Question about Electrolux Epic 6500 Vacuum
The empty bag with a question mark goes on. Why? what do I need to do? thanks
  • 694 Answers
That simply means to check your bag. The symbol actually represents a full bag, so this is telling you it's time to change it.
Posted on Sep 24, 2010
What does it mean when the vacuum electricity light is on but no power and the ? mark is also lit up
The electricity light means there is powewr to the vacuum.The ? means there is not bag or the vacuum doesn't detect a bag.If so there is a little swich that is pushed down when closing the front cover.Make sure it goes down when closing.It is located where the top of the carboard of the bag top...Chris
Jul 11, 2014 | Electrolux Epic 6500 Vacuum
When I turn it on it shuts down in about 3 seconds, bag is empty, no blockages?
Sounds like a bad handle assembly. Unfortunately these are known for being quirky when the circuit board goes bad. There's nothing else to go wrong with the rest of the unit. Here's the part and number. Good Luck
http://vacuummedic.com/product.php?id=389
Apr 20, 2013 | Hoover UH30010COM Bagged Vacuum
Bag is empty but it vaccuum still says bag needs to be checked?
you need to blow out the insides some how like with an air compresser
Mar 18, 2012 | Hoover U5227-930 Elite Upright Vacuum
The unit comes on and the exhaust blows out however no suction at all. l placed a wet vac on the unit where the bag goes and all of the outlets pull some air. The unit is the cv350. Thanks.
there would be 2 things potentially wrong here...
1) the black rubber gasket is missing off the body where the pail goes onto the machine. If that is missing there will be no suction.
2) This is a little more complex but will also lead to the same problem. up above where the bag goes there, is a filter. It could be clogged, but if you are getting a lot of air blowing out of the unit, I think it is more the rubber gasket between the motor and the body. You can check for this by looking behind the little motor pre-filter there (if it is even there) and check the motor intake for the unit. It is probably blocked or partially blocked with the motor gasket. To fix this you will need some weather stripping or another motor gasket.
Good luck.
Mark
Nov 08, 2010 | Broan-NuTone CV350 Performance Bagged...
My vacuum does not start after switching bag, if the little switch is pressed in the light goes on to signal full bag even though it is empty
check your pipes.. if the can be removed clean what you can with cold water little bit of washing up liquid. ONLY.
it really sound like to me its your pipes.
Oct 29, 2009 | Electrolux Epic 6500 Vacuum
13 yr Electrlux.Cuts off if hose plugs in.Says Bag Full-bag empty
This sounds like the valve assembly (full bag control) is faulty or one ov the tubes is clogged. You will have to take it to the shop.
Jul 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
sounds like you have the plastic bodied canister. the controll valve inside is bad. I usually just disconnect those to avoid future problems. you may want to take the vacuum to a repair shop though becuase they are a pain to get apart and get back in one piece.
Jul 15, 2009 | Electrolux Vacuums
New bag signal
Hi
Either the filters are blocked, the hose is blocked or the indicator is faulty
Please leave feedback
Thanks
Rob
Jan 31, 2009 | Electrolux Guardian Bagged Canister Vacuum
Hoover hygiene full bag light is on but the bag is empty
hi,
theres other filters that may be dirty and need to be washed or replaced below or around the bag, study the owners manual for alternate filter locations, basically the machine isnt getting the airflow it needs and is letting you know. The hepa filter is the most expensive, try and run the vac without it and see if the light goes out. Its okay to run it without but I suggest vacumming then dusting, not the other way around..
replace it as soon as possible
J
Jul 11, 2008 | Hoover Vacuums
Emptying the bag
Changing the paper bag...Just rotate the cardboard and pull until it comes off of the fill tube. Note the tabs on the fill tube top and the notches in the cut out circle in the cardboard on the paper bag when reassembling. Try this link for free shampooer directions.....manuals also available.
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope it helps,
Marci
Jun 25, 2008 | Vacuums
Vacuums Logo
122 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
