Question about KitchenAid KHMS2050SSS Microwave Oven
Digital display distorted and is broken up by verticle lines in the display
  • 1,555 Answers
Digital display panels are made up of LCD technology. In case these displays get damaged there is no existing technology through which they can be repaired. You need to replace it. I have already checked it on the net and it is not available. The only option you are left is to contact the manufacturer and ask if they can provide you with the display. The second option is to approach any local kitchen aid repair shop and ask the guy if he's having any unserviceable unit with the working display on it.
Posted on Sep 01, 2010
    Genius:
  • 1,478 Answers
Defective or damage digital display - physical abuse is not a recommended technique for getting a microwave oven to cooperate. If there is any visible damage to the digital display, the outer film is broken, it will probably need to be replaced. There are no two ways to this, other than to replace it.
Take care.
Stopped working without power. Unplugging/re-plugging did not work. No display, no buttons responding. Is there re-set option?
there is a fuse inside,take it to someone that knows how to repair,if you use the wrong fuse,you could cause a fire or health problems
Mar 14, 2015 | Sharp R-820BK Microwave Convection Oven,...
The digital display is broken
I would be able to help you, but I would need the full model number form the tag on the oven and more detailed symptoms.
Oct 27, 2013 | Magic Chef Microwave Ovens
The sharp corousel microwave ( Model R-308 JW) was working . There was a small roach nest in the lighted digital display and the display was hardly to read . This was the only issue. After...
Look into the connector and see the point of contact which is visible of the metal contacts. Now the carbon tracks must be on the side of the metal contacts of the connector. In this case it is possible that while you pulled out the flexible stip cord there is damage on the strip , can be that the carbon tracks were damaged and so it does not contact. if so use a carbon track pen to line the tracks so as to contact.
Reversing the cord will not do any damage as there will not be any contact.
finally make sure that the PCB( printed circuit board) was washed with petrol and brushed properly and then DRIED before the unit was powered or else it can damage the processor.
Check the connection leads that were removed and make sure that it went to the correct postion.
Sometimes the touch pads refuse to work once it is disturbed as it might get damaged in the carbon tracks within.
Sep 21, 2011 | Microwave Ovens
LCD pad, numbers do not appear clearly but as a distorted image. example 1:10 may appear as blank.1E example .40 may appear as blank.1L microwave works fine just the read out panel is distorted,...
On most recent Sharp microwaves, the fuse only interrupts main power, so if the fuse is blown, it will be totally dead.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes then try it.
Then chances are you have a failed microwave display. Unless this is an over the range, touch screen, or convection type, it's probably not worth repair, but you can get more information on such repairs here.
Jan 15, 2011 | Sharp R-310CW 1100 Watts Microwave Oven
Blinking display of advantium m/w oven
by unplugging the m/w for a few minutes and then replugging the problem is gone.
May 29, 2009 | GE Advantium SCA1001SS Convection /...
DIGITAL READ OUT SCREEN
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We also have the complete service manual for this model at our site.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 31, 2008 | Microwave Ovens
Goldstar microwave
The control panel has the child lock turned on.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If that doesn't work, try holding down the "0" pad for about 5 seconds.
Different models use different keys, so try "Stop/Clear" and other keys.
If all that fails, contact LG customer support at 1-800-243-0000 or http://us.lgservice.com
Dec 22, 2007 | Microwave Ovens
Bosch hmt9626 gb 1000w microwave cuts out after 20secs
ur mag netron is faulty the reason for cutting out is thermal cutout switch change magnetron
Jan 20, 2007 | Bosch HMT9626GB Microwave Oven
KitchenAid KHMS2050SSS Microwave Oven Logo
67 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
