Question about Whirlpool DUL300 XTL Built-in Dishwasher
I have two buttons that won't stop flashing rinse only and hi temp scour.
2 Suggested Answers
  • 6 Answers
SOURCE: sani rinse, power scour and air dry does not work
wat does it do?
Posted on Feb 10, 2010
How do i reset the consol on a westinghouse dishwasher with the buttons rinse only, quick wash, china crystal, normal, pots and pans, soak and scour, hi temp scour, sani scour, air dry and cancel?
Normally you will have to press High Temp and Air dry button alternatively 3 to 4 times within 8 secs until the whole panel lights up. Then press Cancel. That should reset the dishwasher.
Hope this helps. Welcome to fixya.com.. It is a public forum and you can also answer questions by selecting Solve Problems and answering solutions for problems on categories that you are comfortable with.
May 03, 2014 | Westinghouse Dishwashers
The "rinse only" button will
Hi
If rinse light is flashing then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Jan 06, 2011 | Dishwashers
Lights are blinking and nothing happens when you push buttons
Have you tried pushing and releasing the sani rinse button, then the heated dry? go back n forth several times. If that doesn't work try the soak and scour and hi temp wash buttons and re post results
Feb 20, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Clean light flashing 7 times.
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishawasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 06, 2010 | Whirlpool Dishwashers
Clean light flashing, won't allow cycle to run.
Ifthe clean light is the one flashing then your dishawasher could have aheater circuit problem (depending on the age) or this could simply justbe water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice andtry the dishwasher again making sure to run the water at the kitchensink till it is hot before starting the dishwasher, if this trips andlocks you have a problem with the heating element, or temp sensor.
Pressthe heated dry button followed by the normal cycle button, and thenrepeat once. You should see all of the lights come on for a second ortwo, and then the dishwasher will work again.
If you haven'talready, take a look under the kick plate in front to see if there is aschematic tucked in there somewhere. Whirlpool has put theirdiagnostics for specific models on these.
or
Hope i helped you.
Read the Testimonial by the one of the Customer's who had the same issue :-
http://www.fixya.com/support/t3124974-clean_light_flashes_7_times_time
Dec 30, 2009 | Kenmore 24 in. 16934 Built-in Dishwasher
Our clean light flashes 7 times pauses and flashes 7 times again, we can not restart the unit whats could be wrong
This machine was made by Whirlpool and the flashing clean light is a common error code for them.If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has until all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
or
Hope i helped you.
Dec 30, 2009 | Whirlpool Dishwashers
Clean light flashes, washer won't run
or
Hope i helped you.
Oct 07, 2009 | Whirlpool Dishwashers
Clean light flashes 7 times at a time.
or
Hope i helped you.
Oct 07, 2009 | Kenmore Dishwashers
Blinking Quick Rinse
brent, After doing a little research on this model, I see that Sears put out a service flash concerning this problem. Dishwasher stops in mid cycle and one or more of the lights are flashing. SF22-715. The correction is to replace the existing board with an updated board that controls the line voltage better. Part number 8530928. You could be covered under this flash. The tech will have to eliminate the possibility of a stuck or shorted keypad which will cause this same effect. You can try to get this back in operation by pressing in this order: high temp wash-air dry-high temp wash-air dry. This will put it into a self test mode. Just let it run through if it works. If you don't have those keys try power scour-air dry-power scour-air dry. Catriver...post back.
Nov 19, 2006 | Kenmore 16639 Built-in Dishwasher
Whirlpool DUL300 XTL Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
