Question about Refrigerators
It does not make ice and i have spoken to whirlpool tech's and tried to shunt two leads and check if water will flow. Water did flowed which they said the ice maker is not working and recommended to replace the assembly. I am now looking for the replacement. Am I on the right track?
    President:
  • 1,218 Answers
Good day,
Yes, it sounds as if the ice maker failed. Be aware the freezer must be at normal temperature no warmer than 10 degrees for the thermostat inside the ice maker to allow it to cycle.
If the temp is normal, then replace the ice maker.
Posted on Sep 01, 2010
I have a Whirlpool refrigerator. Model # ET1CHMXKBO3 and it leaks water into the bottom of the refrigerator. Water also freezes on the bottom of the freezer compartment. I checked for a clogged hole o
When your refrigerator defrost the water runs into a drain pan in the bottom/underneath the refrigerator, You will need to first unplug and remove contents from freezer and proceed to remove the air tower in the center of the back panel, underneath the evap. coil in the center is a hole that leads to the drain and it is iced over and the water is not able to flow.What i do is get a hair dryer (be careful not to melt the plastic) and defrost/melt the ice. You will need a towel to start and once you think you have the ice removed get some hot water and pour in the trough to make sure it flow's to the drain pan. When the flow is good put the part's back and make sure the refrigerator is level from side to side and slightly tilted towards the back (front to rear)!
Dec 24, 2013 | Whirlpool Refrigerators
I have a whirlpool gold refrigerator, it is still making ice but no water coming out of water dispenser? Filter has been checked ok any answers?
Hello Jane
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable.
Best Regards
Neciforo Llanto
Sep 21, 2013 | Whirlpool Refrigerators
No water no ice
Change the=> 67006531 Water Inlet Valve I believe the side of your 67006531 Water Inlet Valve that controls water flow to the ice maker has weakened and cannot open properly. Replace the water valves and I believe the ice maker will work fine, Sea Breeze
Jun 07, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Low water flow from "ice magic plus"
Have you tried replacing the inline filter? and if you have remove the filter and place a large bowel next to the water line and open it up and see if water flows from the line, if it flows fast then it's a problem with the fridge if it folws slow you have a problem with the water connection. Check that can get back to me if you need more help.
Avid101
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator side by side
hi. thanks for the question. To see if the problem is with the water valve, or ice maker. remove 1 wire from water valve ,at the back . now turn on the water . if water still flows. replace the water valve . if not replace the wire and try again .if flows replace ice maker. thanks the appliance doc
Sep 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Icemaker - hollow or solid ice, take your pic!
check behind the bottom front panel, mine has instructions for changing the water flow. If the instructions aren't there try your manual or an online one.
Jun 11, 2007 | Whirlpool GC5SHEXNS Side by Side...
No water or ice
ALWAYS CHECK FROM THE WATER SUPPLY LINE TO THE WATER SOLENOID VALVE ... TO ENSURE THAT YOU HAVE GOOD WATER FLOW ... IF WATER FLOW IS GOOD, SHUT "OFF" VALVE. THEN YOU CAN CHECK WATER SOLENOID VALVE STRAINER AND ORFICE TO SEE IF IT IS CLOGGED. (USUALLY LOCATED BEHIND FRIG.... INSIDE THE INLET SIDE OF THE VALVE THAT REQUIRES YOU OR SOMEONE TO REMOVE THE SUPPLY LINE BRASS NUT. (IN SOME CASES THE FITTINGS ARE NEOPREME) CREFULLY REMOVE THE STRAINER AND ORFICE ASSEMBLY ... IT IS SMALL !!! (CLEAN THEM THROUGHLLY). REPLACE ALL PARTS THE WAY YOU REMOVED THEM.... TO CHECK WATER SUPPLY SOLENOID OPERATION EASILY ... JUST USE A "METAL BUTTER KNIFE AND HOLD IT ABOUT 1/4" FROM THE TOP OF THE VALVE ... YOU SHOULD FEEL THE MAGNETIC PULL IF IT IS GOOD. LASTLY LOSEN THE NUT ON THE SIDE OF THE VALVE THAT LEADS INTO THE FRIG. TO CHECK FOR WATER FLOW. IF YOU HAVE WATER ... THEN THINK ABOUT CALLING A "LICENSED FACTORY-CERTIFIED COMPANY TO GET A "FLAT-RATE DIAGNOSTIC CHECK". UNFORTUNATELY THOUSANDAS OF CONSUMERS ARE BILKED BY SO CALLED FIX-IT-ALL HANDYMEN WHO LOOK TO REPLACE PARTS THAT CAN COST YOU HUNDREDS. NO WATER ??? NO ICE !!!
Apr 23, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
