Question about Bosch Classixx WFL 2066 Front Load Washer
There is a foul smell in the machine which is coming from residue which has collected at the back of the rubber door seal. Can we remove the rubber seal to clean out this.
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch wfl2066 front loader washing machine
Posted on Jul 22, 2013
  • Bosch Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip about how to clean your washer
How to have a Clean Washer
heatman101
Posted on Sep 01, 2010
I have a Hoover PFA167 AAA1660 7KG front loading washer, which has the most foul smell when i open the door, if i wash in it i have to take the washing out straight away to avoid my washing smelling....
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2010 | Hoover Washing Machines
Mould/gunk on the rubber seal of a Maytag MAF1300 AAW - help!
Once mold is present the only way to get rid of it is with peroxide. Any residue left will grow again.
May 13, 2010 | Washing Machines
I have always had a smell coming from my duet washer. I put bleach in and run it through a rinse cycle, but it always comes back
there may be some dirt or other things collecting in the drain boot attatch to the drain pump there is usually a plastic coin trap located inside the rubber boot his will cause a musty smell in the washer.as well as a moldy door boot seal.if the door boot is moldy it needs to be replaced.
Jan 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Foul odor from front load washing machine
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Nov 06, 2009 | Washing Machines
Terrible smell coming from our washing machine
remove bottom cover at back of machine, loosen large jubilee clip on hose between drum and pump. pull hose down and off, take out strainer basket and pull top off, clean top, ball and basket by running under tap. clean out hose with an old rag. reassemble strainer and put back into hose, in the correct position. fix hose back on to drum and tighten clip. run machine on a hot wash and all should be fine.
Nov 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
Foul odor
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%4
Aug 26, 2008 | Kenmore Elite 45986 Front Load Washer
Rubber door seal mouldy
Wouldn't normallyexpect a few mould spots to leave that bad a smell, so likely you've got two distinct issues.
Starting with the water trapped in the seal: Open the door and very carefully slip your fingers into the seal where the water is gathering (to stop your hand getting trapped between the drum and the outer casing, put your other hand inside the drum and push it up out of the way - just be careful not to let it spring back too fast).
At the very lowest point,of the space inside the seal, either at the very front or the very back (so tucked into the corner between the floor of the seal and it's front or back wall), you'll find a little drainage slot. Once you've cleared the inevitable blockage from this slot, your seal problems should vanish.
If the foul smell is coming from inside the machine, the problem is likely to be grey sludge inside the works of the machine. This is usually caused by modern detergents not being quite as good at working at 30 degrees as they claim to be. The answer is to run a cycle every now and then with no laundry, detergent, or conditioner in the machine, on the longest, hottest programme the machine will support. This should be sufficient to dissolve the rotting sludge and pump it away down the drain.
A.
Apr 06, 2008 | Zanussi ZWF1440 Front Load Washer
Duet washer
Run the washer on the hottest setting you have with nothing but a cup of bleach in the tub. Pour the bleach through the dispenser so it cleans the dispenser as well. Run the washer like this and let it complete the cycle. If the smell persists, remove the lower kick panel under the door and check the drain trap on the drain pump for anything that could be caught in the pump and making it smell. This odor can travel back into the the wash tub. If you decide to open the drain pump, however, here's a bit of advice. There is some residual water that stays in the drain lines and pump (this is normal). If you remove the drain trap cover, all this water will come gushing out. To avoid this, take the drain hose out of the standpipe and use a wet/dry shop vac to pull this remaining water from the tub and lines. This will save you from a big clean up later. Lastly, you mentioned you've been cleaning the rubber door boot. Are you using 50/50 mix of bleach water in a spray bottle? Are you cleaning the area behind the door boot where it meets the wash tub? I ask this because once mildew sets into the rubber it's hard to get rid of it unless you use something with chlorine in it to kill it. Also, articles of clothing get caught in this area and can begin to smell. Not to mention, all the nasty residue left by soap and detergent. If all else fails, and you have tried all the advice, the last thing I have found that works, is to simply replace the entire door boot. -courtesy jsrock (guru)
Nov 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
225 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
