Question about Logitech QuickCam Pro 5000 Webcam
How can i reinstall the logitech camera in my computer?
My problam is that my cam is not working
Try and remove the usb cord from the camera and computer then go to control panel then add/remove programs,remove the logitech camera restart then reinstall.
If this doesn't work
Try to uninstall and then reinstall your drivers. Or check for updates from the manufacturer. To modify your drivers go to your Control Panel> Hardware and Device> Imaging (most likely something like this)> and then find your Logitech camera. Click on the drivers tab and check for updates. If this doesnt work then uninstall the drivers and then reinstall them. Check and make sur eyour cables are all tight as well.
Their website also has a handy tool to help you...http://www.logitech.com/support-downloads
Aug 15, 2012 | Logitech Webcam
RE:QuicjCam UltyraVision- even though camera IS plugged in,program does n ot recognize this fcat. Multiple attemps and all available USB ports tried - and yet "CAMERA IS UNPLUGGED" persists. ...
try to uninstall and reinstall the program again
go to start control panel add or remove hard ware take it all out and reinstall then do a reboot
Jul 29, 2008 | Logitech Cameras
My web cam is not detected
You may need to perform a clean install of the Logitech camera software if it didn't install properly or a another program in memory is conflicting with it. Removing the camera software and reinstalling it using a clean boot procedure may resolve the symptoms you are experiencing.
The following instructions will walk you through this process:
Remove the Logitech camera software.
  1. Unplug the camera from the computer. Later you will be prompted by the software to plug in the camera; do so at that time only.
  2. Open the Windows Control Panel.
  3. Open the Add / Remove Programs window.
  4. Locate the listing for the Logitech camera software and remove it. When prompted to remove the camera drivers files, click Yes.
Prepare the system for installation of the Logitech camera software.
    1. Go to the Logitech Downloads Page and select your product to download the correct version of the Logitech camera software.
    2. Please see here for the clean boot procedures.
    3. Doubleclick the icon for the Logitech camera software download file.
    4. Follow the on-screen prompts to complete the installation.
  1. Return Windows to its normal state.
    1. Use the instructions located here to enter MS Configuration window.
    2. Place checkmarks in the items that you previously removed them from.
    3. Click OK and allow the computer to reboot.
    4. Test the Logitech camera software to ensure your original issue has been resolved.
    Please ensure that you are using QuickCam 11.8 if you have Windows Vista or Windows XP
Dec 20, 2010 | Logitech QuickCam Express Web Camera
My logitech system got erased from my computer. When I reinstalled it, there are no more special effects like the "fun filters". How can I get that back on?
Either go to the Logitech site and search for fun filters or Google for Logitech Fun Filters download, and see what comes up, that should do the trick.
Jan 26, 2010 | Logitech QuickCam Messenger Web Camera
Unable to install logitech software for quickcam s5500 on to a computer with vista
clean boot the pc. and reinstall
http://www.logitech.com/pub/techsupport/quickcam/lws100.exe
Jul 11, 2009 | Logitech QuickCam Express Web Camera
Logitech QuickCam1150 Notebook Deluxe camera not configured properly in xp error
Hi, Please uninstall any logitech software version present on your OS (if available) - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if
possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for
new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect
the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware
failures are covered by warranty terms
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Nov 10, 2008 | Logitech Webcam
Webcam installation
Go to the link that I have below, on that page (The logitech support page) you will see many pictures of their different cameras. Look until you find the picture of yours if it is there, and click on it.
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
From that page you should be able to download the installation for your camera. Good luck, and let me know if there is anything else I can do to help you.
May 21, 2008 | Logitech QuickCam Express 5-Pack Personal...
Camera is not recognised
HI YOU CAN DOWNLOAD THE SOFTWARE FOR LOGITECH WEBCAM FROM THIS LINK http://www.logitech.com/index.cfm/suppor...
Aug 30, 2007 | Logitech QuickCam Messenger Web Camera
Logitech QuickCam Pro 5000 Webcam Logo
15 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
