Question about V.Smile V-Motion Active Learning System
When I turn the console on, the logo pops up an says "V Smile Motion." However, if I put a game in and turn it on, it does absolutely nothing.
  • 3 Answers
This worked for me!
Ttry removing all of the batteries or unplugging the power cord..and holding down the "ON" button for about 45 seconds. Then replace the batteries (be sure they are fresh) and try your product again. It is somewhat of a "hidden" Re-Set button.
Posted on Sep 16, 2010
Wireless controller not connecting, wireless light just flashes after it worked for the first couple of games.
I can't connect the controller to the console. It did work, but now the light flashes on the controller but not on the console. Any ideas?
Jan 15, 2011 | V.Smile V-Motion Active Learning System
I was playing C.O.D MW2 but my xbox was turned upside down so i turned it back the right way then my xbox made a few noises then a notice pops up and says could not read disc. so i cleaned yhe disc with a...
There is really big chance for an Xbox 360 to completely ruin a game disc if it was moved while the disc is spinning inside, even the slightest bump or vibration could higly cause for a disc to be scratched. This also happens with other optical drives which has spinning motion, say DVD/CD players and other game consoles.
May 13, 2010 | Microsoft Xbox Console
V-smile not working once cartridge is placed in slot
Here's the solution to your V smile: Oxidized connectors! Remeber the original Nintendo back in the 80s? You had to repeatedly reinsert the cartridge so that it would work properly. The V smile has the same problem. They use tin plated copper contacts on the game cartridges as well as the internal connector. All newer electronics use gold plated contacts because gold does not oxidize (rust, corrode). You'll need a very fine sheet of sandpaper. Start by lightly sanding the game cartridge connector (you have to expose the contacts by pushing the plastic part in). Make sure you wipe the contacts clean with a rag, and do not touch the contacts with your fingers! Then you have to do the same with the console's internal connector. The danger here is bending one of the pins inside so be very careful. The real solution to this would be to replace the connector but no one sells it (checked ebay, Vtech). Should last a couple of months to a few years, depending on relative humidity and use. If your V smile turns on normally without a game cartridge, then this is your problem. Symptoms vary from no power to corrupted graphics to no sound as well as random turn off (with a cartridge, no problems without a cartridge). I've done a few lately and all are working like new. Let me know how it goes, but I take no responsability for bent pins, damaged connectors, fire, earthquake,...
Jan 13, 2009 | Vtech V.Smile TV Learning System
Power won't come on
This is a problem with the cartridge not the console. The cartridges get dirty and then the console acts as if its broken because it can't read the cartridge. Pull the purple flap up so that you can see the inside of the cartridge and clean it with an alcohol based cleaning solution. Dry the cartridge fully before inserting it back into the console. I have done this for serveral games and they have worked again. A couple of games have just broken and refused to clean up. Hope this helps, let me know.
Dec 03, 2008 | V.Smile V Smile Console
Having issues when the games are in the console
Make sure the system is turned off before inserting the cartridges. Things you can try to get the V.Smile TV Learning System to work:
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Nov 28, 2008 | Vtech V.Smile TV Learning System
My Guitar Hero 3 Game Will Not Go Past PS2 logo at start!!!
i think you should take the alcohol and take a cotton swab and gently brush the lens back and forth for 30 seconds. Then take the alcohol and take a really soft tissue and rub it in a circular motion.
Jul 03, 2008 | Sony PlayStation 2 (PS2) Console
Xbox 360
you are screwed, there is absolutely nothing you can do, except use the 360 as a football and punt throw and spike it
Mar 13, 2008 | Microsoft Xbox 360 Console
V.Smile V-Motion Active Learning System Logo
539 people viewed this question
Top V.Smile Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a V.Smile Toy Expert? Answer questions, earn points and help others
