Noy reading drive A:.floppy disc is new.it says please insert disk in drive a:
  • 3 Answers
Have you tried to format the floppy disc first?
If the disc is new it needs to be formatted.
Does the LED light up when accessing the disk in the drive?
Posted on Sep 01, 2010
My floppy drive does not seem to recognise that a floppy disk is inserted...after inserting a floppy disk and trying to run it ......it says ' please insert disk into drive A' ? any advice would be much...
Hello there!
Well, you 1st should check is your floppy drive properly insterted into your pc mb. Open your hardware check the joins on your FD(floppy drive) if thats ok, assemble the box. Next move is to check is your FD even enabled in ps BIOS. Open your bios acess general settings, and you should find setting flopy disc 1,28~ enable/disable.
After that if you still experience problems you should thinking about usage of usb pen drives, since floppy drive systems are really outdated, as I know there never been any drivers for that system , so those steps should solve your problem.
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Samsung SFD 321B (SFD-321B) Internal...
What do you mean by insert a disk removable disk
Insert a removable disk, means to place in the appropriate drive one of the the following:
a. floppy diskette
(Usually a 1.4 meg floppy disk) Rapidly becoming obsolete
b. CD disc
c. DVD disc
d. Blu-ray disc
e. Thumb drives
Removable Disk
Also known as removable storage and removable media, a removable disk is a type of media that enables a user to easily move data between computers without having to open their computer.
Hope this helps!
Oct 03, 2009 | Electronics - Others
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Where is the insert for the floppy disc
The floppy disk may or may not be installed in section 5. They started eliminating floppy drives some years ago, when USB flash started to become popular.
5
FlexBay drive panel
Can contain an optional floppy drive or optional Media Card Reader. For information on using the Media Card Reader, see Using a Media Card Reader (Optional).
If your question was more basic than this, and you have a floppy drive, then you just insert the floppy into the slot. It doesn't open. Look for the arrow on the floppy disk, if it doesn't go in one way, turn it over.
Sep 13, 2009 | Dell Inspiron 531s Desktop Computer
Where do you insert a disk in a laptop
Check in right side of laptop .
You find i small button press it so you cna ejct it.
Also you can find with my computer .
open my computer thne right clcik on your cd drive icon then click on EJECT so your disk drive is eject.
Put your disk there.
Let me know if you need more assistanse.
Thanks.
Aug 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
DISC ERROR
This means the the floppy disk drive has dirty the reader/recorder heads, or the heads are misaligned, or the floppy has a mechanical problem during the reading process.
You can start in blowing compressed air inside the floppy disk.
If it does not work, then the floppy drive will need to be serviced or replaced.
Best regards,
May 29, 2009 | Sony Mavica MVC-FD73 Digital Camera
Floppy drive light stays on all the time
please remove the floppy disk if inserted floppy drive...........or unplug the floppy drive .........or check the motherboard setting....some times light on due to reading floppy disk........please try it and rate it
Apr 11, 2009 | NEC (FD1231T) Floppy Drive
My floppy drive tells me to insert a disk when I try to use it
Sounds like you have a bad drive or the disk is corrupted. Did you try a different floppy disk to see if the drive is functioning?
Mar 21, 2009 | Computers & Internet
Memorex external usb floppy disk-drive does not appear or functio
As I understand it the computer recognizes the floppy drive.
Can you read other discs, write to them etc? If not drive is bad
If you can read other discs then your floppy disk is bad
Jan 23, 2009 | Memorex Computers & Internet
Epson smd349 floppy
Hi Elia, Could be a couple of things: -Your drive may only be a 720K drive. They will format 1.44 MB disks but only with a 720K format. The test is inserting a HD disk and try formatting it as HD. -The disk could be mislabeled, HD disks have two holes on end opposite the slide, one to write protect the disk and the other to signal to 720/1.44 capable drives this is a HD disk. -The HD disk could be formatted as a 720K disk even though it is an HD disk, reformat as HD. -The new, used drive could be damaged. -The drive could be configured as a 720K by the computers BIOS. You?ll have to enter the BIOS setup find the config for the A drive and set to 1.44MB. Let us know what happens and please don?t forget to rate the posting.
Jan 19, 2007 | Epson 1.44MB 3.5 Floppy Drive Floppy Drive
Computers & Internet Logo
206 people viewed this question
David Payne
David Payne
