 7 Sub woofer makes no noise,the led burns
Subwoofer is center speaker from A+B speaker signals. first check your wire to the receiver. Otherwise you need electronics service on the amplifier inside the speaker.
Posted on Dec 04, 2010
My subwoofer will not wake up, regardless of whether I flip the switch from Auto to On or not. Suggestions?
The sub settings for testing should be: Crossover frequency - Max; Volume - Mid; Phase - Normal.
As a quick test, unplug the sub cab from the amplifier/receiver end. Switch on the sub and turn the volume down all the way. Briefly put your finger across to short the RCA/phono tip and ring. The sub should make a buzzing sound. You now know that the sub is working and the cable appears to be okay or not.
If you've got power then that's a good thing. It could be something simple as a broken solder joint or bulging capacitor.
Aug 05, 2014 | Harman Kardon HKTS 14 System
My sub ts7 won't power on
check the cable , might be it burned bcoz of the voltage fluctations.
If not check the transformer if its buzzing or not. if not- buzzing replace the power cord
Aug 08, 2012 | Harman Kardon HKTS 7 System
I am getting no sound from sub. The turns on, but so sound. I have connected to two different receivers to verify it isn't the receiver sub output.
Bear with me on this.
Just because two systems don't light this sub up doesn't prove the amps are faultless unless they work with other subs. Can you assert that?
See page 14:
http://www.retrevo.com/support/Harman-Kardon-HKTS-14-Speaker-Systems-manual/id/386ci056/t/2/
How are you driving the sub - Speaker or Line Level?
Jan 30, 2011 | Harman Kardon HKTS 14 System
My HKTS 7 Sub woofer makes no noise,the led burns from amber to blue as normal,and every so often i hear a low rumble noise. The Sub is powered and has 1 cable to the receiver, the fuse is also good.
Dec 04, 2010 | Harman Kardon HKTS 7 System
Sub-Woofer blowing fuses.
You should open it up and look for a short. Usually, an exposed wire is touching metal. Wrap the wire with electrical tape and look for a ground wires that are loose. That will blow fuses too.
Feb 15, 2010 | Harman Kardon HKTS 7 System
Yellow circuit protection light
Please see my tip HERE regarding Protection Mode for Car audio Amplifiers.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 18, 2009 | MTX (TC4004) Car Audio Amplifier
Sony Trinitron XBR, Stand By Mode?
Generically, the 6 or 7 blinks usually indicate a problem with the horizontal circuit. In order to provide accurate diagnosis and suggested solutions, the exact model number is needed. Please update this with tha number and I will post more details.
Thanks,
Dan
Mar 18, 2009 | Televison & Video
Sharp xe-a41s cash register mode switch stuck
Sounds like you have the wrong key. Look at the letters on the key tab. OP stands for OPerator; it can only move from Off to Reg. MA stands for MAnager; it can move to all the marked positions. Some models also have an SM (Sub-Manager) key that moves from PGM1 to X1/Z1.
Mar 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
Wont come out of standby
Hi there, Im Kanth, i had the same problem, and i found a person in Mississauga, they fix all kind of problems in Plasma, they fixed my LG before a 7 months, its still running good, i came to know lots of ppls were having same problems, i sujest u to being the plasma to electronics @ Dixie and Britannia Mississauga, call them now 905 565 6595 or check there wesite for more info. http://dukeelectronic.com
Mar 08, 2008 | LG 50PX4DR 50 in. Plasma TV
Harman Kardon HKTS 7 System Logo
104 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
