Question about Frigidaire Washing Machines
E70 flashing at end of wash cycle - Frigidaire Washing Machines
  • 4,323 Answers
Hi
Error code E70 means Cold water hose is connected to wrong faucet or Cold water faucet is not turned on. If this is not the case then check the cold water hose, whether it is kinked or plugged. If the hose is fine then the fill valve assembly has turned bad and you would need to replace the valve. Connect hose to cold water faucet and cold water inlet on washer. Be sure cold water faucet is fully opened. Hope this helps...
Daniel
Posted on Sep 01, 2010
AEG Lavamat 60810 E70 7Beeps Does seem to still work but display shows E50 and some time E70 and 7beeps over and over. Many thanks
First of all, read exactly alarm code.
Press "Spin/Rinse hold" button and "Prewash" simultaneously for at least 2 seconds: the LED switch off and then display the
sequence of flashes indicating the alarm.
The alarm sequence is displayed for the time in which the buttons are hold down. During the time the alarm is displayed, the appliance continues to perform the cycle or, if it is in the
selection phase, it keeps in memory the options previously chosen.
E70 - Family alarm code
  • E71 - Washing NTC sensor faulty
  • E74 - Washing NTC sensor badly positioned
Causes: NTC sensor badly positioned; NTC sensor faulty; wiring faulty; PCB faulty.
E50 - Family alarm code
  • E51 - Motor power supply triac short-circuited
  • E52 - No signal from motor tachometric generator
  • E53 - Motor triac sensing circuit faulty
  • E54 - Motor relay contacts sticking
Causes: Motor faulty; wiring faulty; PCB faulty; current leakage from motor or from wiring
Dado
May 05, 2015 | AEG Washing Machines
Need help with Error Code E70
You could trace the heater circuit from the controller unit please check this link for tips to open the unit.
open control panel
Check heater element
Jul 02, 2012 | AEG Washing Machines
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
It is stopping in the cycle and reading E70 on the screen.
The main cause for this e70 error is that the hoses would have swapped (hot to cold, cold to hot). It means the washer isn't getting cold water.Try to switch between the hoses. Another possibility is the faucets are not turned on.
Hope this solution will fix your problem for sure.
Thank You !!
Jul 16, 2010 | Frigidaire GLTF2940ES Front Load Washer
KEEP GETTING E70 MESSAGE
Are you sure its a E70? If so, the hot and cold lines are reversed.
Apr 25, 2010 | Frigidaire GLTF2940ES Front Load Washer
Stops within cycle E70 is error message
E70 Means that the Hot and Cold water lines are backwards. Switch the lines and cancel out the cycle. Turn the dial to drain and spin and pump all the water out of the unit. Then restart the cycle and it should be fine.
Feb 26, 2010 | Frigidaire ATF6000ES Front Load Washer
E70 ERROR SIGN
Great news that worked!! I had other issues with my washer and had a repair man come and fix it, when he left I started washing and that's when the E70 showed up uhh he hooked the hoses up wrong.. Thanks a bunch
Mar 11, 2008 | Frigidaire GLTF2940ES Front Load Washer
E70 error
May 15, 2009
I had this exact same problem with my Frigidaire washer (E70) as bubbles100. I called an appliance repairman on 5/14/09 and paid him $60 to tell me my hot and cold water hoses were reversed/not properly installed.
This repairman was the cheapest priced $60 and he would work till he found the problem. I had one appliance repair company wanting to charge me $90 for 30 min and another wanting to charge $120 for 30 min. Hopefully this information can help save the next person some money by trying this first.
Feb 16, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire washing machine model LTF2940E
Check your outlet filters, clean out. The machine will not spin if the filter is blocked. Also check your inlet into the machine. Clean screens on both ends of the pipes. Refit carefully.
Nov 30, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
168 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
