Question about Nokia E72 Smartphone
I tried to put my sim card in and i put the cover on but now it is stuck and I cannot get it off...............help!!!
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
Alcatel one touch sim stuck in sealed phone, no tray just a slot next to the SD card holder. Can anyone please help me if they know how to get it out??
can you take a pic of the slot and how the sim card is stuck in there? Have you tried a small needle in there to see if you can catch the end of the sim card and then pull it out?
Jun 09, 2016 | Alcatel Cell Phones
Verizon wireless lg env2 vx9100 make put a sim
Verizon phones (unless global which the env2 isn't) do not support sim cards. If you are talking about a micro sd card. It goes in under the cover on the right side for the phone. Hope this helped
May 23, 2012 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
I have a nokia X6-00 and am trying to change my sim card. I have taken the battery off and opened the sim card cover, can slide the tab across so the sim card moves out but then it is stuck, I can't pull...
Please use gentle pressure to push or use a thin tool to slide the sim without damaging the SIM. Try and move it forward or backward so that there is free movement or the SIM is released from the jam position.
Mar 15, 2011 | Cell Phones
I put in my sim card tray in backwards and now its stuck
How to get the sim card tray out of my iPhone it is stuck backwards
Feb 21, 2010 | Apple iPhone 3G
My alcatel one touch is stuck on emergency mode how do i get it off?
I took my batter and sim card out and put battery back in without sim. Next, turned on my phone and then back off; then removed cover and battery again. I then reinstalled the sim, battery, and cover. Turned it back on then it worked. I don't know if this will help in your case, but give it a try.
Feb 11, 2010 | Alcatel One Touch FIRST 20 Cordless Phone
How do I replace a SIM card in a Nokia 2115i?
firstly turn off your phone then open the battery back cover which easy just slide then take out the battery and you will see the sim card holder take out old sim card and put new sim card then put battery back and put back cover.
Dec 30, 2009 | Nokia 2115i
Can not get Nokia 6120c V04.21 to online mode
there might be problem with the sim card holder. try to insert some piece of paper folded atop the sim card and close the sim holder
Aug 12, 2009 | Nokia 6120 classic Cellular Phone
Need to put in sim card
try and find a button or arrows to show you which way the back slides off. it might take some strength because its a new phone
Dec 25, 2008 | O2 Samsung SGH-E250 Cellular Phone
Nokia E72 Smartphone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
