I purchased Samsung Sync Master 19" LCD monitor for PC, E1920 NWX 70000:1 contrast ratio last month. But When I started yesterday, when I connected to CPU It working for 10min, after that the screen started blinking, turning ON and OFF and it repeated for 10times. Later the screen was OFF. Now power supply is coming(Blue LED indicating) but when I connected VGA cable, black screen and without VGA cable it is showing "PLEASE CHECK THE SIGNAL CABLE" and showing 4 colours. The monitor turned black when connected to the CPU. What should I do??
SOURCE: Monitor display in blue shade
It may be due to the loose contact of the monitor signal cable
Contact the nearest Repairman
Let me know that your problem is solved and rate me as Fixya!
Posted on Jun 17, 2008
  • 1314 Answers
SOURCE: audio cable for lcd monitor for cpu
A USB cable????? How about just a regular audio cable. Plug one end into the audio input on the monitor and the other one into the audio output (usually green) on the back of the tower.
One just like this.
Posted on Jun 23, 2008
SOURCE: my benq FP567s (lcd monitor) can't show any image
seems many users face same problem
Posted on Aug 26, 2008
  • 62 Answers
SOURCE: green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Posted on Oct 13, 2008
  • 5603 Answers
SOURCE: I just purchased a vga
You have to set the computer to emit the correct resolution for the monitor.
Try setting to 1020 x 768 and see if that works.
Do this in the "display" settings in the control panel of your computer. Also make sure the Sony is set to receive on the VGA port.
Posted on May 02, 2010
ViewSonic VA1926w monitor dims darker when there's dark content on the screen. I have 2 of these monitor connected to a Pro Mac. Only the right side monitor does this.
Its the dynamic contrast ratio (DCR) that dims the display when dark images are displayed.
For my VA1926w, pressing the right most button (up arrow), enables or disables DCR. Keep this disabled.
- Shalabh
Oct 08, 2012 | ViewSonic VA1926w 19-inch Wide LCD Monitor
2333 sw modeline
Samsung SyncMaster
Part Number: LS23CMZKFV/ZA
Product Line
Samsung SyncMaster
  • Native Resolution Full HD (1080p) 1920 x 1080
  • Contrast Ratio
    1000:1 / 20000:1 (dynamic)
  • Color Support
    16.7 million colors
  • Horizontal Viewing Angle
  • Vertical Viewing Angle
  • Brightness
    300 cd/m²
  • Horizontal Refresh Rate
    75 kHz
  • Vertical Refresh Rate
    61 Hz
  • Max H-Sync Rate
    75 Hz
  • Max V-Sync Rate
    61 Hz
Dec 18, 2017 | Samsung SyncMaster 2333SW 23" LCD Monitor
Samsung syncmaster 2433bw , suddenly went out of colour. Tested it with a ps3 but I found a setting that shows me colour .. its the dynamic option under magic colour
Samsung Sync Master 2433BW has the brightness rectangule and monitor menu in one corner of my screen. How I disable/remove that rectangul?
Oct 21, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
Cant get size from display settings for external 19" Samsung Sync Master 931B cant see start button everything to large
See if you can pull up the menu on your monitor. If you can reset it to factory defaults.
If you still can't see the screen properly then you need to on your computer. Go into the device manager and make sure its seeing your video card properly. Look underneath display adapters and be sure its seeing something other then standard display vga.
If not then your display adapters are missing so once you install those, the computer will recognize your monitor.
Dec 18, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Samsung Sync Master 943bw monitor shuts down after a few minutes, behaves as though it is overheating, will only flash briefly if attempted to open immediately. starts again after standing for some...
Mine shut down during my normal working day. Same thing, turn it off and on again - screen flashes up briefly then flicks off again.
Called Samsung and they are replacing it with a refurbished screen under warranty.
Dec 08, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Hi, I am having Samsung LCD sync master 943nwx, after power on momentarily display is coming and going,
it may simply be a lose connection with the monitor cord. or the monitor cord may to be replaced.
Jul 12, 2009 | Samsung 15.3" LCD Monitor
Solution for this problem is to re-set the settings for color, contrast end brightness.
The have had a spontanious reset to 0.
Just go to custumsettings for picture: menu, picture,custom, customsettings and tune up the settings .
voila picture is there again...
greetings H. Huizer
Nov 19, 2007 | Samsung SyncMaster 910MP 19" LCD Monitor
Computers & Internet Logo
570 people viewed this question
David Payne
David Payne
