Question about Neff B1644 Electric Single Oven
Hi, I have a Neff oven Model No B144 2N0GB. The light has blown but I am unable to remove the glass cover to replace the bulb. It appears as if the glass cover has fused into its surround because it refuses to unscrew. Several fit men have also tried to unscrew it without success. Any ideas? Best Regards Paula
  • Neff Expert
  • 414 Answers
If the unit is less than two years old, cal 0844 892 8999 and ask for an engineer to come out. Alternatively, put on a pair of marigolds, this will help with the grip and remember that the cover comes of anti-clockwise if you are looking up at it. If you do not want to call an engineer out, call the number above and ask them to post out to you the lamp cover removal tool. Part number 613655.
All the best
Posted on Sep 02, 2010
Testimonial: "Really helpful - many thanks"
Unable to remove light cover inside oven
I'm not familiar with that oven model, but as I have had a similar issue with my Neff oven light, I thought I would give you the benefit of what I had discovered. The light cover in my oven is a round, thick glass cover. The hand book has a graphic showing that the cover is simply twisted with one hand in an anti-clockwise direction as viewed straight onto the cover. No way! The first issue is that the lamp housing is right in a tight corner and getting sufficient grip on the cover is tricky. I put rubber gloves on to increase the grip and resorted to using two hands to exert as much force as I could manage, but it only moved a small amount. I think the movement was only the entire lamp housing moving in the oven wall, rather than any movement of the cover. I tried warming up the oven (not too hot) in the hope that the cover might release due to expansion, but no go. I then wondered if cooking grease / deposits and bonded the cover to the holder; although it appeared reasonable clear. This appears to have been the issue as I applied WD40 to the seam where the glass meets with the lamp housing and left it for a few minutes. It needed a second application, but eventually came free. On inspection, there was only a minor 'varnish' on the glass that appeared to have prevented the two parts from moving. Using WD40 weakened the bond eventually, but it also made the glass incredibly slippery, so gripping the glass cover after application is difficult. I used the rubber gloves and wiped the glass well to remove any residual WD40 prior to attempting to twist the glass cover off.
Oct 06, 2014 | Neff Ovens
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
I have a neff oven, cannot remove glass cover to change bulb. Was advised to buy strap wrench, no good. Advised to heat oven, no good. Cover moves about quarter inch, when heated , nothing. can you please...
Having tried several ways to get the glass cover off, there is one other thing you can try.
Spray some WD40 around the glass cover,and keep trying to tighten and then unscrewng it, and tighten again.
If this does not work, then the last resort is to break the glass cover, which is what I have had to do in the past,. but make sure you can get a replacement cover first.
Please rate my solution.
Thanks.
Nov 24, 2009 | Neff U1721 Double circotherm Electric Oven
How do I replace the lightbulb. NEFF B1442 series 3 Oven
1. Some glass covers are held on with a wire clip over them. It should be visible.
2. Some have a 'ring' which is screwed to the oven cavity around the light cover. On that design the screws need to be removed from the surrounding retaining ring.
3. On may later model the glass light cover screws into place. Those covers should 9hopefully) be able to be unscrewed the same you you'd remove a jar lid.
Nov 07, 2009 | Ovens
Broken screw of Light bulb stuck in Neff Oven
hi,,
make sure the power is OFF. get yourself a flashlight and a small flat blade screwdriver. okay you have to make a small bend in the old light bulb screw area so you can get a pair of needle nose pliers in there to get that out, you need to get right in between the threads of the socket and the old light bulb, just enough room to get a pier of needle nose to turn the old bulb out, be careful take time
J
Jun 29, 2009 | Neff B1421 Electric Single Oven
Trying to unscrew bulb cover in a neff oven
no WD-40, turn of the power, break the bulb and remove the base with pliers. More than likely there is dielectric corrosion between the base and the socket and this makes removal next to impossible
Jun 13, 2009 | Neff U1721 Double circotherm Electric Oven
Unable to remove the glass cover to change the light bulb in oven
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
Jan 12, 2009 | Ovens
Trying to replace main oven bulb: cover jammed
Try heating it up with a hair dryer or similar if that does not work then you will probably have to break the glass cover.
Nov 17, 2008 | Neff U1461 Double circotherm plus Electric...
Neff cooker model b1422nogb bulb replace
Unscrew glass cover anti-clockise, likewise unscrew bulb, and replace.
Apr 28, 2008 | Neff B1421 Electric Single Oven
Change Bulbs in Neff U1661 Oven
You don't need to slide the oven out, just remove the glass covers with a flat bladed screwdriver and then unscrew the old bulbs. Replacement is the opposite.
Bulbs available from Homebase, Wickes, BandQ etc etc.
Apr 27, 2008 | Neff U1661 Double circotherm super...
Neff B1644 Electric Single Oven Logo
488 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
