Question about Cycling
How do I convert a two brake rollator to a one brake usage Its like a bycycle handle but i need a connection to maketwo cables into one,
  • 843 Answers
I have an old tandem bicycle that has two sets of brakes, with a total of 3 brake cables. One lever operates one cable and the other lever operates two. The brand is MAFAC. I found one on-line at the following site. Scroll down to "Mafac tandem brake lever".
http://www.bikeville.com/brakes.html Good luck, Al K
Posted on Sep 01, 2010
  • lindaphilbey Sep 02, 2010
    Thank you I will try them.
How do I adjust brakes on an invacare bariatric rollator
the breaks are just like the ones on a bicycle with hand breaks and there is a cable usually up near the hand squeeze area you will see where the cable enters and there is rotatable tensioner you can turn it one way of the other one way will loosen and weaken the breaks the other way will tighten and make the breaks more sensative. oh and you might need a small pliers to turn the little adjuster Invacare Bariatric Rollator Left Brake Handle And Brake Assembly
Mar 13, 2018 | Invacare Health & Beauty
How do I set and release the brakes
On most walkers the handle you squeeze to make the brakes work will push down. If you push them down the brakes will lock on and pull up to unlock.
Sep 23, 2014 | Medline Guardian Luxe Rollator,White,Each"
How to adjust brakes
Hi.can you tell me how to ajust front calipers on BA Falcon on 2003 6 cyl. thanks.
Jan 01, 2014 | Drive Medical Winnie Walker, Mimi Lite...
How to adjust parking brake on winnie lite 3 wheel rollator
For openers "LOCKING" handles)...
Very GENTLY would be the first caution..
Unlike the brakes on those long ago bicycles we used to have... these WALKER BRAKES are pretty cheesy plastic...
None of the ones I've been compelled to work with have
interchangeable parts... SO BE GENTLE.
Look at both ends of the cable of the first wheel you want to adjust...
You are looking for a threaded sleeve with a nut on it...
If the brakes are too tight you will want to shorten the sleeve...
Too loose you will want to lengthen it (tightening the cable).
DO NOT overtighten...
These are all plastic... cheaply constructed... but EXPENSIVE to replace.
I have had to hand craft REPLACEMENT PARTS to repair these things (nothing is STANDARD (but the careless attitudes).
When you do break'em... AMAZON had the greatest selection...
(knowing the mounting diameter, and cable length is imperative
(sold in PAIRS)).
Carnac the Magnificent
Jun 20, 2012 | Drive Winnie Lite Supreme 3 Wheel Rollator...
Brakes will not lock in parking position
There are adjusters on the brake cables that are designed to solve this problem. The cables for the brakes run inside a flexible housing. When you squeeze the handle, the cable should engage the brake. The problem is that the cables inside the housing stretch over time and do not work as well. There is a threaded adjuster at the handle where the housing of the cable goes into the handle. If you turn this adjuster counterclockwise it will, in effect, make the housing longer and the brake cable tighter (shorter). This should engage the brakes better. It make take some trial and error, turning the threaded adjusters clockwise and counter-clockwise to get the proper setting for your strength and comfort. This same adjustment technique applies when you pull the handles down in the park position and when you squeeze them to slow down. Hope this helps.
Nov 22, 2010 | Drive Medical Winnie Walker, Mimi Lite...
The brakes on a clever lite rolling walker will not engage when the grips are squeezed
There are adjusters on the brake cables that are designed to solve this problem. The cables for the brakes run inside a flexible housing. When you squeeze the handle, the cable should engage the brake. The problem is that the cables inside the housing stretch over time and do not work as well. There is a threaded adjuster at the handle where the housing of the cable goes into the handle. If you turn this adjuster counterclockwise it will, in effect, make the housing longer and the brake cable tighter (shorter). This should engage the brakes better. It make take some trial and error, turning the threaded adjusters clockwise and counter-clockwise to get the proper setting for your strength and comfort. Hope this helps.
Nov 09, 2010 | Drive Medical Winnie Walker, Mimi Lite...
Need to adjust the brakes on a Winnie Walker Lite Deluxe walker.
Please try :Instruction Manuals.Visit :-www.FixYa.com/Instruction+Manuals
May 12, 2010 | Drive Medical Winnie Walker, Mimi Lite...
Cycling Logo
59 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
