Question about Dual XDVD270 Car DVD Player
Daul wher can i find accessories for a Dual xdvd270
Dual XDVD270 Car DVD Player need to know who sells the accessories for it?
Hi Rose,
I Would like to tell you about a website where you can get a large variety of car Accessories at Wholesale Price. They also provide 12 Months Warranty on all the Products. Also it is a Paypal Verified Website. So You can have a look at the DVD Player at this Website which you are looking for at http://www.ankaka.com/Wholesale-car-accessories_c10005
Apr 05, 2013 | Car Audio & Video
My problem is not solved
The Dual XDVD270 shipped with a 12V 3A AC adapter. (It was similar to the DC car adapter except for having a polarized 120V plug.)
You can ask if a replacement adapter is available here: http://www.dualav.com/support/parts.php . They will need the serial number of your unit. Otherwise, I'd check with any store that as Universal Adapters for one that gives 12VDC at 3A. (You may have to try several adapter ends to get the correct polarity.) I've gotten some from Radio Shack in the past; these days those prices are higher than some online vendors.
I hope this helps.
Apr 05, 2013 | Dual XDVD270 Car DVD Player
I have an XDVD271 and the picture flickering or skipping. The audio is fine. What is going on?
Try to check/toggle the int - ext A/V switch on the left hand side of the unit, that might solve it if it is only on one screen, if it is on both it is most likely the DVD player itself, try with a clean good DVD to check if it could be a dirty or scratched DVD.
Feb 15, 2010 | Dual XDVD270 Car DVD Player
Wiring
moz-screenshot.pngthis is the best way if it is a dual 4 ohm ....
this is the best way if it is a daul 2 ohm sub...
Jan 28, 2010 | Boss REV-650 Car Audio Amplifier
I can't get my PS2 to connect to my dual xdvd270
You can connect the PS2 Video out (composite video out) to any of the 2 monitors video connector and the audio at the audio connector, remember to select A/V ext (External Audio and video) both video and audio uses 3,5mm jacks, if it does not work you might need to try to draw out the jacks a little, the connectors are of poor quality so be carefull.
You also might want to check if the right system is selected PAL/NTSC, check the format from your PS2 and set the monitor to accept the same signal type, then it should work fine.
The only thing I am not sure how you do is to get the composite video out of the PS2 but study the manual or google and you will find it I guess, but my guess is that you allready have that part covered.
Jan 03, 2010 | Dual XDVD270 Car DVD Player
Dell E210882 Socket 775 PC Computer Motherboard MB SATA can this surport daul processors
it only support socket 775 single core pentium 4 or celeron processors IT DOES NOT SUPPORT ANY DUAL CORE CPU'S SUCH AS PENTIUM D OR ANY DUAL CORE OR CORE 2 DUO PROCESSORS
Nov 21, 2009 | Computers & Internet
Dual xdvd710 whats the white/brown reverse lamp wire for
It is if you want to install reverse back-up camera to your rear bumper. You do not need to connect unless you have a reverse back-up camera.
Aug 08, 2009 | Dual XDVD270 Car DVD Player
Dual xdvd700
dual sells them from their website for about $30
Jul 24, 2008 | Dual XDVD270 Car DVD Player
Dual XDVD270 Car DVD Player Logo
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
