Question about HP 2133 Mini-Note Notebook
The mouse pad on my dv-6 2133ee is not allowing to double click, no action takes place when i double click on the mouse pad, every time i have to depend on the two keys given below
pontelemon
  • 531 Answers
SOURCE: touchpad does not work 100%
You can "tap" on touchpad as you do with left click,
otherwise it needs new touchpad assembly.
Posted on Mar 19, 2009
Murphybanton
  • 2004 Answers
SOURCE: touch pad - not double clicking for selection
Please run system restore but visit http:/www.hp.com go to drivers and download synaptic touch drivers again.
Good luck
Posted on May 19, 2009
Endeir
  • 140 Answers
SOURCE: touch pad
Are you wanting to take the double click off?
Posted on Feb 19, 2010
  • 53 Answers
SOURCE: My mouse on my presario
I would verify that you have the compaq drivers installed for the mouse pad NOT the microsoft defaults alot of the time they add functionally like the double tap click and things like that. The link is
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=500746&prodTypeId=321957&prodSeriesId=432985&swLang=8&taskId=135&swEnvOID=228#11318
Its under input devices I selected windows XP I dunno your operating system but if your operating system is Windows xp that will work.
Like this if it worked for you. PLEASE!!!!
Posted on May 16, 2011
damnor01
  • 1179 Answers
SOURCE: on touch pad, the left and right click below the
Since the left button is a primary button it gets used quite a lot thus the button fails at some point in time.
Either the button has broken or the spring mechanism has broken.
Don't worry it can be repaired, claim warranty support if you can. The laptop needs to be partially disassembled and the buttons inspected. The button may need replacing.
Take care!
damnor01
Posted on Jun 09, 2011
Testimonial: "My son figured that the spring might have broken, but can't find a manual showing us how to disassemble the laptop, is there one available?"
How di make my mouse work
usb mouse or mouse bad ?
Look at the type of mouse you have.
To date, there are three types of mice: the USB mouse, the PS/2 mouse and the Bluetooth mouse.
USB mice connect with a USB adapter, which has a rectangular shape. Conversely, the PS/2 mouse uses a PS/2 adapter, which is round.
Finally, there's the Bluetooth mouse, which has no external adapters.
Plug the mouse into your machine.
Now, how you do this will depend on the mouse you're using.
With a USB mouse, simply plug your device into your laptop's USB adapter, which will also be rectangular in shape.
For PS/2 mice, you'll need to plug it into a PS/2 adapter. Plug your mouse into the PS/2 end then plug the other end into your laptop's USB adapter.
And for Bluetooth mice, no plugging is required.
Install the mouse drivers.
If your mouse is not plug-and-play, you're going to need to install its drivers. To do this, insert the CD or diskette that came with your device.
The installation should occur automatically.
Pair your mouse, if using a Bluetooth mouse.
At this stage, non-Bluetooth mice are ready to be used.
However, if you are installing a Bluetooth mouse, you must perform one additional step: pairing it to your machine.
To achieve this, use your laptop's touchpad and right-click on your Windows screen. Select the option "Pair Device." From there, follow the on-screen instructions to sync your mouse with yourcomputer.
Place your mouse onto a mouse pad. Before using your mouse, you need to place it onto a mouse pad.
This should be done for all types of mice, whether they are wireless or trackball.
Otherwise, movement will be difficult
mouse pad
Examine your mouse pad.
Dirt and grime can affect performance and slow down mouse sensitivity, if not shut it down altogether.
Make sure the surface of the track pad is clean and that there is nothing that has managed to get beneath it or around any trackball buttons that could affect the pressing and depressing of the component.
Check to see if your mouse pad has been turned off.
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option. Click on it and you will see the option to enable your device, then click OK. If this does not work,
Check the manufacturer of your laptop (for example, Toshiba) and then navigate to their official website. Find an area for Software and Drivers, and move on to that area.
Enter your laptop number (check your documentation/manuals and/or the bottom of the computer) and look through the drivers that are presented as a result of this number input.
It could be that your mouse pad simply needs updated drivers. Find the driver that corresponds to your computer and mouse pad (for example, most Acer laptops use a Synaptics touch pad).
Then, click on download.
Once the drivers have downloaded, double click them to ensure they install, restart your laptop, and your mouse pad should be working again.
hope this helps
Sep 09, 2012 | Compaq Presario CQ57-339WM
Laptop touchpad doesnot clicking
If the click on the pad works but not the button ..it may be either the driver to blame or the function disabled in the control panel or just the button being dead..The fact that allows you to drag means that it one of teh click works ..cause you can not select for dragging without the click function ..
If the button is dead and even after reinstalling the driver will not work ..see if the double click on the area where you drag works ..usually all pads work for click if you peck on it ..
If it is the other way and the button works but not in the tab area..it is the driver but if it works there but not in the button it may be something damaged physically ..
If it does not take double click in the tab area..check the settings in the control panel ..mouse pad..The double click may be disabled..
Jan 11, 2012 | Acer Computers & Internet
My mouse on my satellite a660 scrolls up,down,left and right without a glitch but i can't get it to double click and enter to open up pages. on the opening windows 7 blue page where the little icon...
hello friend,
I THINK THE PROBLEM IS FROM THE MOUSE PAD, I THINK IS EITHER YOUR HAND IS WET OR SOME LITTLE WATER POURED ON IT, IF NOT, THEN IT IS DEVELOPING SOME FAULTS THAT I THINK MAY TAKE SOME TIME. PLEASE IF YOU CAN LOOK FOR AN EXTERNAL MOUSE TO USE FOR THE MINE TIME NOW AND AVOID TOUCHING THE MOUSE PAD FOR SOME TIME THEN I THINK IT WILL COME BACK TO NORMAL LATTER.
Jul 11, 2011 | Toshiba Satellite A660-BT2G22 Customizable...
When I tap on the touch pad on a HP Pavilion dv7 cursor jumps
The touchpad is installed on HP notebook PCs.
You can "tap" and "double tap" your touchpad with your finger, and interact with the operating system in exactly the same way as clicking and double clicking on your mouse.
When using touchpad on your notebook PC, the cursor may jump, flicker, or double-click by itself.
Follow the recommendations in that HP document, or "disable" the TouchPad, if you don't like what it does.
May 12, 2010 | Computers & Internet
Go to your control panel and double click on your mouse icon to get to your mouse properties. Go to "Pointer Options" and make sure that the "snap to" box is unchecked.
Mar 21, 2010 | HP Computers & Internet
Touch pad
Feb 19, 2010 | HP Pavilion dv1000 Notebook
When I select text (doesn't matter whether with touch pad or mouse) the action isn't cancelled when I release the touchpad or mouse button. I have to click again to make another action.
This is normal, it allows you to use keyboard shortcuts to process the selected text.
It should cancel if you click elsewhere on the screen.
Oct 04, 2009 | Computers & Internet
My pointer is down...
might be mouse on off botton is it on turn labtop off back on with out usb mouse on it then buy mircosoft mouses only for best results and easy to use
Mar 13, 2008 | Computers & Internet
Mouse touch pad is too sensitive and erases information and relocates the cursor.
Go to "control panel" and double click on "mouse"
Take a look around and you should find a setting to allow you to decrease "tapping" sensitivity.
Sorry I can't be more specific as each computer setting window is slightly different. I hope this helps.
Dec 31, 2007 | Acer Aspire 5500 5570-2609 Laptop
THE 4-way scroll button IN MY ASPIRE 5100 DOESNT WORK
Double click the icon in the toolbar. Click the device settings tab and then hit setting. select buttons in the list on the left side. Hit the plus sign(maximize) and select scroll up button action....scroll down button action...Etc. For each action select what you want it to do and just hit apply and move to the next. Once you have selected the action for scroll up, down , left, and right hit apply again just to be sure and try it. It should work. I just did it on my 5630 but Im assuming it works the same.
Aug 14, 2007 | Acer Aspire 5100 Notebook
HP 2133 Mini-Note Notebook Logo
71 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
