Question about Radio Shack Pro-83 Scanner
How do i reprogram scanner ? - Radio Shack Pro-83 Scanner
    Genius:
  • 1,274 Answers
Hi, my name is John. Press the HOLD button,enter the channel you want, press FUNC + PGM, enter the frequency you want including the decimal point, press E to enter...........Hope this was helpful
Posted on Sep 01, 2010
How do you reprogram a Uniden Bearcat BC 340 CRS
Uniden BC340CRS Owner Manual
Resetting the Scanner (Clearing all Memories)
To reset the scanner to factory defaults, turn off the scanner. Then, while holding down 2, 9, and HOLD, turn on the scanner. All scanner memory contents are erased.
May 14, 2016 | Uniden Radio Communications
I can't open the car door with the key, i have to use the beeper but for some reason that is not connecting with the car (03 ford expidition). The car has two alarms, one i turned off with a key...
The key fob battery, the theft module , must be causing the problem.The car not getting open with key, may be key needs reprogramming.-------- There is a battery in a key fob, many a times battery gets weak or dead, causing the problem.But if battery in key fob is already replaced, then theft alarm needs to be reprogrammed by the dealer.The theft system is not letting the car to start.----------- Both key fob and theft module needs to be reprogrammed by the dealer.Its done by a reprogramming scanner.Not a error code scanned, but a reprogramming tool scanner.----------- That will only pin point the problem,if the theft module is got faulty or just needs reprogramming.---------- This will help.Thanks.Helpmech.
Sep 14, 2011 | 2003 Ford Expedition
How to do the relearn/reset after replacing ecm in 2001 monte carlo
DEALERSHIP HAS TO REPROGRAM THE NEW PCM.YOU NEED A GM SCANNER TO REPROGRAM NEW PCMS IN GM VECHICLES THE GM VECHICLES FROM 1996 UP TO 2011 HAS TO BE REPROGRAM AT DEALERSHIP, HOME MECHANIC CANT REPROGRAM IT.YOU NEED GM TECH 2 SCANNER.
Aug 01, 2011 | Chevrolet Monte Carlo Cars & Trucks
Need to replace computer on 2002 chev malibu . What is the proper steps to take in removel
YOU CANT REPLACE PCM AT HOME BECAUSE YOU NEED SPECIAL DIAGNOSTIC EQUIPMENT TO REPROGRAM THE NEW PCM.YOU NEED GM SCANNER THAT CAN REPROGRAM RELEARN CKP AND CMP.RELEARN IDLE AND REPROGRAM THEFT SECURITY SYSTEM.
May 10, 2011 | 2002 Chevrolet Malibu
Scanner quit broadcasting frequency codes lost, how to get them back? How do I re-program the stations I had before. I live near Marietta OHio. The scanner runs the numbers but the weather is the only one...
For a comprehensive database of active frequencies in your area (they're not codes), visit:
www.RadioReference.com
If you need a copy of the manual to assist you in reprogramming the scanner, you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC244CLTom.pdf
Bill B.
Listening in since the 60's
Dec 22, 2010 | Uniden BC244CLT Base Scanner
Reprograming the pro 95 to get the 850.000 band
The linked article below indicates that the PRO-95 and other non-digital Radio Shack scanners are not capable of rebanding to provide coverage of the revised Motorola systems. For more information you should contact your local Radio Shack store.
http://www.radioshack.com/uc/index.jsp?page=researchLibraryArticle&articleUrl=..%2Fgraphics%2Fuc%2Frsk%2FResearchLibrary%2FBuyersGuides%2Fresearch%2FScanners12.html
Bill B
Apr 15, 2010 | Radio Shack Pro-95 Handheld Scanner
Bc560xlt
http://www.uniden.com/pdf/BC248CLTom.pdf
heres the owners manual , it will guide you thru reprogramming and trouble shooting .
Dec 29, 2008 | Uniden BC248CLT Base Scanner
BCD369T problem
You might be able to, if you understand how to reset the scanner's binary CPU board. But honestly, I had the same scanner with the same problem, and one way to fix it is to reprogram the entire scanner's memory. The second way is expensive, send it to a radio repair store. I'd recommend to just reprogram it and see if it works then. If no avail, you might need to have it looked at, but reprogramming it helped my problem. It's time consuming I know, but it worked.
Best Regards,
Gavin93
Jun 17, 2008 | Uniden BCD396T Handheld Scanner
Uniden bearcat scanner
The scanner was probably turned off and it forgot what frequencies were programed into it. Older scanners have a problem with retaining their memory when they are shut off. Most of the older scanners have a memory back-up battery that helps the scanner retain its memory. Check and see if this battery is still good. As for your frequencies, you'll have to reprogram the scanner. To put it in technical terms, some older scanners have what is called RAM (Regency Alterable Memory) and ROM (Regency Organized Memory), when you turn off you scanner, this memory is erased, along with your programmed channels. Be sure not to turn off your scanner unless you're willing to reprogram the scanner.
Apr 30, 2008 | Uniden BC60XLT-1 Handheld Scanner
Radio Shack Pro-83 Scanner Logo
162 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
