Question about Frigidaire GLET1031 Top Load Stacked Washer / Dryer
Can't locate Two Thermostats GLET1041AS1 I have front removed from dryer
  • Frigidaire Master
  • 2,605 Answers
Welcome to FixYa.
According to your model number, there will be a safety thermo. on the heater housing ( at the top of the shroud ) part # 3204267
example...
plus a two piece thermo., but really separate components located below the exhaust/blower housing. part #`s 131658100, example 1)
and 3204307, example 2)...the image has two but that is just showing fCan't locate Two Thermostats GLET1041AS1 I - 36995b8.jpg.
Hope that helps you out. Let me know how you make out or if anything is not clear.
Thank you for choosing FixYa.
Good luck.
Macmarkus
Posted on Sep 01, 2010
Fridgidaire GLET1041AS1 need assembly/dissasembly schematic so i can take it apart
Good Morning lzook, thank you for your post!
I understand you are seeking a Parts Manual and Wiring Diagram for your Frigidaire washer, GLET1041AS1. I have located information about your washer on the manufacturer website. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Dec 12, 2013 | Frigidaire GLTF1670A Front Load Washer
My kenmore HE2 is not drying clothes. It turn s on and spins clothes but does not have heat. It is an all electic front loading dryer
If the dryer is not heating at all the three things that you want to check are going to be the heating element, the high limit thermostat and the thermostat. The high limit and the normal thermostat are going to be located on the heating element itself. All of these can checked with a volt meter set to check continuity. To access these depends on if the dryer has a two piece front or a solid front.If solid, Then you will just remove the back of the dryer and the heating element and thermostats will be located on the right hand side as your facing it, If a two piece, you'll need to remove the kick plate and the parts will be located on the right side once again. Just remember to unplug the machine , 220v hurts, trust me.
Aug 31, 2012 | Kenmore Dryers
Maytag dryer runs but will not heat
Sounds like your problem is a faulty heating coil or thermostats.
Unplug the dryer.
Normally if you remove the back of the dryer, locate the air tube from the blower to the drum. The heating coil and thermostats are normally located inside of the air tube.
Remove the wires from the heating coil...Use a continuity meter across the two terminals and check to see that you get a reading of full continuity.
Good luck,
I hope this helps
Oct 05, 2009 | Maytag Dryers
Only warm air, must cycle many times
You problem sounds like you have a faulty heating element or maybe the thermostats are faulty.
If you plan to do the repairs yourself, then you will need to remove the back of the dryer and locate the air tube from the blower to the drum, this is where the heating coil and the thermostats are normally located.
You can test the coil and thermostats with a continuity meter and check function.
Good luck
I hope this helps
Oct 04, 2009 | Magic Chef CYE4000AWW Electric Dryer
NO HEAT
Sounds like your no heat problem is a faulty heating coil or thermostats.
Remove the back of the dryer and locate the air tube that runs from the blower to the drum.
The heating coil and thermostats are normally located inside of it.
I hope this helps
Oct 03, 2009 | Kenmore Dryers
Thermal fuse or heating element problems on a medt236ayw maytag
Normally you will remove the back of the machine and locate the air tube that goes from the blower to the drum...the thermostats and heating element are normally located there.
Sep 26, 2009 | Maytag MDE4806 Electric Dryer
Model# glet1041as1, S/N XE30404473 Dryer will not start. Thermal limiter appears to be good. (0.1 ohms resistance across terminals).
there is also an overheat fuse (not your typical looking fuse) check the circuit diagram on the access panel to locate it. Its not uncommon for them to blow. (under $10 fix)
Aug 16, 2009 | Washing Machines
We have a older kenmore dryer that will run but it is not pushing any hot air out what could be wrong?
Hi, Is this gas or electric?
Test the fuse first. Here is how:
UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. If this dryer is electric, test the element and thermostats while the back is removed.
If this is a gas dryer, the front panel will need to be removed to test the ignitor.
Please let me know if I can assist you further.
Vic
Jun 19, 2009 | Dryers
My amana dryer turns on but wont heat only cold air
you can remove the acess panel fornthlower front, and the heate and thermostats are located on back wall, check for continuty, in hte thermnaostats and heater
Mar 15, 2009 | Amana DLE330RAW Electric Dryer
Unplug unit! Remove top screws and pull off top lid of dryer. Heater terminals should be at top right. Use ohm meter to check resistance. If ohms won't display, then your heater unit probably has an open circuit. For instance, my GLET1031 has a reading of 12.5 ohms.
Sep 30, 2008 | Frigidaire GLET1031 Top Load Stacked...
Frigidaire GLET1031 Top Load Stacked Washer / Dryer Logo
50 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
