Question about Garden
I have a Kew Hobby w-tra 3600 presseure washer. There is a problem with the electric swich needs extra weight to hold it down. any reccomendation? bela@ntlworld.cok
  • bela35 Sep 01, 2010
    so this is the cause , what is the solution?
    Bela
  • 10,319 Answers
The switch does need to be replaced
The housing inside has simply widen from the heat of the current causing this to happen
Posted on Sep 01, 2010
  • frank thomas wilson
    frank thomas wilson Sep 01, 2010
    here is a website that may have your switch
    http://www.sparesgiant.com/m-2-kew.aspx?...
Kew hobby 3600 wiring diagram
go to the next web page and translate with your browser.
www.automecanico.com or www. autoelectronica.com
God bless you
Jun 18, 2013 | Cars & Trucks
Were is cluch sensor on jetta manual tra
I believe there is a switch on a lot of manual trans cars on the floorboard.This ensures that the clutch pedal is all the way down before the starter is engaged.( I am taking a guess here)
Apr 05, 2012 | 1992 Volkswagen Jetta
Kew 1640H with display flashing A 2 fault code
Hi really hope someone can help as I couldn't find a manual for my kew alto 1640hot and cold diesel pressure washer, problem is when I turn it on from been stood over night !i press on button and I see a f then a 1 flashing on the display ,anyone know what it means or we're the fault is,
Sep 18, 2011 | Garden
Kew hobby pressure washer. powers up ok but no pressure behind water jet..??
frozen output valves were the hoses attach to. two or them are present. one is inside the other
Apr 12, 2011 | Garden
Type- KEW Hobby waterblaster- requires addition pump oil. What kind of oil does it take.
Pump oil is 20 or 30 weight non-detergent motor oil. SAE20 or SAE30.
Pump oil fills about half-way up inside pump. Look for fill mark or read manual.
Of course you saved the manual, right? So you're not in line at fixya wanting a manual for some product made 5 years ago in China by a company that doesn't post manuals. Or manual is available in Italian and German with pages missing.
If this is gasoline-powered engine, do not turn machine upside down to drain oil or 10-W30 engine oil will drain into carburetor.
Nov 27, 2010 | Garden
Kew Alto Force X-TRA cold water supply pressure sensor problem
Have the same p-washer (5-6 years old) and the same problem. Opened it and the pressure switch is the crook. A plastic pin has an inner and an outer spring on it (two consentric springs). The smaller inner spring is completely rusted away so the switch no longer operates correctly. Obviously the spring was of a too low quality. The service office say a new switch cost around 400NOK (50 euros) - so the washer is too expensive to mend. But I will try to get it working without the inner spring. Doubt if I succed. So will have to dump the washer.
Mar 19, 2010 | Garden
I have a Kew Hobby 80. The output from the lance is not constant but pulsates.
Could be the input water pressure is not sufficient. There is a pressure valve inside the machine that will cut off the motor if input pressure is too low or non existent.
Try a different source for the water input.
Feb 22, 2010 | Karcher PSI Electric Pressure Washer
Kew hobby 80-1 instructions
I have a kew hobby 70 with little use. The nozzle wont spray, it just sends a weak jet of water. how can i fix it? I have hardly used it. It has been
in a shed for years . thanks
Sep 29, 2009 | Garden
Found this presure washer in the basement and want to know if it works the motor runs when you plug it in but does not build press. The brand is kew hobby
This may be as simple as still having air in the system.  Connect the machine to the water supply (but not the electric) then squeeze the trigger and allow water to flow for at least 60 seconds.  During that process, hold the nozzle outlet under the surface of water in a bucket so you can see when air stops coming out.  Keep going until you're sure there's no more air in the system.  Then switch it on.  If it still does not come up to pressure you'd probably be wise to abandon it.
Apr 16, 2009 | Garden
Garden Logo
669 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
