Question about Refrigerators
Not freezing ice very warm Is the fan in the freezer supose to run all the time
  • 944 Answers
Yes the fan will always continue to run to allow for the air to be circulated in the freezer compartment.
Due to various reasons this problem could occur:
1)Check the temperature setting.
Set it to max and min and check for any changes you can see in the system.
2)The compressor vents cold air into the freezer. Occasionally the vent can become clogged with ice, food or other debris. Locate the vent and clear it. To remove ice, use a hair dryer set to "low". Using the high setting may cause damage to the components or interior of the refrigerator.
3)Test the temperature control
With the ohm meter you can test it.If it does not show any reading this is the defective one you have to relplace this soon.
4)First and simplest thing is to make sure your condenser coils on the back of the fridge usually, are clean and have adequate air circulation. If you pull the fridge away from the wall you can just brush them off or use the brush on your vacuum.
5)Check for a clogged drain tube if it is clogged remove the clog.
6)Test the evaporator fan.The evaporator fan circulates air over the refrigeration
coils. The coils absorb heat and the chilled air is then circulated. If the fan does not operate, the freezer will not cool properly. The fan motor may have failed, but check first that something is not simply blocking the fan blade.
7)Defrost timer:Usually the defrost timer could solve this issue.It may be located below or back of the refrigerator.Some times it may be located in the side to for side refrigerator.Locate the timer and rotate the clutch head screw clockwise until you hear one audible click. That puts the system into defrost mode. If the system restarts after 30-35 minutes.Then there is no problem with Defrost timer.
8)Heater and defrost thermostat is located behind the back wall of the freezer section.This only controls the Heat.After the Defrost timer stops it makes the system warm.
Defrost thermostat could be defective.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 01, 2010
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
Please someo one help our freezer is soo cold that everything is freezing very hard, but our fridge is not cool it's starting to warm up, i see can see where the cold air is suposed to come from,
You will need to replace the "bimetal defrost element" and the "defrost heater".
Here is a link to the bimetal defrost.
Here is a link to the heater.
You will need to empty the unit of food and leave the doors open for 24 hours so that all the ice buildup on the coils defrost before you can replace the parts.
Take a look at this video.
Oct 16, 2012 | Roper RT21AKXKQ Top Freezer Refrigerator
My kenmore refrigerator model # 363.9771611 runs but is not cooling and the freezer is not freezing
Fan Problems
One of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food.
You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Other Causes
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
Have a good day! : )
May 04, 2011 | Kenmore Refrigerators
Imperial commercial upright. Top shelf is icing and frezzing bottom is not freezing.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
I hope this helps........
Good luck.
Apr 12, 2011 | Freezers
My whirlpool chest freezer runs but does not freeze?
Best regards.
Apr 07, 2011 | Whirlpool Freezers
Reefer is working fan in freezer is working freezer is not freezing
I hope the above helps.
Good luck.
Mar 22, 2011 | Refrigerators
The freezer will not freeze or keep its
Check to condenser coil and make sure it is clean and the fan near it is running when the compressor is on. Check for ice build up in the freezer. If the evaporator coil is iced up the box will run warm. It may be a defrost problem, a dirty condenser, or a refrigerant issue.
Nov 01, 2009 | Continental Freezer Wide Freezer low temp...
Freezer not freezing
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 11, 2009 | GE Refrigerators
Bosch KGV24V01GB Fridge Freezer - Model has Auto defrost feature but freezer section is all iced up. What do I do?
Try increasing the temperature of the freezer (closer to -5) for a few days. It could be you have it too cold.
At certain times it should feel warm in some places on the sides, or you may hear a fan running. If you don't get this, there may be a fault in the defrost circuit, timer or fan.
Make sure vents are clear, and that door seals are in good condition. A faulty door seal admits warm damp air which then freezes.
Where is the ice forming?
Jun 28, 2008 | Bosch Refrigerators
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
