Question about Brother HL 5150D Laser Printer
I have a Brother HL 5150D Laser Printer and the status light is solid red and will not print. This has been going on for about 2 months and usually I can cut the machine off and it will reset but now I cannot print anything.
4 Suggested Answers
mbase213
  • 728 Answers
SOURCE: PAPER JAMMED-PRINTER HL5150D
Hello a_bowen1
You can clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Note
    • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
    • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
  1. Pull the paper tray completely out of the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Press the cover release button and then open the front cover.
  1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
hl50_05712.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Note
    If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
chap0615.gif Caution
    After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
  1. Pull the Duplex Tray completly out of the printer.
  1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
  1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
    Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
hl50_047.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit assembly back in the printer.
  1. Put the paper tray in the printer.
  1. Close the front cover.
Good Luck and don't forget to leave a rating based on my solution:
Mark
Posted on Apr 04, 2009
SOURCE: HL-5140 Brother laser printer red status light remains on.
Help me, please . Red status light on. PC recognises printer. Nothing happening. Toner was on for a few weeks. But now new toner cartridge and still solid red light. What is this?
Posted on Apr 29, 2009
male_28_cam
  • 1555 Answers
SOURCE: Brother HL 5150D printer has all lights flashing
switch off your printer. Remove power cable from printer. Open upper cover remove cartridge and then re-install. Wait for 5 minutes. Connect power cable again and restart your printer. It will work fine.
Posted on Jun 20, 2009
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
Brother 5150d
1. Press the cover release button and open the front cover of the printer
(so you can see the toner cartridge)
2. Press and hold down the Go button until all 4 LEDs are lit. Once all 4
LEDs are lit, release the Go button.
3.Close the front cover.
4. Make sure that the Drum LED is now off
Mar 19, 2012 | Brother HL 5150D Laser Printer
My hl 5150D will not print. when isend document
1/ Check waste toner may need empty. 2/ You maybe out of toner. remove toner and give it a good shake will get a few more prints usually. Need more info from you. Have you check paper paths. Have you rebooted both printer and computer. Remember you must remove power supply on both for ten seconds for true reboot.. Good luck
Oct 10, 2009 | Brother HL 5150D Laser Printer
Status light solid red not printing
Press the menu button for 20 sec and then try to turn on the printer
Sep 15, 2009 | Brother HL 5140 Laser Printer
Jun 20, 2009 | Brother HL 5150D Laser Printer
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Brother HL 5150D not printing unless I keep pressing Go
its not the problem of toner cartridge.its the problem of gears which pulls the paper they r worn out or may be cracked internally.exactly what happens when you u give the print for the first time the printer gets command and the gears starts spinning and the paper gets pulled because it gets a pressure internally and after 2 pages that pressure gets low and it stops pulling the paper.some times changing the paper thickness solves the problem temporvarily .i mean use the thick quality paper instead of thin.
Jan 08, 2009 | Brother HL 5150D Laser Printer
New drum and the copies are extremly light
Drum may be defective must be repalced.
When replacing drum, be sure to reset the drum counter for HL 5150D:
-Open the toner compartment door, and hold the go button for 5 seconds.
Nov 30, 2008 | Brother HL 5150D Laser Printer
Brother HL 5150D Laser Printer Logo
133 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
