Question about Microwave Ovens
How do I change the filter on my Ariston System 2000 cooker hood?
CAN a ZANUSSI gas cooker be converted to utilize NG ? Without affecting its programs and controls ?
usually any gas cooker can be converted as long as the gas jets are changed to the right size. they also have to be the right fitting. it would involve a lot of work as you will need to get into the nitty gritty of the gas lines inside the cooker and if you make a mistake it can cost to get it fixed.
Jul 02, 2017 | Microwave Ovens
Hi can u pls send me installation manual for Whirlpool for Ikea 90cm cooker hood HOO D10S with carbon filters. Thank you :)
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 09, 2011 | Whirlpool Microwave Ovens
The lights have blown on my Lamona cooker hood, is there a fuse and how do I access it?
So has mine. At a loss as to what to do as fan not working either. Any joy yet???
Feb 22, 2011 | Microwave Ovens
Hi, I have a hotpoint cooker hood and the lights keep fading out then flashing on again.
Sounds like loose/burned wiring at the plug or spur unit .Check mains feed
Feb 22, 2011 | Hotpoint Microwave Ovens
I have a plaster board wall,can i fit a cooker hood to this
Yes but only if you fix into the wooden stub work behind the plasterboard.
Feb 14, 2011 | Microwave Ovens
How do i fix a LOGIK L90CHDG10 90cm Cooker Hood to the wall and what are the power requirements thanx
That should come with a drawing to cut out, sometimes the box itself will have that on, and one places it on the wall to mark screw holes for fixing.
It will run, as it is only a fan and a light buld, from the cooker switched outlet on the cooker point, or a fused outlet from a spur.
If you are unsure, get a qualified electrician to wire it in for you!
Jan 15, 2011 | Microwave Ovens
Good morning We are about to fit a rangemaster classic hood 120cm approx. to suit our Elan 110 dual fuel cooker with a gas hob. What is the corrrect distance we should leave between the hob and...
In my experience, the hood should be just above head height, that will avoid banging your head, and at least 33 inches or 8ocm above the hob.
Hope this helps.
Nov 03, 2010 | Microwave Ovens
Microwave Ovens Logo
172 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
