Question about Goodman Heating & Cooling
My Goodman Central AC Unit will not power on.
    President:
  • 1,515 Answers
Hi, have you checked all breakers, fuses in the disconnect box at the outdoor unit as most have them in behind the pull out off plug. Please give me more information on this and I can solve this for you.
Sincerely,
Shastalaker7
A/C,
Posted on Sep 01, 2010
10 year old Goodman central AC won't come on after mini power outage. Breakers and wall thermostat OK.
Check the start capacitor for proper value and replace if necessary.
Ditto for thermostat. There are also some fuses in the air handler that might need replacement.
You may have had a power surge that had a bad effect on electronics of unit. Make sure that unit is receiving power for one thing. U might try to reset the electronics by completely shutting off all the breakers to compressor and air handler and waiting a few minutes and then reconnecting.
Sep 02, 2015 | Goodman Heating & Cooling
I have a goodman 4 ton central ac unit. The fan blower turns on but the compressor will not turn on. I replaced the capacitor and verified the compressor is receiving power. My question is a goodman...
Hello, you can Ohm the compressor windings with a multimeter. Just kill power the the unit, remove the wires from compressor and check each winding. You should have resistance, if not the windings are open and compressor must be replaced.
May 24, 2012 | Heating & Cooling
I have a Goodman AC unit that isn't working. I believe its the fuse. My power went out and the ac unit stopped working. the first time the repair guy said it was the fuse. I don't want to spend...
Generally, the fuses are located in a box outside by the outdoor unit. The box has a door on it and you will probably have to pull a cartridge out and the fuses will be behind the cartridge. If you don't have an ohm meter to check the fuses , just go to home depot, lowes or another hardware store where they can check them for you. Be sure to check the circuit breakers too.
Jul 11, 2011 | Goodman CKL36AR36 Air Conditioner
My central air unit comes on but it's not cool and
to me it sounds like filter are dirty, need to be cleaned or replaced, home systems, packaged or otherwise are hermetically sealed and should not need freon recharge. Always start with airflow and/or unit being set too low. An AC unit of any type will build ice if a) the filter is plugged up and can't move enough air, b) it has been run without the filter, clogging the coil, again, not moving enough air, c) setting an AC unit below 68 degrees F will almost ALWAYS cause icing, and d) running a standard AC when it's warm inside and cold outside (unless equipped for "low-ambient operation"). When in doubt, a bit of maintenance(thorough cleaning) by someone with AC skills can cure a b, common sense will cure c d.
Reply
Jun 23, 2011 | Goodman CKL42AR42 Air Conditioner
My goodman central air unit quit working after a storm. The circuit breaker is not blown. The furnace fan kicks on when ac is turned on at the thermostat but unit outside does not operate. Is there an...
1 posible cause.the thermostat supplies 24 volts to the outside unit to control the contactor if you hear a ligth huming on the outside unit this is the being activated. if this is the case then
check to see if any ants are in or around the unit see video, they will usually climb to dry areas before during or after a storm and for some reason they like the contactor if this is the case cut all power to the unit and clean contactor spray the area around the unit with an insecticide ( not the contactor) replace cover and test unit. Best of Luck. raypena_4.jpg
May 30, 2011 | Goodman Heating & Cooling
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
Goodman CK30-1A Central AC Unit will not run by thermostat
double check your t-stat wiring your not getting 24volts to the contact at the cond. unit outside
Jun 20, 2009 | Heating & Cooling
My goodman cple18-1c model central AC unit blowing hot air
Ths sounds like the outside unit or compressor is not kicking in, check for power to the unit at the breaker box, or at the bottom of the contacts!
Sep 13, 2008 | Goodman Heating & Cooling
Goodman Furnace/AC unit not working 3a fuse blows even after replacement. once thermostat is turned on and clicks to start ac unit the fuse blows
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Jul 03, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
65 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
