Question about Frigidaire Refrigerators
I am having a problem with water in the bottom of the frige under the vegetable drawers. I am having to soak it up with towels once a week or it will start to leak out the door.
    Brigadier General:
  • 3,917 Answers
Water build up
Good Afternoon Friend,
I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire Refrigerators
Lower drawer F1 error code, I suspect possible seal leak. Very small amount of water on floor. Upper washer control panel cycles rapidly through all programs and back light is burned out. I suspect control...
Yes this means that the machine is detecting water under the bottom drawer. Pull the bottom drawer out and soak up the water with a towel and then the error will go away. This happens often because something gets put in the drawer that's too tall and doesn't allow the lid to come down all the way and seal.
May 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water appearing in the refrigerator and collecting on the back of the shelves as well at the bottom under the vegetable and fruit containers.
could just be condensation,which is normall,have you put any uncovered/warm/food or salad/fresh fruit in lately,these all add to the"problem"there is no "fix "other than kitchen tissue under the salad /fruit drawers,and throw away once a week.fridges are not frost free.(condensation in freezer is frost)
Apr 01, 2010 | Refrigerators
Water under vegetable drawers
Look on the top back of ur fridge. in the middle of it u should see a resetacaple. if it is full of water and over flowing there is ur problem. then u have to check about ur cooling unith if not change the setting of u fridge let the frizzer frezze and the fridge stay a bit warmer
Nov 19, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
Bottom of fridge under vegetable drawers lots of water collects. Every two days have to soak up.
I assume it's a top freezer model. The drain is either blocked, or frozen up. You'll have to be able to remove the the rear panel in the FREEZER compartment and inspect.
One other thing that can cause this, is if you have an Ice maker, and when filling, the fill hose to the ice maker hose has become dislodged.
Oct 19, 2009 | Whirlpool Refrigerators
Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 21, 2009 | Refrigerators
Water is pooling in the bottom of my roper refridgerator.
check door gasket all the way around , check water line inside frige behind crisper drawers
Jun 25, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
May 16, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Refrigerators Logo
174 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
