Question about LG Washing Machines
Lg washing machine, model no. wm-1280 keep on getting error code LE, some people are saying its the sensor (which i'm dubious about) and others are saying motor or bearings....... erm help
  • 4,323 Answers
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it’s not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn’t move freely then the motor is locked and you’ll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...
Daniel
Posted on Sep 01, 2010
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
LG WASHER LE CODE
Fix for Error Code "LE" on LG Front Load Washing Machine
I just had an interesting experience with our LG washing machine today. I found some hints for the solution online buried in some user forums, but I thought posting my particular solution here in a less cluttered blog might make it easier to find.
I had just run a load of laundry, emptied the machine, and reloaded. I put the detergent in and started the machine. After sitting for about 2 minutes with no activity, a "LE" error message appeared.
While the online forums indicated this might be a problem with a sensor, I was able to solve the problem by doing the following:
1. Press the Power button
2. Manually rotate the hopper 4 times clockwise and 4 times counter-clockwise.
3. Press the power button and run the machine normally.
Don't know if this will work for everyone, but it worked for me. If I keep getting the error message, I'll have to call LG and find out about this sensor I was reading about.
May 30, 2014 | LG WM-2277HW Front Load Washer
Lg Tromm front loading washing machine. Model # WM0532HW.I keep getting the UE and IE codes. Also makes alot of noise in the spin cycle....warranty is done....should I not bother & get another
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too small, too large objects between tubs
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Service notes and manual
Jul 23, 2011 | LG WM-2277HW Front Load Washer
LG WM 1485FHD with LE error code. Stope washing after 5 or 10 mins and can't get it to complete cycle
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Jun 14, 2011 | LG WM-1485FHD Front Load Washer
Water still in machine says LE on display
LE error code means Locked Motor Error.
Sometimes this can be cleared by unplugging then plugging back in the machine. If this does not clear it you have a faulty component.
This usually failure of a component called the Hall Effect Sensor which may need to be replaced.
Dec 16, 2010 | LG WM-2277HW Front Load Washer
What does the LE code mean on the LG front loading
The main cause for this error code is because you used too much or the wrong kind of detergent in your washer. This code is set off by too much suds in the washer. Not only will this set off the alarm code, but it may also cause your washer to leak and even start to have a bad smell from the dampness getting where it should not be.
OR
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
Please check the below link for an detailed article about LE error code
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
COURTESY:HEATMAN101 - A senior and experienced expert of fixya
Jun 06, 2010 | LG WM-2277HW Front Load Washer
LE error code on LG WM0642 FL washer
LE is a locked motor error code.
It is usually associated with a loose motor connector wire or a defective Hall Sensor.
Mar 08, 2009 | LG WM-2277HW Front Load Washer
LG Front load washer LE error code
You can order parts by your location by CLICKING HERE
Nov 21, 2008 | LG WM-1832C Front Load Washer
LG Washer LE Error
Yes this is the same Hall sensor as in the WM 2277
You can Order them HERE and have them within a few days.
Easy fix
Jun 14, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
87 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
