Question about Samsung Washing Machines
My washing machine model 8204 semi-auto is having problem of water leakage through the drainage at very low pace taking 2-4 hrs . what to do? plz suggest.
  • 909 Answers
You need to raise the drain pipe up about 250mm to stop the water siphoning out. When it is high, the flow will stop untill the pump tells it to come out.
Posted on Sep 01, 2010
Error 15 in BOSCH dishwasher model sms69m18gc
E15 error code indicates that there is water sitting in the base of the dishwasher.
Most common reasons:
  • malfunction of the water drainage sensor when the aqua-stop worked
  • the system is clogged
Mar 11, 2018 | Bosch Washing Machines
During wash machine keeps either beeping displaying E10 or automatically pauses. We have checked the filters with no blockages identified. Drainage hose is not low so water is escaping.
if LG:
ERROR DISPLAY [E I ] Leakage error. Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
Apr 01, 2015 | Washing Machines
My washing is saying error 2
E11 is low water pressure
E12 is a slow drainage problem
E13 too much water
E31 motor problems
U02 is cannot lock the door after 20 seconds
E22 is memory failure
what exactly does the error message come up with and when does it occur
Feb 24, 2011 | Haier HWD1000
Washer does not drain water
The major reason for this to happen is the clogging of the drain pipe of the washing machine. If, even after you clean the drainage hose, the problem persists, there may be other problems.
Next possibility could be that the drainage pump which drives the water out of the drainage hose may be clogged! So, remove the drainage pump and clean it. That should solve the problem. it might also be that the belt of the drainage pump motor may have loosened. If this is the case, you have to simply tighten it.
Take care.
May 30, 2010 | Whirlpool LSR5132PQ Top Load Washer
Water leakage after cleaning lint trap
make sure that when you replace your filter that there is no obstruction in the filter thread(small stone), i have had many problems with this,if the drain light keeps comming on then check the waste pipe stand.
Apr 07, 2010 | Miele W1926A Front Load Washer
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Takes forever to do the laundry
If it is taking forever to fill, take the water hoses off the supply and check for clogged filters. Also, if you have low water pressure in your house, or old clogged pipes, your water is running slow.
Mar 18, 2009 | Bosch Washing Machines
Washing Machines Logo
44 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
