Question about Brother Office Equipment & Supplies
Have a dcp8020. Went to copy document and it said to put the doc. cover down. looked down to me. went to lift it and put it down again [gently] when the cover just lifted up. seemed to rise up on the right [hinge] but completely separated from the left. 2 plastic pieces exposed on the left that look like thet should be pressed down. had to push black button on left side in to get it to copy. cover still misalligned. what do i do?
  • 4,924 Answers
I think those plastic hinges are removable ..just lift the lid up in a 90 degrees angle with the printer face ..and try to insert them both in the same time ..it has a snap in kinda action ...and after that close it ..
Posted on Sep 01, 2010
Like many other people I have a vertical line down the copy, using the document feeder, not the plate glass. on my HP officejet J5780 3 in one. Your advice is to clean the small glass plate. I look...
I dont have a picture at the moment but if you lift the document feeder up to expose the large plate glass, the small plate glass is normally situated at the extreme left hand side of the large plate glass.
May 29, 2011 | HP Officejet J5780 All-In-One InkJet...
Interior bulb went out , and it's an over the counter mount. How do I get to the bulb ?
Remove the top grill cover by gently pulling out on it and down on the right side. Remove the filter that is in the middle. Look at the metal cover, push back on the plastic tab and pull the metal clip toward you. You can now gently lift the cover off expsing the lightbulb and replace it. Simple and easy, no tools needed.
Dec 13, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Keep getting a "check original" message on screen - won't fax or copy
the check original relaates to the document you are trying to copy or fax check the guides for the document input and check you are putting teh doc in far enough yuoo can also lift the cover and check there isnt any obstruction .. basically the sensor that lets the machine know you have a doc on the go isnt getting actuated to start the process..try and put a thick piece of card in the doc feed part to see if it goes through it might push through the obstruction
Aug 05, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
I put a new black ink into my printer it seemed alright, then when I went to print a document it made a strange noise and the green light went out and the red light went back on. I have tried pressing the...
the cover over the cartridge was not closed properly is my guess - was the noise like a grinding sound? - if so, it was the toothed drive belt jumping teeth on the drive roller.
Turn off power to the printer and GENTLY pull the cartridge carriage back t the center using the drive belt. Next remove and re-insert the cartridges and make sure the cartridge cover is down and locked.
Nov 18, 2008 | Epson Stylus C46 InkJet Printer
Black line on copy
Have you try to print with other tray also. Is it fine.
Your printer need cleaning of the roller, just open the cover and try to clean all the dust and ink.
Regards
ELLIN
Sep 23, 2008 | HP LaserJet 3330 All-In-One Printer
Error msg..."close ADF cover". Where is it?
Adf : auto doc feeder
the top that you put the pappers in to copy mare than one sheet.
make sure all doors are closed.
lift doc feederas if making copy on glass look where the hinges are there should be a plunger next to one of them, that is the switch to tell it if it's open or flat. try pressing it down to see if message goes away, it may need adjusting.
Jul 15, 2008 | Ricoh Aficio 1013F Copier
Brother MFC 8420-- hinge?
i went to Brother site and opened support.
searched for parts and got a listing of technical support shops in my area. called the first one listed and asked if they had the LP2403001 hinge in stock and they came back with an affirmative answer. will pick it up this afternoon locally.
You can see an image of the hinge assembly at ebay if you search for LP2403001.
Regards,
David
Jan 25, 2008 | Brother DCP-8020 Laser Printer
Doc cover open
Yes there is and I know your problem have a look at the left hinge on lid that you lift to put down an original for copying, it will be breaking apart, the switch is black in that same corner on doc feeder base, as the hinge breaks apart the doc feed lifts in that corner causing "doc cover open" cause that switch no longer gets pushed in when lid is shut
Dodgy repair - tape switch closed, but doc feeder will not work properly/can use glass.
Repair - Easy removal of three screws and replacing 20buck hinge bought from brother dealer...part no.LE8731001 Hinge assy left.
Now that's FIXYA!
Nov 19, 2007 | Brother MFC-8440 All-In-One Laser Printer
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
