Question about Lexmark X7350 All-In-One InkJet Printer
Scanning head grinds and vibrates as it travels along the center bar
  • 39 Answers
You probably already did so, but I would advise calling Lexmark Support at 1-800-332-4120 and asking for a replacement. Sounds like the scan bar has gone bad.
Sorry for the late response, but don't blame me, I only registered here recently and Fixya asked if I could help with this problem.
Posted on Aug 06, 2008
Bars across after reply recording
hi,
your camera's head is either damaged or may be dirt on the scanning chip of the head, try to clean it with a head cleaner tape, if the head is effected with clog, try to clean it several times. then test it with a prerecorded cassette. if there is no any progress, it means the head is faulty, it must replace with a new one.
Apr 04, 2016 | Sony DCR-VX2100E Camcorder
Why is head bar vibrating frequently on startup?
It is supposed to do that while the ribbon runs and it scans the barcode.
Sep 18, 2015 | Printronix LineJet® P7205 Matrix Printer
Ford Explorer 2002 grinding and vibration under 60 mph
you have wheel bearings failing
the random abs light is the rotor for the sensor touching the sensor head because the wheels are loose on the shaft
Apr 15, 2017 | 2002 Ford Explorer
My Husqvarna 125L trimmer makes a terrible grinding sound and vibration along the shaft. What is this?
Could be a damaged bearing in the gear head, could be a bent drive shaft or outer drive tube, clutch drum may have worn the
engine housing and spinning off centre.
Nov 20, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
Grinding Noise in my scanner
Try cleaning the guide bar that the scanning head rides on, apply a thin film of lithium grease on the guide bar
Apr 15, 2009 | Epson Perfection V100 Flatbed Scanner
Dyson animal
Is the noise a loud screaming or a grinding/vibration? The screaming is an air flow problem and you'll want to check your hoses are clear and all the seals are tight. The grinding is an issue with the roller/belt/clutch/motor/housing. From what I'm reading, both problems are common on the Dyson animal.
Sep 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Epson Stylus CX6400 not printing
The head assembly is attached to a photo sensor that tells the printer when it is at the ends of its travel.
Sounds like this mechanism is not working properly.
Check to make sure thare is no obstructions or dirt in the paths at the ends of the print head travel.
You can use an air gun to clean the printer (JUST KEEP IT AWAY FROM THE PRINTER CARTRIDGES) as the ink will FLY EVERYWHERE.....
Oct 29, 2007 | Epson Stylus CX6400 All-In-One InkJet...
Light stripe on scans
Possible causes, CCD failure, smudges or marks that can only be picked up by the CCD if the underside of the scanner glass is dirty. Uninstalling/reinstalling your scanner driver will eliminate if its software related or not. From the looks of it, could be with the CCD if the lines are in the same area with every scan attempted.
Aug 18, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Lexmark X7350 All-In-One InkJet Printer Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
