Question about Pioneer DEH-P3900MP CD Player
RCA Pre-Out Making Producing a Mumming and a Popping Sound.
The unit sounded o.k. for during the first six months of use. Just recently, mostly when I first start the car the subwoofers connected to the amp starts to hum and pop in a rhytum. I tried new RCA cables but that didn't work. I have a 2002 Nissian Altima. The humming sounds simular to ground loop, but my ground cables to the amp are of proper gage and are no longer than 20 inches. Is it because of the negative ground factory speakers that came with the car ?
If you have this humming sound, try to ground the rca to your car body ground. that will do the trick...
Posted on Jul 11, 2008
    Genius:
  • 1,224 Answers
The speakers hook to speaker wires not to any thing else no power no negative poles do you have a remote shut off switch connected to amp this would be important to cut off amp
when cut off amp if you still here the humming this can be an indicator of low power being produced by alternator alternators produce 14 anything below 12 would mean replacement of alternator
if alternator fine then you need to find new ground for amp and make sure you have a good ground for sterio this can be checked with a test light
to check a ground all you do is hook gator clip to power then touch test light end to ground on radio end light comes on got a good ground (make sure not to touch any other sterio wires just the ground wire while connected to power to check grounds)
if pulsing in test light on the ground means you have a bad ground
just disconnect move to better ground
check the amp ground the same way as decribed above
Posted on May 09, 2008
I recently purchased 4 K 22 soundboard for myself and my son and daughter.
i will put a pic here on how to connect the 2 tv-s
capture-wwsozecm2jr4f23puaylicsu-2-0.png good luck!!!
Apr 11, 2017 | Samsung Televison & Video
Why do my pitco fryer have excess soot and keep making a loud popping sound.
Hi There.
Check and ensure that the unit receives correct gas pressure during operation as written on nameplate; make sure that the unit also has the correct orifice size for the type of fuel currently used.
Regards.
Sep 14, 2014 | Pitco Frialator Kitchen Appliances -...
My Sunfire MKll is making a popping/rattling sound during some low frequency notes, the sound is coming from the left woofer when facing the amplifier board ( its the softer woofer of the two, but...
The passive radiators on those are notorious for coming apart inside and making a knocking noise. You can sometimes glue it back together but youll have to remove the driver from the cabinet.
Jul 30, 2012 | Sunfire True Sub MK II Subwoofer
Mixer is still going but making a popping noise. Also has a burning smell - maybe a wiring problem?
HI.When the stand mixer produces a popping sound during mixing this problem has something to do with the motor.Motor has bossing on it.This might not be lubricated well and eventually lossen up.That's why it produces a popping sound.And with regard to the burnt smell might be on the coil of the motor's rotor or armature.Is the unit still functioning eventhough you smeeell burnt wire?Thank you for choosing FIXYA..
Jul 22, 2011 | Kenwood KM305 Stand Mixer
My amana dryer is not turning .it is making a mumming sound
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 25, 2011 | Amana Dryers
Outside Unit blowing air but not cooling and slight buzzing sound
The compressor is not coming on and some part of that unit has failed. Do you hear any clicking sounds along with the buzzing sound? Recommend that you shut the unit down (remove power from it) until a service tech can listen to it try to start up.
The power company-installed load management system is probably a red hearing. That system will either fully turn off the unit or allow it to turn on/start up.
May 08, 2009 | Heating & Cooling
Humming sound
the old color wheel on models pre 06 have bearings. The new replacement dosn't. The noise you here is the bad bearing. Mine got so loud I couldn't take it anymore. Just replace and noise is gone! I did mine myself. Not that hard.
Dec 21, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Tv has sound but no picture
my rca hd model hd50lpw164 has no picture. some sound and a electrical popping noise.
supect the lamp is out.
where can i obtain new lamp and whats the cost.?
david
Nov 20, 2008 | RCA HD50LPW165 50" Rear Projection HDTV
Poppng sound and flashes on screen
The Blu-Ray will not cause this problem and in my experience the popping or arcing is coming for the ysus, zsus, or one of the buffer drive bds. When I hear this complaint it is normally not long until a loud pop is heard and the unit will go dead. Most times the ysus bd fails, sometimes the zsus bd and sometimes both.
Feb 09, 2008 | LG 42LC2D 42 in. LCD HDTV
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
Pioneer DEH-P3900MP CD Player Logo
282 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
