Question about IBM ThinkPad T20 2647 Notebook
Not powering up
The other day i had the laptop on and was working fine until. it white screened an then the battery icon on the unit went out like it had no power at all even when it was pluged in resontly i have tryed to turn it on and it came on then back off so i pluged it in to charge the battery and now nothing again whats up with that do you know??
I plugged in my usb for my camera and the screene went dark. It has been dark ever since and you can barely see anything. I'm trying to figure out what is wrong, how to fix it and if it will cost anything. It is a hp laptop!
Posted on Jun 10, 2008
  • 3 Answers
Sound like the power connection may have broken therefore not allowing the unit to switch on or charge.Do any lights flicker when you plug it in?
Replacement part should do it
Posted on Jun 04, 2008
Htc 8s water damaged?
It is a water demage - with using to quickly you made it bad, I guess with pressing the screen you moved the water.
I would say ... give it another dry (smile)
Open the rear, take the batterie out ... mean let the mobile breath ... then leave it on a warm, but not hot place ... it has to stay on the side. We want that the water in the case vabours troughthrough the side buttos within the time.
Feb 04, 2014 | Computers & Internet
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
Hi. I went to switch on my HP Pavillion Laptop one day when it unexpectatly froze during startup. I clicked the power button of the laptop and everything seemed fine with the lights turning on and the...
That blinking cursor is the way in which the BIOS of the laptop is telling you that it can't load Windows because it's too corrupt There's nothing more you can do apart a full reinstall. Use the recovery disk that has came with the laptop when you bought it.
Jan 15, 2011 | Computers & Internet
My ibm laptop, was working great until this morning, the screen started to flicker, then the icons started to dim and completely disappear and then the screen went to a coloured test pattern and finally...
Check the power supply.Hope the notebook receives power from the battery or the Ac adapter.We need to ensure there is no issue with the power supply.boot the notebook to the safe mode.If it boots to the safemode perform a system restore.In case the notebook does not boot to the BIOS,connect to an external monitor.If we still do not get a display,its the video card
Mar 02, 2010 | IBM ThinkPad T40 2373 Notebook
Total battery power remaining: Unknown
Well you can try a system restore.
1.) start
2.) programs / accessories / system tools
3.) system restore
follow the on screen instructions too restore the computer to a few days before it started having problems.
Chances are that the battery is shot if system restore fails.
Mar 01, 2010 | Acer TravelMate 5720-6635 Notebook
I was downloading the latest version of Norton Antivirus and half way through my computer locked up and the screen went white. Now nothing works. I can't power off because there are not icons available. I...
First diaconnect all external devices connected to your laptop, restart computer then access F8 for safemode and then uninstall the norton in safemode then restart again .
ERNZ
Feb 05, 2010 | Toshiba Satellite Pro L300 Notebook
Gateway 450ROG Laptop was downloading a video when the screen slowly went all white. I had to power off. I waited a while reloaded the battery and powered up. I got the windows didn't power down right....
You must go through the safe mode and uninstall your graphics driver and install another one, may be you will find more compatible driver with your graphics card and your windows copy on gateway website.
Jan 31, 2010 | Gateway 450ROG Notebook
Hi, my DV9700 battery does not charge, adapter works but does not charge or run the computer on its own. I have had it checked and everything seems fine, they suggest the motherboard but I explained that...
This may sound stupid but try this, for some reason this seem to work on 6 and 9000 units with charging problems.
With the unit running, disconnect the battery and allow the unit to run for 60 seconds, then plug the battery back in, again with the unit running.
Nov 30, 2009 | HP Pavilion dv9500 dv9600 and dv9700 FF...
My acer aspire laptop has a blank screen when it is turned on it was working fine and I pressed alt+f10 then it went blank with just a white blinking cursor
Hold down the power button until the computer completely shuts off, wait 10 seconds, power it back on.
What happens?
Nov 21, 2009 | Acer Aspire 5720 Notebook
I have a problem with asus eee 901. I've just bought it. It had linux, but it was changed into windows xp. Since it had been fully charged only once I was using it on battery and setting it up with new...
Remove the battery for a couple of minutes while the unit is not plugged into the a/c adaptor. Reinstall the battery, plug the unit into the a/c adaptor, and see if it will boot up.
Mar 14, 2009 | ASUS Eee PC 901 20G Notebook
IBM ThinkPad T20 2647 Notebook Logo
79 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
