Question about Bushnell 26-2036 Monocular
Bushnell Night Vision 2x36 Scope
I left it at a friends and after picking it up found it rattled when I shook it.
I took it appart and need to figure out how to put it back together.
Does anyone have a schematic or blowup diagram so I can put it back together?
Dave
  • superguy_3 Aug 12, 2008
    had it at a buddys place and when i got it home i noticed it was dirty somehow inside so i took it apart know not sure how to put it together right
  • 15 Answers
SOURCE: Bushnell night vision binoculars
They do stay on for a while after switch, that is OK. Dim and out of focus may indicate that the output voltage is low. If replacing the battery does not fix it, then the problem may be in the power supply circuit.
Posted on Nov 29, 2008
fps353535
  • 99 Answers
SOURCE: Ruger 10/22 Scope problem
This happens will all firearms. what happens when the bullet leaves the bullet is a decieving "rise" of the bullet. The reason for this is the Line of Sight (Scope View), angles down and away from the Line of Departure (Barrel). The bullet actually never rises and is in fact continally falling away from your rifles Line of Departure but because this is higher than the Line of Sight the bullet seems to Rise than fall to the set distance in the scope (i mention set distance and not zero because you can change your Minutes of Angle on your scope to increase and decrease range)
http://www.rifleshootermag.com/shooting_tips/ballistics_0303/
this is a chart that illustrates what i just said.
now that you understand that you should take a good read into Exterior Ballistics. this is the Mathematics of your fireamrs trajectory ( I say your firearms because your bullet's flight depends on the length of the barel which will vary from gun to gun) this science of shooting will teach you how to understand bullet Grain and Volume relations. understanding the Feet per second of your rounds and how the affects you. teach you about shooting in high pressure and low pressure environments and extremly windy environment.
now there is alot of math to all of this and its hard to find it all on the net and if your not that great at math you can do what i do bc im lazy and im not a sniper im just a hobby kinda guy. '
Sierra Infinity V 6 Ballistics Software. I dl'd mine off the net you might have to buy it depending on how resourceful you are. it is well worth the buy. You can punch in the daily variables (Barometric Pressure, Temp, Humidity, and Altitude) (of couse with your bullet as well) and it will give you a "Cheat Sheet" for those conditions stating Windage and Elevation adjustments per decided incriment (50 yrds is standard) then you take that to the range and (bring a laptop if you got it and arent embarrased (som1 might even help you tune in the variables) hope this helps if not ill check back in a bit to see how you did
Posted on Apr 07, 2009
  • 77 Answers
SOURCE: Bushnell Banner .22 scope with loose part inside.
It would be better to replace the minute you disassemble a scope unless resealed with special equipment it will never function as well nor will it be reliable and for a bushnell by time you payed for shipping to and from a repair place you'd be at cost of new so might as get new one which has newer glass types that are vastly better than 20 yrs ago
Posted on Apr 17, 2009
  • 75 Answers
SOURCE: Bushnell 26-3150 NV
Well, there's no telling because Bushnell is not telling. It could be due to it being 'dated' technology and as it is a 1stGen NV they have newer tech. available with other styles. It never got rave revues in the first place. If you can afford it, look at at least 3rdGen NV, even 2ndGen. is good for civilian use. Stay away from the russian junk, almost all of which is 1stGen. But USA if possible and at least you are buying quality which if it needs service, you can get it.
Good luck. :)
Posted on Apr 23, 2009
  • 121 Answers
SOURCE: How to put lens back together on a Bushnell
I presume you have this fixed by now but if not I'd recommend getting it back to Bushnell for repair(is it still in warranty?)
The Permafocus binoculars need specific callibration and the risk of dust or moisture getting in while open is not worth the hassle..
Posted on Oct 08, 2009
Installed new batteries and the unit will not power up. Check polarity and everyting is correct.
Hello, there really nothing I can tell you until I get some clarification on you Bushnell NV audio amp. If it is new then send it back. Did you fill out your warranty card? Also, since they call it a audio scope 26-300 do you need to use ear phones with it? GB...stewbison
Aug 24, 2011 | Bushnell 2.5x42 Night Vision Audio Scope...
My husband has a Paramount moonlight night vision NV 100 that the lumint red light comes on but the night vision stopped working after only a few months it was bought a few years ago he put up and forgot...
Hello. The red light is the IR (infrarad luminator) this inhance the night vision capabilities of the scope, monocular. Do not look directlly into the IR tube, The Paramount Moonlight has gone to the land of the Red Star. The scope contract is up. it junk, to expensive to repair. stewbison
May 26, 2011 | Bushnell MOONLIGHT Night Vision -...
Left lens no clear view and both lenses blink
What color is it when you turn on you Bushnell binoculars? I think this Bushnell 26-3150 is a digital NV devise that uses CCTV image tube. In other words, it not anolog operation, but uses a digital devise to convert the iit (image intensifier tube) analog signal to a digital signal. There are advantages using digital signal, increase pixel rate, low power comsuption, etc. stewbison. Call Bushnell Night Vision and listen what they have say on this matter. stewbison.
May 20, 2011 | Bushnell 26-3150 Nightvision
I can't see any object in my night vision monoscope. The batteries are new.The indicator IR and ON are illuminated when switch to on.Please advice. Thank you very much. Respectfully yours, Remigio...
Hello, did you turn the Bushnell on. There two switches one for the on/off the other is for the IR and it say on as long as your finger pushs the button. Have you used during the daylight hours, looking a bright lights. If you have, the NV has gone south in one hurry.
If want come on even though the on/off switch working. If the NV devise is work there will be a green LED on the back indicating that the devise is on. stewbison
Feb 02, 2011 | Bushnell 4x50 Prowler Night Vision...
I need an owner's manual
Hello. Go to this Bushnell URL site http://www.bushnell.com/manuals/night-vision/26-0900_Night_Vision_6LIM.pdf. This will give you owner's in about 10 different langage.
GB you...stewbison
walk gently upon this earth, and she will be good to you....
Feb 01, 2011 | Bushnell NightHawk 26-0900 Monocular
I have a AMT nightvision rifle scope that was made in the 1990's that has no serial numbers. I am wanting to know more about the scope. what generation etc.
Hello, AMT is defunked, no more, all gone, left in the night, can't see them. no good bye. Don't worry, ATN Inc bought their stuff, just different name now. Sorry, i don't think you can find any material about the AMT NightStorm NV. Try contacting ATN Inc. in CA. ATN does make NightStorm monoculars. GB....stewbison
Nov 18, 2010 | AMT NightStorm Night Vision Optics The...
Hello, I live in Argentina and I sent you a night vision to have it repaired. As I read, you don´t return items overseas. I´ll be staying a week in NY next month, can I ask you to send the night...
Hi Miguel, I think you might have sent this email in error. Go here to explain the mistake to FixYa so they don't mistakenly charge you:
http://www.fixya.com/contact
If I am mistaken, and you are asking a FixYa technician for help, forgive my mistake.
Sep 08, 2010 | Bushnell 4x50 Prowler Night Vision...
Hi the ir is not working on my bushnell 26-0400,is there any way you can help (repair ?)
I had the same model, same problem. Bushnell replaced mine under warranty, If they needed to send it for repair it had to go to Russia. I guess it was cheaper to give me a new one. If its not under warranty Bushnell will send it off for you but it will cost quite a bit. My new pair lasted about 2 years with a lot of usage. Gen 1 night vision tubes do not have a very long life span. You may be better served buying a new pair of night vision binos.
Jul 08, 2009 | Bushnell 26-0400 Binocular
I need help with adjusting my rilfe scope after it was shook up in a fall.
Contact Bushnell and see what they recommend you do. They're pretty good about helping people out and may service it for free for you. Give it a shot.
May 24, 2009 | Bushnell Optics
Dosent work
Get a technican to give it the once over - the wires may have been cut because the equipment is unsafe to use. If not, they should be able to fix the damage as the circuits are quite simple.
Nov 16, 2008 | Bushnell 2.4 x 29mm Night Vision Compact...
Bushnell 26-2036 Monocular Logo
132 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
