Question about Yamaha P4500 Power Amplifier 2-Channel
I have 2000watts speaker, what type of amplifier that is suitable for my speaker?
How do i hook up bose accustimass speaker to my radio?
Acoustimass speakers need to be driven by a Hi-Fi amp/receiver or AV receiver. So the thing that's driving them needs to be an amplifier.
Unless your radio is also an amplifier then the radio and the Bose speakers are not directly compatible. There's no suitable output on the radio that generates the correct signal in sufficient power.
Sep 07, 2014 | Bose Acoustimass 5 III System
3 blinking lights
It has gone into protective mode. There could be a short in one of the speaker lines or your speaker has catastrophically failed causing a short. Inspect your speaker lines and test the speaker coils with a volt meter for both continuity and a suitable resistance. If there is no resistance at the speaker or it shows that it is open then the speaker is the culprit.
Feb 10, 2012 | Clarion APA2160 Car Audio Amplifier
How to hook up speakers? Sound sounds muffled
You DON'T connect speakers to this... this is NOT a powered mixer... you MUST use external amplifier !!!! You use bvalanced (TRS) cables to a suitable power amplifier which connects to speakers. Some Behringer mixers such as the PMP5000 have built in amplifiers to drive speakers... yours does not.
Jul 23, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Hotrod amp is distorting on the clean channel once it goes past 3,is it a speaker problem or is it tubes?
to rule out the speaker, you could try one of 2 things.
1. remove the speaker from the cabinent and gently push the diaphram in 1/2 an inch to 3/4 an inch, as far as it will gently go- BE GENTLE. the speaker should recess and return to normal position smoothly, without any scratching or rubbing, or internal resistance., the only resistance should be from the paper cone itself, not internal to the speaker. if there is any rubbing or scratching from the inside (inside the area surrounded by the magnet), or any changes in resistance (not smoothly moving) as the speaker goes in or out, then the voice coil is damaged.
2. find another speaker of suitable wattage and ohmage, and disconnect the hot rod's internal speaker, and hook the replacement speaker up in the internal speakers place. a speaker of 50-100 watts should be suitable, and it will probably need to be 8 ohms- a standard bookshelf speaker may be suitable if it is a suitable wattage and ohmage rating (stamped on the back of the hot rod's speaker magnet and/or on the back of the external speaker/cabinent as "8ω",) do not, and again, do not, under any circumstance disconnect or connect a speaker while the amp is on, or even plugged in. touching the positive and negative speaker leads together, even briefly, while the amp is powered will fry the amplifier circuit, and you will smell it!!!
Mar 09, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Will hilfonics brutus 2010d mono work??
Well with the correct powering system, heaps of paralleled 12 volt Batteries, & a Beefed up Alternator to charge them, I guess so, BUT it is only Mono, so you will need TWO to provide stereo output
Mar 06, 2010 | Hifonics Brutus BX 1605D Car Audio...
How much does this amp run
Well here is the stats
2000watts 2-channel
Output Powers
• 500W (RMS) x 2CH (2 Ohm) 500rms each channel
• 600 (RMS) x 2CH (4 Ohm) 300rms each channel
• 1000W (RMS) x 1CH (4 Ohm)
If your talking about price it runs about...
$100-130
Jan 12, 2010 | Solid Audio Formula Series F2000 2-Channel...
Require speakers of sony make model no.DVPNS67P
The Sony DVP-N67P is a standalone DVD player which was produced solely for the Indian market with two analogue left and right audio outputs (phono sockets) and coaxial and optical digital outputs.
You cannot fit speakers directly to this unit, instead you must fit an amplifier with suitable matching input sockets and a connecting lead and then fit whatever speakers suit the amplifier. The amplifier and speakers can be of any brand, they do not have to be Sony.
Nov 06, 2009 | Sony Televison & Video
Technics SU-X955 amplifier. which speakers ?
Helo you have to use speaker of the same wattage you have now chage crossover to get new clear digital soud
Feb 11, 2008 | Technics SUV500 2-Channel Amplifier
Subwoofer for Teac AG-D8800 Receiver
speakers are suitable to any amplifier, exept for the rating of it. (wattage) sometimes there are some speakers that are voltage needed. well you can use it as a subwoofer output for your tv for better sound.
just buy a aux splitter for the two amplifier, so that you could use them both.
hope I helped you for this.. have funn.^^
Feb 01, 2008 | Audio Players & Recorders
Yamaha P4500 Power Amplifier 2-Channel Logo
67 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
