Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
Ge pdw9880 dishwasher keypad issues - only one mode works\r\ncant change modes - cant enter factory test mode is it the module?
  • GE Master
  • 909 Answers
Yes, it needs replacement. The micom(program) is corrupt.
Posted on Sep 01, 2010
I have a GE NX-6V2 security system which came with the house I bought two years ago. I have not required arming the system until this month. I do not have the user codes or the master code. The security...
can you enter programing mode ?
This manual tells you how to load factory defaults but you need to be able to enter programming mode
http://static.interlogix.com/library/I-NX6V2-IM%20Rev%20C%20Installation%20Manual.pdf
Jul 05, 2017 | Cell Phones
GE DISHWASHER PDW7300N10WW DISPLAY SHOWS RANDOM CODES AND BEEPS CONSTANTLY.
old post. but I am posting here, to help , searchers.
this model has a full computer behind that panel
with service modes and factory test modes.
and a service manual..
try cycling power, (pull main power plug for 5min.)
make sure the drain line is not blocked. (i use a 5 gallon bucket to test my washer drain hose. 2 person, one to hold the hose firmly in his hands , aimed at buck. (the resest button kills all actions)
the beeps are error warnings, covered in the manuals.
there are many beep modes.
even door left open, does that, soap dispenser (option) empty.
the first tests on a PDW, washers, is the rinse, only mode.
when started, it first pumps the sump dry. (old water ejected)
if the pump do dose not start, but humms.. the drain is blocked.
then does a full rinse run. if not make sure the water valves are on.
these models have a Service mode, and a factory test mode
both are covered in the service manual, and allows the manual
testing of each mode and device in the washer.
The turbity sensor can get limed up , so run 1/2 cup of vinegar
in rinse mode. once running.
GE does not offer the serv. manual to DIY, but google does find them, if you search long and hard. "for sure"
is is a generic help page, but do not down load his helper browser bad (jeckle and hyde site) the HTML pages are safe.
http://www.appliancerepair.net/ge-dishwasher-repair.html
Aug 23, 2013 | GE Dishwashers
I have GE Profile dishwasher Model PDW9880 series. It will not drain. We had a repair man come & he said it needed a new control board. Do you think this is true? If so, can I purchase one one my...
Of course you can purchase the part. Module runs around $100. Dishwasher control boards are usually easy to replace, but there's no way I can determine if you're capable of doing it.
Jul 14, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
My dishwasher keypad works except for the up/down arrows for cycle selection. Is it the keypad or the module?
It could be either one. I would try replacing the module first since it's cheaper and if that checks out, your problem is a bad keypad (control board). http://www.appliancepartspros.com/
Feb 09, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
Samsung wave S8500 secret codes
You just need to type the codes using Keypad:
*2767*3855#
Think before you give this code. This code is used for factory format. It'll remove all files and settings including the internal memory storage. It'll also reinstall the phone firmware.
PS: Once you give this code, there is no way to cancel the operation unless you remove the battery from the phone. So think twice before giving this code.
*#197328640#
This code can be used to enter into Service mode. You can run various tests and change settings in the service mode.
*#0228#
This code can be used to get detailed information about phone battery.
*#7465625#
This code can be used to check the status of Sim Lock and Network Lock.
Codes to get Firmware version information:
*#4986*2650468# - SW Version, HW Version, MP, RF Cal Date, CSC Version, CSC Model Spec, FFS Version, RC2 Version
*#1234# - SW Version and CSC Version
*#1111# - FTA SW Version
*#2222# - FTA HW Version
Wi-Fi and Bluetooth Test Codes:
*#526# - Wi-Fi Manual MFG Test Mode
*#232337# - BT RF Test Mode
Codes to launch various Factory Tests:
*#0*# - LCD test
*#0673# OR *#0289# - Melody test
*#0842# - Vibration test
*#2663# OR *#2664# - TM Command
Dec 28, 2010 | Samsung Wave S8500 Smartphone
Switches to "Quick Start" before I enter all information
The Maintenance Mode allows you to query and modify the basic settings of the Star Trac Pro
Stepper.
Engaging Maintenance Mode
Press and hold the0 , 2and OK keys together.
A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information
window.
Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode
The following keys are used to modify Maintenance Settings:
Upper and Lower Data Information Window SCROLL keys: Display the next and
previous settings.
Increase and Decrease Level Keys: Adjust the value of the displayed
setting up and down respectively, in increments of 1 unit.
OK Key: Updates (saves) the value of the display setting in the Flash memory, and exits
Maintenance Mode.
The Keypad Test can be used to verify that all keys are functioning on the display assembly.
To engage the Keypad Test
Enter the Maintenance Mode (see Settings – Maintenance Mode).
Press until Keypad Test is displayed in the information window.
Press to enter the Keypad Test.
Press each key on the display. Each time you press a key, the information window will display
which key has been pressed.
To exit the keypad test, press .
If any of the keys do not respond, they may not be functioning and the display keypad must be
replaced.
Jan 23, 2010 | Startrac Fitness Products Sc4130 Star Trac...
2003 ford futura programming a new keypad
Adding and Removing remote Keypads to the Smartlock module
Up to four Keypads can be programmed and used with the Smartlock Remote
Central locking system.
If you have replaced the BEM, or new keypads are being added to the
system, you will need to train the keypad codes to the module.
# 1. The ignition switch should be in the Off position, with all the
doors shut and Unlocked.
# 2. Turn the ignition key to the ACCESSORY position and within 5
seconds, operates the rear demister switch exactly three times in quick
succession. (IE. Press the switch so the Demister light turns on, then
off, then back on again.)
# 3. After the 5 seconds is up, the door locks will change state, to
indicate that the BEM has entered keypad learn mode.
NOTE : All existing keypads at this point, have been erased from memory
# 4. Press either buttons on the keypad that is to be trained. The door
locks will change state twice, to indicate that the keypad has been
added to the BEM memory.
# 5. Follow step 4. for each keypad that is to be added to the BEM
memory. A maximum of 4 keypads can be added to the BEM memory.NOTE :
You must teach all remote keypads for the Smartlock module, before
proceeding.
# 6. When you have taught all the remote keypads, turn the ignition to
the Off position to leave the learn mode. The door locks will change
state to indicate a return to normal mode.
# 7. Check the function of both buttons on each keypad, to ensure that
the keypad has been trained.
Sep 15, 2008 | Ford Futura Cars & Trucks
Continuous beep after power went off and on
I'm the one who posted on May 23. I tried turning off the breakers and it was still beeped when powered back on. I ordered a new touchpad and control module. When I replaced the touchpad, the beeping was gone, but not all the buttons worked, so I changed out the control module, too, and it works:) I'm going to put clear caulk along the top to prevent spills from leaking through the front panel.
May 15, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
478 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
