Question about Lexmark X7350 All-In-One InkJet Printer
Remove glass to access scanner
How do I remove the top glass to access the scanner unit to adjust how it rides on the bar. It vibrates loudly in transit, blurs the scan
  • 39 Answers
I personally wouldn't try to do that, you run the risk of rendering the scanner nonfunctional, and also probably would void the warranty if it's still applicable. You may try calling Lexmark support at 1-800-332-4120 and tell them the scan bar is really noisy, and that's making the scans blurry. Depending on whether you're still under warranty and who you get (no joke), you may get a free replacement, since this sounds like a manufacturing defect.
If you can't get it replaced because it's out of warranty and decide to buy new, Lexmark's new business products that have just been released have a 5 year warranty, which is probably best in class. Check them out here.
Sorry I didn't respond to your post sooner, you've probably fixed this by now - I only registered here recently.
Posted on Aug 06, 2008
How to clean the underside of the glass in a HP scanjet 2400
Hi ,
You probably already found this :
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/performMaintDisplay/?sp4ts.oid=297429&spf_p.tpst=psiContentDisplay&spf_p.prp_psiContentDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01275864-2%257CdocLocale%253Den_US&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
According to it , you should normaly contact a HP technician to have the job done . Nevertheless , I succeeded to clean the underside of the glass inside a HP Scanjet 5470C wich seems similar to your model 2400 . If you take of the lid of the unit , you should find two screws in the opening of the hinges . Unscrew them and lift up the the whole top of the unit . You might encounter somme kind of resistance during the operation but I finally succeeded to get the it free that way .
Best regards .
Sep 04, 2014 | HP ScanJet 2400 Flatbed Scanner
Printer keeps making an adjusting noise
If it is the scanner making the adjustment noise it is because it is having problems adjusting scanner either for location or white balancing. You can try one thing that sometimes fixes the problem, but if this does not work then you will likely need to replace.
1. Turn off printer and unplug power.
2. Lift up scanner lid so that you can see the scanning glass
3. Locate the screw on the top left side next to the small **** of glass. This glass is the section used for scanning from the automatic document feeder. Remove that screw and then the plastic that it was holding. Lift the glass out.
4. With the glass removed you can see the drive belt for the scanner. You need to rotate it until the scanner head moves to the left far enough that you can see the top of the moving part of the scanner. You will see a thin light bulb and a slot. Do not touch the lightbulb, it is fragile. You may need to pull on the assembly to move it the last bit to access the slot
5. Use a flashlight to see down into the slot, you will see a thin mirror that runs the width of the slot. If that mirror is dirty, that may be the problem and it needs to be cleaned.
6. Use a q-tip moistened with either alcohol or window cleaner to gently clean the mirror. Make sure you do not leave any lint in there.
7. Replace the glass and turn printer back on. If this is going to work it should come to ready.
May 01, 2011 | HP LaserJet 3330 All-In-One Printer
RE AL 1621 SHARP - REPLY
"L1" flashing is common.
1.Under the bottom left corner of the control panel there is a plastic latch that locks scanner assembly for transportation purposes (you can see it if you look underneath; you unlocked that latch when you installed the copier). After a while, due to vibration, that latch moves and deters scanner/lamp free movement. Move it counterclockwise (looking from top). This we usually troubleshoot over the phone.
2. If this doesn't solve the problem, the technician should clean and oil the shaft the scanner assembly rides on (steel bar that runs on the rear side of the copier, left to right, you can see it through the glass).
Jan 03, 2009 | Office Equipment & Supplies
Hp 2820 scanner error 5
I'm not sure if this will help or if this is the same as i had but I had been given A laserjet 2820 which keep't coing up scanner error 5 the chap that had it before me contacted hp service & was told to replace scanner unit which he did & it was ok for a while like 6 months & started then started again.
The problem he had was powered up ok till it came to scanner bulb warming up the scanner unit moves back & forth then try's to escape through the right hand side of case.
This is because it cant see the home position white strip under the scanner glass all you have to do is remove top section of the scanner unit complete with scanner glass & clean the under part of the scanner glass the white strip is located under the wide gray panel as you look down on the scanner glass with the lid up. hope this is of some use. my unit has been working for some time now
Dec 29, 2008 | HP LaserJet 2820 Printer
The Black line on the paper when I scan and fax
try cleaning the grid on the drum unit and you might replace the drum
Dec 22, 2008 | Brother MFC-8220 Fax
Ever Smart Jazz Scanner
you cannot.... mmmmmwhhhhhaaaahahahahahahhahahaha
Jun 09, 2008 | CreoScitex EverSmart Jazz Flatbed Scanner
HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
Apr 16, 2008 | HP LaserJet 2840 All-In-One Printer
Microtek scanmaker 9800xl problem
9800XL - fix for failing lamps
1) Unplug the scanner - not just from the computer, but also from the AC!
2) If your unit has a Transparent Media Adapter on top, disconnect it from the back of the scanner, lift it off and set it aside.
3) Remove the four white slotted screws at rear of unit.
4) Remove the four Philips screws in the area surrounding the glass scanning bed.
5) Carefully lift the top off, and set it aside.
6) Inside the scanner, there will be a black metal contraption that rides the two steel rails in the unit. On the side of the contraption are some black screws. This device contains the lamps as well as the image sensor. Unscrew the 4 screws that hold the top cover on. Lift off the top cover. You may gently move the thingy along the rails for easier screw access, it will automatically reseat itself when powered on.
7) Inside this area, you will see a small circuit board. Disconnect the two connectors on it, remove the two screws that hold the board in place, and lift it out.
8) On this circuit board there should be one or two damaged capacitors. Unsolder them and replace them with 2 33pF 3kV capacitors (cost: under $1.00)
9) Put the whole thing back together, and it should function properly.
Feb 12, 2008 | Microtek ScanMaker 9800XL Flatbed Scanner
Toshiba e studio 150
on the toshiba Estudio 150 there is a lock for the scanner unit underneath the left side of the scanning unit where you would put your hand to get a copy. what happens most of the time is someone unintensionally turns that know which in turn gives the error code because the scanner cannot move. check to make sure that the lock is in the unlocked position. this plastic lock can be removed with a screw driver. other times we have found that the scanner rail underneath the glass needed to be lubercated with a light oil. to do this the four top screws on the top corners of the machine would need to be removed and the glass will lift off. once the glass is off you will see a silver bar that runs across the scanner unit that the scanner rides on. take some light oil like typerater oil put on finger and coat the siver rail with it by running you finger of oil on it. put back together and try. if that doesnt solve it the only other thing i have seen is broken scanner lamps and in that case it needs to be repaired by a service tech.
Jan 03, 2008 | Toshiba e-Studio150 Copier
How do I access the underside of the Flatbed scanner to clean it?
remove the lid by lifting up. There are two philips head screws exposed. Remove screws and lift top of scanner off. Pay particular attention to thumb wheel position when lifting. Go to computer repair center and buy double sided tape. replace tape and reverse process
Nov 08, 2007 | Umax Astra 1200S Flatbed Scanner
Lexmark X7350 All-In-One InkJet Printer Logo
76 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
