Question about Logitech Harmony One Advanced Universal Remote with Color Touch Screen
Harmony one just shows go to website and update settings, after i went into safe mode and reinstalled firmware and updated settings
SOURCE: my harmony is stuck in safe mode
I had the same issue this morning so my apologies for the delay in answering you. After numerous delays and frustrations in being unable to "update" my remote i did the following. First, remove all batteries and disconnect remote from the USB cable. Check ALL buttons to ensure that none are stuck in the down position. I found that my SELECT/OK button was stuck in the "on" position. Continue to check all buttons to make sure all test fine. After doing this hold down the "Off" button while connecting the USB cable, still no batteries in the unit at this time. Hold the "Off" button down for at least 10 seconds or until the units Testing is completed. If the Harmony remote software is up, perform the Update Remote step still sans batteries. After it completes it may perform a self test again (mine did) and after it completes then insert the batteries back into the unit. Hope this helps.
Posted on Dec 26, 2008
  • 22 Answers
SOURCE: Harmony 1000 in safe mode?
The harmony remotes have a built in safe mode, similar to a Windows XP computer. Usually you enter the safe mode on the harmony remotes by taking the battery out, then pressing the power off button and holding while putting the battery in. If you continue to press the power off button, the remote will display safe mode on the screen.
If you are not doing the above procedure and you are still getting the safe mode on the display of the remote, I would try to update the firmware on the remote. And if you have an RF Extender, update the firmware on it at the same time.
Hope this helps,
81
Posted on Dec 29, 2008
SOURCE: display shows "Harmony safe mode" and will not respond/turn off
remove one battery. press and hold the #2 while replacing the battery. hold the #2 until you see "upgrade success". press activities and you're back in business.
Posted on May 02, 2009
SOURCE: Logitech Harmony universal remote stuck in safe mode
Just a message to all that have problems with there Logitec remotes. My remote went into something called a "safe mode" when my partner changed the batteries while holding the power button.... I pressed every single button to try and get out of it but nothing seemed to work, (I was getting pretty frusterated, there is nothing in the manual to tell you how to fix this problem), however, I have now learnt that as you replace the batteries you need to have the number 2 button held in as you replace the last battery. This works 100% so if you have any trouble with the "safe mode" then this is what fixes it.
Carly.
Posted on Aug 26, 2009
Testimonial: "Worked like a charm"
  • 86 Answers
SOURCE: harmony 550 in safe mode
Hi There,
To get out of safe mode, do a firmware update from your PC. This will install the latest firmware and your configuration. Safe mode is a bootstrap designed to recover from firmware corruption issues so about the only thing it knows how to do is reload firmware.
However, if the remote fails to communicate with the PC when it is stuck in Safe Mode, please try the following.
1. Remove the batteries from the remote & check for any stuck buttons especially the Power button that may be causing the remote to stay in this state.
2. If it still will not apply firmware to get out of safe mode, then still without batteries hold down the #2 button while plugging into USB, and it should exit Safe Mode, and say something similar to 'Firmware Upgrade Success'. Even though it says this, still perform the Firmware upgrade since it was stuck in Safe Mode to begin with.
Posted on Aug 29, 2009
Put in new batteries safe mode appeared cannot use remote
Hi. Safe mode is just the remote protecting itself from either a power surge or corrupt firmware. All you need to do to get the remote out of safe mode, is update the firmware.
1. Launch the Harmony software and log in to your account. 2. Connect your remote to the computer. 3. Click on the downloads link at the top of the page. 4. Click firmware. 5. Once the firmware is done updating, update the configuration by clicking "Update Remote."
Hope this helps
Jul 25, 2011 | Logitech Harmony 670 LCD Remote Control
Tip
Logitech Harmony Firmware Update Would you like to upgrade / update the...
Would you like to upgrade / update the firmware of your Logitech Harmony Remote?
To upgrade or reapply the firmware on your Harmony remote:
  1. Launch the Harmony remote software and log into your account.
  2. Click on the Downloads button at the top-right corner of your screen.
  3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote.
  4. Once the firmware upgrade is complete, click on the Update Remote button.
Your Logitech Harmony has now had its firmware updated.
I hope that helps.
__________________________________________
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
on Apr 27, 2010 | Baby Care
Tip
Logitech Harmony Safe Mode Fix Is your Logitech Harmony Remote stuck in SAFE...
Is your Logitech Harmony Remote stuck in SAFE MODE?
If you upgrade / update the firmware of your Logitech Harmony Remote, your remote will no longer be in SAFE MODE.
Your Logitech Harmony has now had its firmware updated, and is no longer stuck in SAFE MODE.
I hope that helps.
____________________________________________
on Apr 27, 2010 | Televison & Video
What is "Safe Mode?and how do I get this off my remote? It is completely not working. The Activities button is light up and it simply says Harmony Safe Mode.
1. Remove the batteries. While holding the 2 button down, connect the USB cable. The remote will boot into normal mode.
2. Update the firmware. Update the configuration. If you are unsure of how to do this, please see below.
- Upgrading/Reapplying the firmware on your Harmony Remote
- http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747
3. There could be a stuck button on the remote causing the symptom. Remove the batteries from the remote. Push in, and massage each button ensuring it is not stuck down. Replace the batteries and Update the firmware. Update the configuration (update the remote).
4. Remove the batteries from the remote. Manually place the remote into `Safe Mode` by holding off and plug in the USB. Upgrade the firmware in the remote. Update the configuration (Update your Harmony remote).
May 06, 2010 | Logitech Harmony 520 LCD Remote Control
LCD doesn't display anything. Removed battery and reinstalled. No success. Is there a reset process?
try these steps to fix the problem your experiencing with your LCD. most of the time this will work.
1- Remove the battery from the Harmony Remote for 10 seconds and insert it back in, and test the remote to see if the screen is displayed properly. If this does not fix the issue, please proceed with the following steps.
2- Make sure you have the latest Logitech Harmony Software (version 7.6.0) installed on your computer.
3- Connect your Harmony Remote to the computer. Run the Logitech Harmony Remote software on the computer and Login to your account.
4- Click on the "Downloads" button at the top and select "Firmware"
5- Remote will go through the firmware update, which will put the Harmony Remote back to Factory Default with the most updated firmware. Then software will ask you to select "Yes" to update the remote and click on "Next" to do a remote update, which will take the information on your account with your Devices and Activities and bring them into the Harmony Remote.
6- If this Firmware Update process does not fix the LCD screen issue, try doing a Firmware Update in "Safe Mode". To do this; remove the battery from the remote, press and hold the "Off" button on the top of the Harmony Remote and insert the battery back in to the Harmony Remote. Screen will display "Safe Mode" and then please follow the steps 3 through 5 again.
Jan 14, 2010 | Logitech Harmony 670 LCD Remote Control
Tip
I hope that helps.
NO LCD DISPLAY
Jan 09, 2010 | Logitech Harmony 670 LCD Remote Control
Changed the batteries and it went onto 'safe mode!'. Any ideas?
Hi. Here is how to get your remote out of safe mode.
1. Connect your remote to the computer.
2. Launch the Harmony Remote Software, and log in.
3. Click "Downloads" at the top and click "Firmware"
4. The remote will go through the firmware update.
5. Select "Yes", and click NEXT to update the remote.
Voila! Hope this helps.
Sep 26, 2009 | Logitech Harmony 525 LCD Remote Control
Safe mode!
I can help you with your Harmony One Remote Control.
Replacing the firmware in your Harmony One is the way to get it out of Safe Mode.
To help you make sure the firmware update is successful:
  1. May I suggest you make sure you are running the latest Harmony Setup Software (V 7.7.0).
  2. Replace your remote's batteries with fresh ones. It is important the remote has sufficient, unvarying power when updating firmware.
I hope that helps.
______________________________________________
Harmony One Manual Download
Apr 18, 2009 | Logitech Harmony One Advanced Universal...
Replaced batteries in Harmony 670. Does not work shows "Safe Mode
Update the firmware:
- Launch the software. - Connect the remote. - Click "Downloads" - Click "Firmware." - Update the remote.
That will get the remote out of safe mode.
Mar 29, 2009 | Logitech Harmony 670 LCD Remote Control
Logitech Harmony One Advanced Universal Remote with Color Touch Screen Logo
1,136 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
ka4iup
ka4iup
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
