Question about 350 HV ESP Security System 350HV ESP
My vw beetle 2004 wont start after removing the battery cable when the aircon system was clean.
  • nbmaducdoc Sep 01, 2010
    there is a power but the engine wont continue running , it will last for only few seconds then the engine stops.
  • 19,396 Answers
Hi.
Check all fuses, with attention to fuel pump fuse. Check the connectors to fuel pump, eventually read volts at pump and nsure that fuel is circulating
Check air intake and connectors to air intake sensors (MAF sensor), check connection to crank sensor and O2 sensors.
Remember that after a prolonged and failed attempt to crank the vehicle, the cylinders will be flooded and the car will no start (wet plugs- no spark).
Check if there is spark on all cylinders. This can be done removing one by one the spark plugs wires and putting them near to the engine block while someone else try cranking. You will see the spark.
If there is no spark, then you have a coil/distribution problem. test coil by reading volts in and impedance (coil must not be open). I think this engine is not distributorless. Check distributor cap and wires. If you have disconnected spark plug wires after the problem, also ensure that wires are connected in right order.
Once you are sure that there is spark, check fuel delivery and engine control. This part will take longer.
Posted on Sep 08, 2010
  • 2,019 Answers
Try removing the battery cable again, and let it sit off for about a half hour.
The system may be confused and just need to be reset.
You could also try turning the alarm on and off.
Normally locking and unlocking the driver's door will do that.
But personally I would have the Viper 350 HV ESP Security System removed.
The last thing you want is an unreliable car.
You would be better off having it stolen than be unreliable.
Posted on Sep 02, 2010
  • Kirk Augustin
    Kirk Augustin Sep 02, 2010
    Cars sit outside in subzero or blistering temperatures, get rained on, covered with dew, bumped and jostled, etc. Delicate electronics will just not last in those conditions.
  • Kirk Augustin
    If it does run at all, then I would assume the security system may not be the problem.
    It could be the fuel system.
    Check the fuel pressure.
    Also check the voltage at the coil and at the fuel injection control box.
    It could be that only the cold start injector is working, if it stops right away after starting.
  • 944 Answers
HI,
Check your alternator wiring connections first.
This may occur due to three reasons
1)Loose battery cables.
2)Defective battery.
3)Bea cause of Fuses.
3)Alternator.
*)Take the battery to have it tested.Check the voltage with your volt or multi-meter, it should read around 12.5v. If there's an Auto zone there, they do free testing If you gradually lose battery power, it's the alternator. If there is no power at all, check your fuses.
*)Look over all of your fuses, to make sure none of them such as the fuel pump fuse, or the fusable link have burned out
*)Check your alternator wiring connections first.
*)Likewise if your vehicle is equipped with a MAP (manifold absolute pressure sensor) be sure that is plugged in correctly.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 01, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 02, 2010
    1)This due to fuel delivery problem it is not getting the fuel you need into the pistons.
    If fuel is the problem, check the fuel pump, pressure...
    2)The ignition system problem the plugs aren't sparking at the right time.
    3)Clean the fuel filter.
    4)vacuum leak could also cause this issue
    Thank you
Vw beetle battery is good but something is draining it. sos help
The standard procedure is to disconnect the negative cable and use a test light or meter to measure voltage.
A test light between the battery post and ground will light up until the drain is knocked out.
You disconnect each fuse and cable until you find the drain.
Jan 18, 2013 | Cars & Trucks
2004 vw beetle wont go into lockup
lockup is controlled by a solenoid in the valve body, VW automatics are notorious for problems with their valve bodies.
Oct 08, 2012 | 2004 Volkswagen Beetle
1998 vw beetle wont start when turn key but bump start works but doesnt want to stay running\
This sounds like the anti theft system is active, you jump start it but it dies out after a few seconds , if this is correct then try another key. the other thing can be a weak battery make sure the battery is fully charged and good,
Oct 01, 2012 | 2000 Volkswagen Beetle
1999 vw beetle, a/c suddenly stopped working, fan blows and light comes on, but compressor doesn't
Have the aircon gas checked. If there is a leak in the system the pressure will be to low and the compressor won,t kick in. Re-gas aircon and check for leaks.
Jun 08, 2010 | 2000 Volkswagen Beetle
My daughter's 2004 vw beetle started slow once, then it wouldn't start the next time. When my husband jumped it still wouldn't start. Do you think it is the battery needing to be replaced?
Most likely it needs the starter looked at or replaced,try boosting it with jumper cables.If it starts go with the battery theory,if not stick to my theory.Hope this helps.
Oct 23, 2009 | 2004 Volkswagen Beetle
How do you replace the battery in a 2004 volkswagen beetle
VW managed to fit the battery in the very last bit of space available. There is a bolt in the front that clamps the front edge down. Once it is unclamped, you'll need to unbolt the power steering reservoir to make room to get it out. If you don't use a "data saver" on the cables, you will need to enter the radio security code and possibly re-adapt the throttle body.
VW is short of volkswagen. Thank you.
Sep 17, 2009 | 2004 Volkswagen New Beetle Convertible
2004 vw beetle window fuse what # would be for the fuses? I don't have a manual & pannel doen't show.
Send me an email address and I'll send along a fuse block diagram for my daughters 1998 Beetle, it's most likely the same in 2004. Compare the arrangement with yours.
The 1998 diagram doesn't indicate any fuse in the inside fuse block that controls the power windows (even though my daughters 1998 has power windows). There is a metal fuse on the fuse block above the battery that controls the cars electrical system, but the diagram indicates that this should only be replaced by a VW Dealer.
Maybe you can call the local VW Dealer once you have a fuse block diagram to refer to. They should be willing to tell you over the phone.
Apr 04, 2009 | 2004 Volkswagen New Beetle Convertible
2004 Volkswagen Beetle Radio/CD player
new one with a usb connector and sd card reader is better and cheaper
Jan 31, 2009 | 2004 Volkswagen New Beetle Convertible
350 HV ESP Security System  350HV   ESP Logo
143 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
