Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
We smell burning electronics at the back of the fridge. unplugged it don't know what to do now.
    Brigadier General:
  • 3,917 Answers
Frgidaire Side By Side Burning Smell
Most burning smells in refrigerators comes from the compressor overheating due to the overload relay going out . Unplug the fridge before the compressor burns out and take the model number to appliance store for a new relay. The relay is located in the back of the fridge inside the lower back panel.
Aug 03, 2012 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Jul 25, 2012 | Whirlpool Refrigerators
I have a 1990s JVC tv that we were wattching the other day then we smelled a smoky smell. Then horizontal lines and staticy sound started to go through the tv. We tried canned air to clean the vents a few...
That tv is very close to catching on fire. UNPLUG IMMEDIATELY. When electronic equipment is old they dont just stop working sometimes. Sometimes the electrical current starts burning the wires and the dust inside. there is a definare odor to electronics burning or shorting out. smell around the air vents in the back of the TV. youll know if wires were burning its a distinct odor
Jun 03, 2012 | JVC Televison & Video
Fridge made a burning smell, and now makes a Tick, Fan runs on...
Sounds like the start relay has become bad/defective and it should be unplugged until we can have a look at it closer to see if possibly something other than the start relay is the reason for causing this failure. Depending on your model number a defective defrost control board or fan could start this cycle of damage to the compressor start relay and compressor if not unplugged until repaired. Please see if you can find the model number and I will be able to tell you more about the cause and assist you in the repair, Thanks, Sea Breeze
Apr 25, 2010 | KitchenAid KSRA22CN Side by Side...
Maytag fridge trips circuit breaker
replace the ptc overload relay on the compressor,it merely unplugs,it supplies start and run power to the compressor and if its bad it will allow the compressor to operate on the start windings too,and draw a lot of current
Apr 06, 2010 | Refrigerators
Foul burning odor
you could possible be right on if your frig has an electronic disp control put your nose their and sniff if seem close to what you earlier smelled you solved your problem pcb control '
Aug 20, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Amana bottom freezer has a burning smell coming from the back of it. Fan is still working.
Is this burning smell occurring during a defrost? Something, like a food particle or wrappping, could be burning while in contact with the defrost heater. Is the burning smell coming from within the freezer? If it is coming from the outside and back of the box, unplug the box and investigate, or call a technician. You may want to call a technician, anyway? We don't need house fires.
Jul 07, 2009 | Amana ASD2326HE Side by Side Refrigerator
Burned electrical smell from the freezer compartment
I would check the defrost thermostat usually a button type switch with 2 wires on it mounted to the freezer coil. Size depends on type ; 1 type is about quarter size, 1 is about dime size, and electronic sensor (not had one burn out but the board could smell like your description but I believe these are not in the freezer section).
I have had these cook out and smell up the freezer section before. And if they go out guess what it wont defrost either. If your fan motor goes out it might smell and wont cool all over but the frost should be minimal.
Also a bad defrost heater could make a smelly situation it is usually a black rod or aluminum colored and the rubber ends can burn and make a smell.
If you find its the heater, I would replace the defrost thermostat as well. Its suppose to cut off the heater before it gets too hot.
If this helps you find your problem please rate me as high as possible if not please post back with more information as to what you did find. Thanks for using fix ya and good luck.
Mar 29, 2009 | Kenmore Refrigerators
Burning Rubber smell coming from fridge
try taking the bottom panel off and vacuming all the dust on the coils. The dust may be heating up and burning. The coils are usually at the bottom of the fridge. Check to see if the fan is running also.
Jan 16, 2009 | Refrigerators
Burning Smell
sounds like the motor is fried or seized up, which would explain that smell.
Feb 17, 2008 | Refrigerators
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
103 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
