Question about Dell Dimension E510 PC Desktop
Fix graphics card on Dell Dimension E510
Got the diagnostic lights 2 and 4 after buying and installing a new power supply. I also bought 512 MB of memory and installed it but I didn't buy a matched pair of memory cards. Anyway life was good for the evening but the next morning it froze up and I couldn't use ctl alt del so I turned it off by holding the power button until it went off. It didn't come back on...Can you help? Thanks
  • 558 Answers
Something on the motherboard may be damaged, if you replaced a power supply the motherboard really needs to be checked to see if there is any damaged components on it. my best guess is there are damaged components on it and you may need a new motherboard as well
Posted on May 11, 2008
How do I fix a dimension E510 with a solid amber power light?
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 25, 2014 | Dell Dimension E510 PC Desktop
I have a Dell Dimension E510 and was told the Radeon 4670 would work in it. I installed the card but the computer just goes on and off and on and off. Is the card too powerful for my computer? Or do...
You do need to install the drivers before using your new card, but that would only effect the display if you didn't. If the computer is actually shutting down, then I think your power supply might be the problem. Check your card's manual to see what the minimum power input is. Then compare that to what your current power supply's output is. These new cards draw a lot of power and if your power supply can't handle it, the computer will shut down. If it does turn out you need a more powerful power supply, you can find them online. It's a fairly easy change to make. Hope this helps!
Apr 19, 2011 | ATI RADEON Hd 4670, (1 GB) PCI Express...
I have a dimension 4100, and only have 512 in ram because it only has 2 slots, is there any way to use a bigger stick to increase ram?
Yes, if only one slot is being used you can install another 512 MB of ram which will give you 1024 MB or 1GB. If both slots have 256 MB in each one then you will need to just buy a 1GB strip of Ram. Go to the link I am posting and let them scan your computer. They will tell you exactly what you can install and the price. This is a site I use all the time and it is reputable and safe with good prices. This will require a download of the scanning tool which is safe. Allow the download. http://www.crucial.com/
Nov 05, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
I upgrade the memory of a Dell Dimension Desktop 9150 from 512 MB to 2 GB,The machine accept up to 4 GB..In the BIOS appear the 2 GB but on system in Control Panel only shows 512 MB..Can anybody give me a...
No you don't have to install a 64 bit OS. Only if you install over 3 gigs you MUST install a 64 bit operating system. 800MHZ is fine it will just back down to 667MHZ. your 32bit windows OS will see up to 3 gigs (minus graphics card memory). SO 2 gigs will work fine. Install one stick at a time and check in the OS and bios to make sure each stick works. I would say you possibly have a dead ram stick.
Jun 03, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
Mar 09, 2009 | Dell (2336V) Motherboard
Dell dimension e510 won't turn on
Unplug the power cable from the power supply in your computer and reinsert it. If you still have nothing, most likely a dead power supply.
Jan 24, 2009 | Dell Dimension E510 PC Desktop
32 mb ATI Rage 128 Ulta upgrade
http://support.dell.com/support/edocs/systems/dim4550/techov.htm#1101565
The documantaions say thar you have an APG-port, i cant see any problem why you couldent upgrade it...if u can find a card.
Good luck
Nov 19, 2008 | Ultra ATI Rage 128 Pro Graphic Card
Memory detected/Memory failure on Dell Dimension PC
So basically the computer does not start. Because I am not sure that is what you are saying.
I think from my understanding it is an issue with vista rather than with the computer. Somehow the new driver has put your computer in sleep mode. The computer of friend of mine starts by itself.
Another I want to say that the memory cards are fragile they can go bad. The way you touch them it is important.
Feb 01, 2008 | Dell Dimension 2400 PC Desktop
Dell 30
i think your graphics card does not support such a high resolution. 2560 x 1600 is a crazy resolution and 256 MB isn't gonna cut it anyways. try looking at the specifications on the graphics card box. it should say the max resolution. if you tell me the exact name of the graphics card i can figure out.
hopefully that helps
Dec 22, 2007 | Computers & Internet
Dell Dimension E510 PC Desktop Logo
314 people viewed this question
Alun Cox
