Question about DeLonghi Alicia Moka Access Kit EMKKIT
Delonghi Alicia, 2 cup espresso maker. h20 appears on the screen. there is water, coffee maker is well assembled to the base and it is not hot. I was able to make only 1 pot coffee with it yesterday (just taking it into use).
SOURCE: Leaky Tassemo coffee maker
i think it's supposed to do that. the cup at the base is supposed to be catching all the water that the tassimo is 'leaking'. it should be dumped after every cup of tea/coffee. if you have taller cups, and do not use the cup base that comes with the machine in order to fit the taller cups under where the tea/coffee comes out, then you are right. it seems like it's 'leaking' because it is. there should be enough room in the base for one cup, but then it can also be removed so as to dump the excess water out after the cup is made. hope this helps!
Posted on May 27, 2007
Noggin
  • 944 Answers
SOURCE: DeLonghi Alicia EMK6 - H20 error
Here is the link to the instruction manual if you need it; http://www.delonghi.co.uk/pdf_files/EMK6.pdf There is no information regarding this error message available online, but I think you are right and it relates to water - probably the sensor of the water level is stuck/blocked/scaled up. you can try descaling using white vinegar 50/50 solution with water, leave it overnight. Give the whole unit a good shake, in case the level sensor is a mechanical float device and it is stuck. See if any change. You can call Delonghi/Comet from this link; http://www.delonghi.co.uk/service_info.php hopefully they will tell you for certain what the error message means - if they do and it is different from what is discussed above, then please ask again if you want to try and solve the problem yourself. Hope this helps :)
Posted on Jul 31, 2007
  • 123 Answers
SOURCE: instruction manual for delonghi combi espresso/filter coffee maker bc0255
http://www.delonghi.co.uk/pdf.php?key=Coffee%20Machines
Your manual is listed on this page and you will be able to download it.
Good Luck.
Posted on Apr 10, 2008
SOURCE: My Vev Vigano Kontessa 12 cup espresso maker does not work properly
(a) Check that the pot is screwed on tightly enough...if you see an excess of steeam coming from where the two partrs join, then you may have coffee grounds trapped, thus steam escapes, thus you have less coffee, because you lose pressure...lose pressure = lose heat = less coffee! SO, make sure the pot is tight AND there is no coffee grounds on the rim.
(b) There is always some residual water left in the basin
(c) Water is also trapped in the residual cake of spent coffee left over.
Posted on Jun 07, 2008
  • 2976 Answers
SOURCE: How does it make coffee?
You fill it to the line indicating how many cups of coffee you want to make. Then you add coffee to the brew basket, at least 1 full heaping teaspoon per cup. Put the basket on top of the stem and place the stem into the coffee maker. Put the lid on and plug it in. That's it. Don't plug it in without the lid, it's a percolator. It will squirt the water out the top of the stem and it flows down through the coffee grounds.
Posted on Jan 04, 2009
What does H20 mean ?
In Chemistry H2O is abbreviated symbol for water. It means a water molecule has two atoms of Hydrogen and one Atom of Oxygen..
Oct 15, 2014 | DeLonghi Alicia EMK6 Coffee Maker
Why doesn't my delonghi magnifica coffee maker add enough water to my coffee
Re program the machine so that when it dispenses coffee it runs a bit longer. not only hot water but a bit more coffee.
May 23, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Our Delonghi Prima Donna always made hot coffee up until 2 weeks ago
Try first to heat the cups ,and then make the coffee.
Becouse the water for coffee and for hot water comes from the same way.
Apr 25, 2017 | DeLonghi Prima Donna Avante ESAM6700...
DeLonghi Magnifica 3200 how to increase coffee temperature?
Evening to you
Not hot enough, do you leave it to stand with the green lights on?
By my experience the machine is best left on so everything is hot when the water passes through.
To let some time pass before you make the next cup.
And lasly to make sure that machine is clean.
Good luck
kolbrun
Mar 05, 2012 | Faberware FSCM100 Coffee and Espresso...
How much coffee to add for 20, 40, 60 cups of coffee in the 60 cup DeLonghi coffee urn?
I like my coffee pretty strong and I use 2/3 cup coffee to 10 cups of water...
You may be able to use 1/2 cup to 10 cups if you don't want it too strong...
You must experiment a bit as different coffees will vary also...
heatman101
Apr 30, 2011 | DeLonghi BAR 140 Espresso Machine
How to remove and clean milk out of espresso water tank :-(
NO the tank is just that a tank and you cant get into it to clean....there are many products for cleaning your coffee pot. Some coffee brewing cleaning products are made by Urnex.Buy mixing a half cup (1/2 cup as i assume espresso meaning a small tank the more vinegar you use the more cycles you'll need to remove) of vinegar with the rest water and brew once or twice 2-3 times or until its right to you.
May 12, 2009 | DeLonghi Caffe Figaro BCO110 Espresso &...
No water light on new delonghi magnifica
I had the same problem.
As the machine is brand new, try washing the infuser under the hot water tap and then dry it. I then made a 2 cup long coffee and the red no water light stayed off.
Mar 24, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Jul 30, 2007 | DeLonghi Alicia EMK6 Coffee Maker
Coffee Makers & Espresso Machines Logo
113 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
