Question about Dryers
The dryer ignites initially but in automatic or timed the gas valve will open(you can smell gas) when it goes into cooldown mode
  • deon11 Sep 01, 2010
    The gas smell is enough to smell outside through the vent. If I disconnect the cooldown tstat it recycles fine.
  • 10,319 Answers
Moister sensor at fault or bad gas regulator
Posted on Sep 01, 2010
  • Dryers Master
  • 12,061 Answers
Hi, sometimes when a gas appliance turns On or Off there may be a slight amount of unburnt gas either before or after, the flame lights, this minuscule amount however, has an enormous amount of area it can cover and the gas has been treated with an Odourent to alert people to leaking/the presence off, gas, however, unless the smell builds up, then you most likely have nothing to worry about, it is just that, tiny amount you smell.
However if you are at all worried, you should turn OFF the gas, each time you finish with the unit. This little inconvenience is well worth the trouble for the peace of mind it brings.
Samsung gas dryer
Nothing to worry about . The problem you had was there was air in the line. Here's how it works. The igniter heats up then the gas valve opens. You had air coming out so it did not light initially . The air was followed by the gas supply but at that point the igniter was already cooling down. When you tried a second time the gas line was purged of all air hence normal operation.
happy drying.
wayne
May 06, 2014 | Dryers
Dryer works fine but i smell gas when it first comes on then goes away and the smell is only outside
Any gas operated divice will have some gas odor when it ignits, because not all gas is vaporized during the initial combustion. BUT check to make sure that your exhaust hose is clear, so that unburnt gas goes outside your living area instead of inside!
Jan 02, 2012 | Whirlpool R 850 RT Dryers
I have a Maytag LDG 4000 gas dryer with electronic ignition. The igniter glows, but does not ignite the gas. I can not smell any gas, so I'm assuming a valve of some sort, internal to the dryer, is not...
Igniter glows - No gas ignition. If the igniter heats
up but the main burner flame is not ignited, remove
power and using an ohmmeter, check the following:
• Open secondary coil
• Open holding coil
• Open wire harness
• Stuck flame sensor (Stuck closed)
Most likely bad gas valve coils.
Sep 07, 2010 | Maytag MDG4000 Dryer
Smelled mild gas odor after moving dryer. Replaced gas line connection. Still smell gas. Tried to tighten gas line have strong gas odor after running dryer. Does not seem to be heating
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
Jan 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas Dryer igniter glows but does not ignite
If the igniter goes on but only cycles off you have a bad solenoid coil on the valve you can pick them up as a set at a local parts supply shouldn't be more than $25
Sep 04, 2009 | GE DDC4500S Gas Commercial Dryer
Maytag MDG5500AWW gas dryer with inconsistent flame
the booster coil gets hot and stops working just replace all three and give me thumbs up...i get$60 for a house call
Aug 08, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer worked well until recently. Igniter glows
I would take a look at the gas coil solenoids. The gas coils are right above the gas valves. They are black electrical coils. When energized, the coils open the gas valves. If one or more of the coils is defective (bad solenoids), then the gas valves won't open and the gas cannot ignite. Because it's difficult to test the coils, it is best to replace both (all) of them at the same time. Sure hope this helped and best wishes.
Jul 28, 2009 | Dryers
Dryer start up fine then the gas turns off as ignitor continues
Hi Jim. Perhaps this will help you.
The burner assembly consists of the gas valve, the igniter and sensor, and the thermostats. The gas supplied to the appliance is turned on and off by the gas valve, as follows:
  • First--when you close the dryer door, set the timer, and press or turn the Start button--the motor starts. When it reaches full speed (in about a second) a switch on the motor turns on, which allows the electricity to flow through a simple thermostat to one side of the gas valve.
  • The gas valve then sends power to the igniter, which glows bright orange.
  • As heat and light from the igniter warm up a sensor that's right next to the igniter, the sensor circuit opens, then supplies power to the other side of the gas valve. This completes the circuit and opens the valve.
  • Once the valve opens, the gas rushes out and the igniter ignites it. As the gas burns, it keeps the sensor warm, which keeps the gas flowing.
  • When the dryer reaches the pre-set drying temperature, a simple thermostat turns off the flow of electricity to the gas valve and therefore turns off the gas.
  • When the temperature in the dryer falls about 20 to 30 degrees, the thermostat again allows the electricity to flow through to the gas valve, and the cycle starts over.
If you selected the Automatic setting, the cycle continues until the clothes are dry, then the timer advances and turns the dryer off.
If you selected a timed setting, the cycle continues until the time has expired, then the timer turns off the dryer
Jul 27, 2009 | Dryers
Gas valves open but gas will not ignite
I need the serial # to better assist you .
thank you
May 13, 2009 | Kenmore Dryers
Internal gas leak with Maytag Neptune Dryer.
start the dryer,go outside where it vents if you smell gas outside and only smell it inside when the dryer is running you have a bad gas valve on the dryer and most likely the valve will fail and you won't have any heat.the valve can get noisy too it will chatter when trying to let gas in if you remove the four screws that hold the door on and opposite the door screws but don't remove the door just remove the front panel you can start the dryer to see what's going on in there,i mean you have an igniter and gas coils but i've never seen a coil or igniter do this they either work or they don't so if you smell gas outside where it vents i'd go with the gas valve is bad.usually if you have bad gas coils the coils will work until they heat up and then no flame,when they cool down they will work again but i never smelled gas and the igniter will work or it doesn't not like an oven igniter they can glow but not ignite the flame and you might get a wiff of gas,i think you have a bad valve,you can get a shop vac and vac out around the burner tube and then blow it out with vac and clean out the inside of cabinet so you don't have a fire this should be done at least once a year,unplug it before you clean it out,blow out all around the gas valve sometimes a spider can make a web in there and block the orifice,write back and let me know what you find thanks and good luck.part number is WP306176 on some models you might have to get a pair of tin snips and open up the metal cover that the valve slides into they made the nut bigger for some reason and it doesn't fit through the metal cover unless you cut the cover to make hole bigger lol gotta love it.
Jan 12, 2018 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
