Stand by Hi, I have a 37" Sylvania LCD TV/DVD Combo...when i turn the power on the green light blinks 3 times then it goes back to stand by....any idea what the problem might be?
  • stoughton May 10, 2008
    the DVD doesn't work either.. nothing works on the TV because it has no power...
    Problem Solver:
  • 8 Answers
Is the dvd part was working ok because that may the problem
Posted on May 10, 2008
Visco vsc20v1 will not powers on and right back off
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 22, 2013 | Element Electronics FLX3711B 37 in. LCD TV
Samsung lcd Tv will not turn on. Red power ligth just blinks . No power
Blinks of power light indicates fault. These blinks are called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the number of blinks occur at one time switch ON, and check the site linked here for more details. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 17, 2013 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
I have a Sylvania LC195SLX TV that when I try to power on the "power on" light (green light) flashes several times and then the tv just goes back to the "stand by" light (red light). ...
The power supply is down . Sylvania power is very simple went you take the back off you should see the two bad capsitators on the board.Just replace them with same value .
Mar 01, 2011 | Funai LC195SLX 19 in LCD TV
Tv comes on, green light flashes several times, get the "digital television" shown at botton left corner, then flashing green light stops, tv turns off and red constant "stand by" light comes back on. TV...
common problem with that model is the backlight inverter, 1 or more of the six transformers may be bad.also check for bad capacitors.the tedious way to check is unplug each and plug in each one at a time but unplug the power from the tv each time you check one or you will get a nice jolt. the one that doesnt light the lamp is bad.or take each transformer off and check the primary and secondary coils if you find one open coil. the transformers cost between $8 and $20 each.it has a substitute part.
Jul 05, 2010 | Sylvania LD-320SS8 32 in. LCD TV/DVD Combo
I have the Direct TV RC64 remote and the Sylvania TV/DVD Combo Model LD320SSX. Is there any way I can program this to control the volume and power for the TV?
You can program the Direct TV remote to control your TV by using the below steps:
1. Turn on the TV
2. Slide the MODE switch to the TV position.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
4. Using the number keys enter the 5-digit code (20675, 21268). If performed correctly, the green light under TV flashed twice.
5.Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying the other code.
6. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
For further details and programming procedures and codes, you can download the complete user manual for your remote by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks for using FixYa.
Nov 28, 2009 | Sylvania LD320SSX LCD TV
SYLAVANIA green light blinks a few times and goes back to red
Funai used lousy wire going from the inverter board to the backlight tubes. Look for any wires that are touching each other. The insulation could have broke down between them and started arching. Get some heatshrink tubing to recover the damaged wires.
Sep 20, 2009 | Sylvania LD370SS8 37 in. LCD Television
TV won't turn on Sylvania LC320SL8 - 32'' LCD HDTV
will turn on tv with remote. stays on green for about 1 second and goes back to red.
Nov 11, 2008 | Televison & Video
I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Sep 07, 2008 | Emerson EWL3706 37 in. LCD Television
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
