Question about GE WBSR3140DW Top Load Washer
We own a GE hydrowave , model number stated below, When a cycle is selected, the washer fills, but it does not agitate.The water runs out of the washer, but it does not spin dry in the time it should, as a matter of fact, the drum remains stationary. you cannot hear any sounds of strain or anything like that. No sounds or grinding or anything of that nature. The washer is just about one year old.
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
hiltonjug
  • 612 Answers
SOURCE: ge profile washer WPSR3100W1WW won't agitate
I see this pretty regular. You have a bad transmission. This is very common with the older GE's. To replace the transmission will run around $340 / $400. Not sure about your area. Just be glad you got this much use out of it, you are one of the very few that have. From 1998 till 2007 I owned my on repair company where I did GE's warranty work in my area for them. During that time period. When I found a GE washer under warranty doing what you are describing. GE would warranty the whole machine. They would have me destroy the machine after I would deliver the customer a band new one. GE knows they had a bad transmission and it cost them a lot of money. It was cheaper for them to replace the washer than have me repair it. The transmission list price was $298.00 back then. A word of advice, when you replace it. Buy a Whirlpool, Kenmore, Maytag. These brands hold up the best. I have the least service calls for Whirlpool and Kenmore. Both are made by the same people. Kenmore is made for Sears. Good Luck.
Please rate this solution if helpful. Thanks
Posted on Aug 21, 2009
  • 121 Answers
SOURCE: GE Washer Model WJRR4170E4WW squeaks while agitating
There are four suspension rods that the tub hangs on. When the washer is agitating the tub will rock back and forth and the rods will move back and froth as well. To fix this noise, lift up in each rod and put some lubricant in the cup that the rods fit into at the top of the washer.
Note that it is best if you use a lithium-based lubricant rather than silicone based lubricant.
For more on do-it-yourself appliance repair help visit http://www.appliance-repair-it.com/index.html
Posted on Sep 17, 2009
Testimonial: "shawnryan111, thank you for a great suggestion. That did the trick and the machine runs much more quietly. Thank you for the assistance. Regards, Les"
SOURCE: drum won't agitate or spin what do we do?
have the belt checked :)
Posted on Nov 26, 2009
GE Hydrowave top loading washer is leaking around the top side and back of unit when filling.
check for the water outlet from the water solenoid control valve
it may be displaced or broken and not directing water to the bowl
Sep 29, 2016 | GE GTWN4250MWS 27" Top-Load Washer, 3.7...
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Top Loading Hydrowave. Washer fills but won't agitate. After a few minutes water is pumped out and it spins normally.
It almost sounds like the lid switch is working backwards but I have never seen that happen on a GE. The switch either works or goes bad. One other possibility is a defective water level switch. Thats also called a pressure switch sometimes.
Apr 17, 2015 | GE Washing Machines
My Ge Top load washer will not power up start button?,no lights.
Their is a fuse in the harness red wire that runs down from the control to the motor on the hydrowave washer. Hydrowave washer manual
Of course if yours isn't a hydrowave maybe you oughta post a model number. GE has several different styles.
Mar 09, 2013 | Washing Machines
How to remove agitator from GE washer? Model WHDRR418G1WW.
how to remove agitator from GE hydrowave washer machine?
Feb 27, 2010 | GE WBSR3140DW Top Load Washer
No agitation in ge hydrowave rinse cycles
you must unplug the washer for just 1 minute open and close the lid 10 times and plug it back in and put it on a light load cycle and let it wash with empty load. shoul work fine after that
Dec 01, 2007 | Washing Machines
GE WBSR3140DW Top Load Washer Logo
54 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
