Question about Texas Instruments TI-30XA Calculator
Trig functions of the TI-30XA
How can I use secant and cosecant functions on the TI 30XA? I am currently needing these functions for navigating great circle calculations.
  • 1 more comment
  • Anonymous May 13, 2008
    mi is on it and need to take it off
  • Anonymous Mar 12, 2014
    how to short the reset pad on a ti-30xa
  • Anonymous Mar 13, 2014
    how do i put ti-30xa in theta mode
If the sides of a triangle are 15cm ,16cm, and 17 cm ,then the area of the triangle is what ?
Posted on Jun 16, 2008
Cosecantx = 1/sinx
secantx=1/cosx
cotangent=1/tanx
Use these identities to get at the trig functions not represented on the calculator.
Also to get the angles you need to use the inverse trig functions (for example sin^(-1) (2nd SIN))
Posted on Jun 12, 2008
How do i find angles using the sin, cos and tan in trig?
Posted on May 12, 2008
TI-36X won't let me take the CSC(1.5). I keep getting
No calculator can have EVERY mathematical function. Very few calculators have the secondary trig functions like cosecant because they're so simple to calculate in other ways. By definition csc(x) is equal to 1/sin(x) and you can calculate it that way. Similarly, calculate sec(x) as 1/cos(x) and cot(x) as 1/tan(x).
Jun 04, 2012 | Texas Instruments TI-36X Scientific...
I have to take the secant of -1.2. I'm supposed to get a degree. I can't figure out the order to push buttons. PLEASE help!
TWO THINGS YOU NEED TO KNOW, Eli.1. Secant will NEVER return a degree measure (or even a radian measure) no matter what computer or calculator you use. The reason is because secant returns the ratio of sides (hypotenuse over adjacent), which has a range of and find its reciprocal (ie, flip the number upside down: the reciprocal of 5 is one-fifth). That's all.B. TI-84 only uses the three basic trig functions. Secant is the reciprocal of cosine. Therefore, in order to find the secant of -1.2 radians you need to be in Radian mode (see #2 above). From there, you just find the cosine of -1.2 and take that values reciprocal (ie, flip the number upside down: the reciprocal of 10 is point one) . That's all. Math lesson: 1 Radian = 180 Degrees. Therefore, 1.2 Radians is roughly one-third of pi, therefore it is roughly one-third of 180 degrees; therefore -1.2 radians would be nearly -60 degrees (a very friendly angle measure). I hope that helps If not, you should call Texas Instruments because they've got friendly people who are happy to assist anyone. Questions like this are right up their ally, advanced questions like the syntax of the poisson cumulative distribution function are not. So, you're fine. For in depth math help holler at www.THEMATHCHEETAH.comIn Short: Secant returns ratios and NOT degrees or radians. Secant is the reciprocal to cosine. Arcsecant WILL return degrees/radians. Your calculator can be set to either mode.TEXAS INSTRUMENTS >>>>> all calculators ever made.
Mar 08, 2011 | Texas Instruments TI-84 Plus Calculator
I have a TI-84 Plus Silver Edition calculator and I need to find the inverse key to get values for sin, cos, tan, csc, sec, cot. I'm past the lesson where you use the 2nd/sin, cos tan to find the...
There are no keys for cosecant, secant, and cotangent. You can calculate those ratios as
csc(x) = 1/sin(x)
sec(x) = 1/cos(x)
cot(x) = 1/tan(x)
Simply calculate the trig ratio on the right and then take its reciprocal.
Dec 14, 2010 | Texas Instruments TI-83 Plus Calculator
When do I use the x-1 key and when do I use the inverse function keys? I know inverse function keys provide cosecant, secant and cotangent, but is that all they are used for?
Use x-1 to calculate 1/x (x to the negative-one power).
What I think you're calling the inverse function keys actually calculate arcsine, arccosine, and arctangent.
To calculate cosecant x, for example, use the relationship
csc(x) = 1/sin(x)
Sep 22, 2010 | Texas Instruments TI-83 Plus Calculator
Confusion on creating a prograM
"Input" is a command, which inputs a value. Try this:
Input X:tan^-1(1/X)
Apr 14, 2010 | Texas Instruments TI-84 Plus Silver...
How do I put cosecant, secant, and cotangent functions into my ti-84 plus?
By definition
  1. cosecant of X =1/sin(X), must not be confused with arc sine [sin^-1]
  2. secant of X =1/cos(X), must not be confused with arc cosine [cos^-1]
  3. cotangent of X =1/tan(X), must not be confused with arc tangent [tan^-1]
Because of these simple relations, calculator makers do not implement them with specific key sequences.
On this calculator, you have two ways to calculate one of these functions. EX cosecant of 37 degrees
  1. You enter 1 / [sin] 37 [ ) ] [ENTER] result is 1.661640141
  2. You enter [sin] [ ) ] 37 [ENTER] followed by [X^-1] to take the reciprocal of the previous answer. The [X^-1] key is the one just below [MATH].
A word of caution: secant cosecant and cotangent must not be confused with the inverse trigonometric functions arcsin, arccos, arctan
Jan 21, 2010 | Texas Instruments TI-84 Plus Calculator
How to use trig function keys on my casio fx-300ES
You have 3 keys for the main trigonometric functions: [SIN], [COS] and [TAN]
To use them correctly you must set the angle unit to the one your problem calls for.
Press [SIFT][MODE] [3:Deg] for degree, [4:Rad] for radian, [5:Grad] for grad. Dependig on angle unit chosen a small D, R, or G appears on the top of the screen.
If you need the inverse trigonometric functions arcsine, arccosine, arctangent, you access them by first pressing the [SHIFT] key
Thus
arcsine [SHIFT][SIN] (sin^-1)
arcosine [SHIFT][COS] (cos^-1)
arctangent [SHIFT][TAN] (tan^-1)
The syntax for the function is
[SIN] # [ ) ] [=]; [SIN] 30 [ ) ] [=] gives 0.5
[COS] # [ ) ] [=] [COS] 19 [ ) ] [=] gives 0.945518576
Note: if the argument of the functions are numbers, the right parenthesis is not necessary. But if the argument is an expression (with various operations) better put the parenthesis to make sure the calculator is performing as one wants it to.
By the way, there are no keys, or key combinations to calculate cotangent, cosecant, and secant, but you can use the definitions:
cotangent (x) = 1/tan(x) Do not confuse it with tan^-1
cosecant(x) = 1/sin(x) Do not confuse it with sin^-1
secant(x) = 1/cos(x) Do not confuse it with cos^-1
Hope it helps.
Oct 30, 2009 | Casio fx-300ES Calculator
Cosecant
The cosecant function is defined by
cosec(x) = 1/sin(x)
1[/] [sin] x.
Do not confuse this function with the arcsine function which is accessed by [2nd][sin to the -1]. When you use trigonometric functions make sure that the angle unit (Rad, dgree, grad) is the one you want.
Hope it helps.
Sep 18, 2009 | Texas Instruments TI-30XA Calculator
How do I use secant, cosecant, and cotangent?
try inputting using brackets (sin(angle))^-1 or 1/(sin(angle))
Jul 27, 2009 | Texas Instruments TI-84 Plus Calculator
Inverse Functions on Casio fx-270W PLUS don't seem to work
because cotangent, cosecant, and secant are all inverse trig functions, just type in 1 / |shift| trig function and the number if you are finding the angles. It might not be a dedicated button, but its an extra push, and it will give you the same result. *note that I put the shift press only because that is how you get the inverse tan to get an angle from a tan ratio.*
May 04, 2009 | Casio FX-270W Calculator
Texas Instruments TI-30XA Calculator Logo
5,597 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
