Question about Sony KP-57WS510 57" Rear Projection HDTV
My tv won't turn on anymore - Sony KP-57WS510 57" Rear Projection HDTV
  • Sony Master
  • 17,130 Answers
Please try to access my link for the SM Power supply and understand if you can check out the power supply of your TV.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Sep 01, 2010
The tv usually turns on but now it won't. When it does turn on it makes a noise like a motor boat sound. The noise stays on until you shut the tv off. I'm not sure what it is I think it's the fan but
I would say that if there is a fan inside of it and it sounds like a fan bearing going bad then that is what it is. The reason for it not to be turning on anymore could be because whatever that fan is cooling has failed. Not sure.
Jan 30, 2013 | Televison & Video
Turned on tv, few seconds it clicks off, after a few times, it won't click on anymore for awhile
Check
http://blog.coppelltvrepair.com/2012/07/sanyo-dp47460-dp42840-dp46819-and.html
You will want to check what is the model of your Sanyo, then contact Coppell TV Repair and ask if we fix the main board for this model - chances are good we do.
Prices are between $65 and $85 total as of September 2012 and you start by going to www.coppelltvrepair.com and following the "Shipping instructions" link.
But before any of that check with us if we service your particular TV model because Sanyo has lots of them and we don't do all just yet.
Aug 27, 2012 | Sanyo 42 in. LCD TV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
I have a Sony Bravia KDL-52XBR4 LCD TV.
Sure, but not at minimal cost - it's a sony! Probably the t con board.
Sep 17, 2017 | Sony BRAVIA KDL-52XBR4 LCD TV
Hello my computer will not connect to my screen anymore. I have a LG lcd monitor and tv it was working yesterday wen i turned it off and 2day wen i turned computer on my screen won't get the signal....
Check the cables and if this doesn't work try a different screen. In the event that a different screen does not cure the problem you may have bigger problems. It could be Ram failure it could be Graphics card failure or it could even be HDD failure. Always try the easiest and cheapest bits first.
Feb 02, 2012 | Computers & Internet
19 inch slyvania tv/dvd combo turn on play button stays on and the the tv goes to red green yellow and blue screen and won't do anything else
I have been having just about the same problem with mine, i can watch the tv for about 20 min and then the dvd player comes on by itself then it goes to red, green, yellow, and black and white, i've tried resetting the dvd player to default but it hasn't helped mine.When i try to turn it off it automaticly comes back on so i have to unplug it.If i find a way to make mine work right i will send you a message to let you know so you can try it on yours. I've had mine just over a year and i don't have a warrenty anymore.
Aug 08, 2011 | Sylvania LD195SSX 19 in. LCD TV
I need help I just won a tv but it didnt come with a remote but I have a RCA remote transmitter. Im trying to program it for the tv but I dont have the book anymore can you please help me The tv is on but...
This Web page should allow you to find the codes for any devices you want to add for this remote.http://remotefinder.rca.com/default.aspx?site=rca
Other than that there is an easy way to program this remote.
1. Turn on the device by hand. 2. Hold down the device name key.(hold the TV button to program a TV) 3. While holding down this key also hold down the power key until the red light turns off and comes back on. Then release both buttons. 4. From here hit the power button repeatedly until the device turns off. 5. Hit the stop key at the bottom. Now the remote is programmed for that device.
May 05, 2011 | Televison & Video
RCA P61927 61 in. Rear Projection Television
get a tv repairman out to make sure of the problem, it might be xomething simpler he can fix but it sounds like the convergence board is out
Jun 21, 2008 | RCA P61927 61" Rear Projection Television
Sony KP-57WS510 57" Rear Projection HDTV Logo
62 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
